Question about Fellowes Office Equipment & Supplies
Fellowes 99ci not shredding fully across paper. I took unit apart and cleaned the teeth. not sure how to put it back together again. I can't find pictures anywhere.
fellowesrep
  • 102 Answers
SOURCE: motor keeps running with the yellow light on and will not shut off.
paper feed sensor is dirty, jammed or broken depending on what kind of sensor your unit has. I work with Fellowes machines but sounds like an issue I have dealt with on our machines. You should contact manufacturer for more detailed info on how to clean or unjam sensors.
Posted on Mar 02, 2008
SOURCE: Took my 360 carefully apart to clean the eye. Put it back together light turns on then off.
its olk
SOURCE: Shredder won't run
I had similar problem. I took unit apart and checked the motor by hotwiring it after checking voltage coming off the circuit board connections that the motor is connected to. Motor did not run until I tapped it a couple times with a hammer. Seems ok now.
Posted on Mar 22, 2009
  • 6 Answers
SOURCE: will not shred, but will go in reverse
Sorry don't mean to point out something obvious, but are you being shown any indication lights that the waste basket is not seated correctly in the bin or the head? If not, then you may want to try and check these connections anyway. Lights can burn out.
Posted on Aug 22, 2009
  • 747 Answers
SOURCE: We have a Fellowes SB-99Ci. It
you have a staple clened to the corner of shreder get a pair needle nose pliaers.
Posted on Feb 02, 2011
Cause of "stall" during routine shredding letter head paper
Lack of grease on the internal gears. accumulation of small bits of paper causing the motor to slow down and stop.
May 25, 2015 | Fellowes Powershred SB-99Ci Heavy-Duty...
Plastic stuck in my Fellowes shredder blades!
Sorry, but no. There isn't really a way, unless you are very technically minded, to take the teeth apart and clean them. You might try, using a paperclip, I find that I have to do that on occasion to clear out the pieces that get caught in between the teeth.
or maybe, just a thought,?... You can use a product called goof off, it does come in a aerosol can as well, in addition to small bottles of the product in liquid form. Good luck.
Mar 31, 2015 | Fellowes Powershred PS-65C Shredder
CAN THE BLADES ON A FELLOWES 99Ci SHREDDER BE SHARPENED?
I do not believe so. Never heard of sharpening one. The shredding blade is pretty complicated. The manufacturer has a good support web page I suggest contacting them. Keep it clean and oiled and it should last a long time. And do not shred stuff listed on the cannot shred list.
Feb 06, 2015 | Fellowes SB-99Ci Shredder
Motor will go in rerverse but red light comes in foward shred and will not go
I wish the manual said to clean the sensors. I had the whole thing apart. Cleaned her real good. Put it back together. Still a red light indicating a paper jam. I read this post, really helpful! Cleaned the sensors. We are back up and running!
Dec 03, 2013 | Fellowes Powershred 420 Shredder
Need a sensor switch for fellows powershred 220. Won't sense paper.
The top sensors may be bad or even the main board that they are connected to is bad. Try cleaning them with a lightly moistened swab or compressed air. Fellowes will sell you the parts.
Apr 29, 2009 | Fellowes Powershred 220 Shredder
Shrededer motor remains on after shredding is complete
Blow out the sensors with some compressed air.(Computer Duster) they are likely covered in paper dust and the machine believes paper is present.
Please be sure to unplug the machine before attempting any sort of repairs
Hope this is of some help
Ed
Apr 20, 2009 | Fellowes SB-99Ci Shredder
Shredder runs in reverse only can u help?
make sure your paper sensor detector is clean....If so, you probably have a bade sensor...
Mar 30, 2008 | Fellowes P700-2 Shredder
Motor keeps running with the yellow light on and will not shut off.
Jan 16, 2008 | Office Equipment & Supplies
Fellowes P600C-2 Motor runs in reverse, but not forward
On mine a tooth broke from a drive gear. I am trying to find somewhere where I can replace this part.
Oct 25, 2007 | Fellowes P600C-2 Shredder
41 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
