NS-29D310NA15 Model red light is on but will not turn on. Tv purchased in 2014. I was not able to locate a master reset. Tried the unplugged and hold the power button for 45 to 60 seconds.
    Top Expert:
  • Televison & ... Master
  • 75,424 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on May 16, 2017
Need help getting Insignia tv to turn on
Your TV has a failed circuit board, which one will require diagnostic testing. Unless you are skilled in TV repair yes I suggest you replace the TV.
Feb 09, 2017 | Insignia Televison & Video
How can I get a manual for NS-40D510NA15
Insignia has the manuals for most of their products on the product page. Click on the Support/Downloads tab. For the NS-40D510NA15, see http://www.insigniaproducts.com/products/televisions/NS-40D510NA15.html . The direct link to the User's Guide (as a PDF) is http://www.insigniaproducts.com/cms/documents/manuals/NS-40D510NA15_14-1088_WEB_V3_ENG_Final_lr.pdf . There is additional documentation available and there is an HTML version of the user's guide as well.
I hope this helps.
Feb 01, 2016 | Insignia Solutions Original INSIGNIA TV...
Led power light comes on but screen will not come on.
"Blinks a few times" implies the TV is flashing a fault code at you. If you can find a service manual for your model, count the number of blinks and look it up in the diagnostics section.
However, the most likely problem is a burned-out electrolytic capacitor in the power supply. These are usually easy to identify visually; the top of the can-shaped capacitor should be flat, but may be bulged out and may have brown or black material leaking from the vent scores. The photo below shows a bad capacitor to the right of a good one; both have black plastic sleeves.
If this is the case, replacement capacitors are relatively cheap. However, you should look for the following criteria in choosing a new part:
>Capacitance (uF): same as the original, or 10% higher if the original value is not available
>Voltage: same or higher
>Temperature: Maximum temperature should be same or higher
>Physical size: should fit in the space occupied by the original; if buying a taller unit, make sure it will fit when the back cover is reinstalled, and make sure the capacitor will not touch heat generating parts such as heat sinks, resistors or large transistors.
>Ripple current: get the highest available without compromising too much on endurance. Ripple current may be specified in mA or A; 1 A = 1000 mA. Sometimes you can get a better rating by going to a higher voltage part, but physical size may be a limitation.
>Endurance: Try to get 8000 hours or better.
I usually use Panasonic FR1 series capacitors, although United Chemi-Con EKZN capacitors are also worth a look. 25351068-tkog3zu3xmxabptjkcidpctj-1-0.jpeg
Jan 02, 2015 | Insignia Solutions Original INSIGNIA TV...
Only getting red light
Is this when the TV is on or off? If it occurs while the TV is on, is it constant or intermittent?
Try this: Unplug the TV. Hold down the power button on the TV for 30 seconds, while the TV is still unplugged. Then plug in the TV and turn it back on.
Similarly, power cycle the TV: turn it off, unplug it and leave unplugged for a couple minutes. Plug it back in and power it on. Reset settings back to factory defaults. If all else fails, I would recommend pursuing repair/replacement options.
Nov 07, 2013 | Insignia NS-LDVD19Q-10A LCD TV
Insignia TV 24 inches, don't get any image
Try power-cycling your TV (turn it off and unplug for several minutes) and reset to factory defaults via the onscreen menu system (owner's manual can be found here for more details). If these steps don't work, repairs may be necessary. Service can be obtained by carrying the unit in to the place of purchase.
Mar 12, 2010 | Insignia NS-24 TV TV
Locate reset button on insignia ns-ltdvd 19-09, and the reset procedure to follow.
There is not an external reset button on this TV. To reset to factory defaults, enter the onscreen menu system and highlight the OPTION icon using the arrow keys. On the resulting screen, select "Restore Default." I would also recommend power-cycling (turn the TV off and unplug for several minutes) as part of your reset procedure. Additional details can be found in the owner's manual.
Mar 11, 2010 | Insignia NS-LTDVD19-09 LCD TV
The tv will not turn on anymore-have a blinking red light where the power green is located -is a flat screen hdtv connected to an xbox 360, tivo, and cable box. model no. 42PF9431D/37 . The cable is...
internal breaker, hopefully that xbox is plugged into a 3prong ac outlet. unplug the tv from electricity for a half hour and that circuit breaker inside should auto reset.
Dec 15, 2009 | Philips 42PF9431D/37 TV
Televison & Video Logo
Top Televison & Video Experts
