Question about Ryobi Garden
Ryobi RS30 trimmer will not start - no spark. Getting lots of fuel.
    Habit-Forming:
  • 154 Answers
Are you sure there is no spark???? did you store this over the winter with fuel in it???? this uses a cdi ign very reliable...
my guess would fuel no good... clean carb put fresh fuel.... DO NOT USE GAS FROM GAS STATIONS the have ethanol not good for small engine... unless your owner manual say its ok to use.
Posted on May 16, 2017
Ryobi ry64400 will not start?
  • Does it have spark?
  • Does it have compression?
  • Is fuel getting into the cylinder?
    More information required. Thank you
May 23, 2016 | Ryobi 10 in. 30 cc Gas 4-Cycle Cultivator...
My blower will not start
Almost positive the fuel lines are clogged if the gas has ethanol in it. Happened to my Ryobi string trimmer 2 years ago. Replaced the fuel lines from the tank to the carb.
Sep 08, 2014 | Ryobi Garden
I left my gas Ryobi Line Trimmer out in the rain on accident and now it won't start. I pulled the spark plug out and it looked fouled so I replaced it. It's still not starting with the new spark plug. I...
Try removing the fuel, remove the spark plug and give a few pulls to remove starter fluid from the cylinder, once completed attach your spark plug and check spark, reinstall plug, add fresf fuel to the tank and try staring with normal cold start procedure. Does it have good compression?
Sep 27, 2013 | Ryobi Garden
My ryobi cs30 gas trimmer (3 years old) has been difficult to start this year, has been getting worse all year and now wont start. What's up?
Most likely it is the spark plug, but could be a dirty fuel system. I'd start with the spark plug then go from there. you can also use a good quality fuel injector cleaner in your gas to help keep all your small engine carbs clean. If the problem persists there is a fuel filter inside the gas tank that plugs onto the end of the fuel pick up line that could be clogged. Worst case a carb kit can be gotten for them for about $20 bucks. Hope this helps. Please vote yes, thank you.
Nov 01, 2010 | Ryobi Gas Hedge Trimmer
Ryobi 700r trimmer does not start. Changed spark
hve you checked the HT lead and the on/off switch i had the same model as this and i changed everthing but in the end t chucked the thing away and got a sthil modle
Jun 21, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
2 Cycle Gas Trimmer will not start
it is normal to see air bubbles in line when pumping the bulb. to make sure what the problem is, try starting several times, remove spark plug. if dry, yes no fuel, remove the carb. if wet, place plug on engine block and look for blue spark. no spark means you need new plug, plug cord or ignition module
Jul 24, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Ryobi 780 Trimmer No Spark - won't start
Hi
Check the spark at the plug,compression and carburation.Clean the air and the fuel filters.Check the muffler.
best regards savumihai71
Sep 17, 2008 | Garden
Garden Logo
54 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
