Question about Shredder Office Equipment & Supplies
How to reassemble base unit for cordon blu hand crank 5 cone food shredder
2 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: I need the disk adaptor for Black & Decker
You cannot get this part except from Black and Decker and the only way is to get to them.
Get details from the B&D site as follows:
http://www.blackanddeckerappliances.com/
Alternatively you can check on the local stores around if the salvaged part or a whole set is available near your location. But maybe black and decker service shops may have many of them around to help you to be another Happy customer.
So call up their customer service division and you will get a solution.
Please dont forget to rate my advice
Posted on Sep 02, 2010
The rubber material around the paper cone is falling apart,it's decaying. Can it be repaired or replaced?
I assume you speak of the loudspeaker or drive unit which is fitted with a thick gasket material around the edge of the cone where it is bonded to the outer flange of the speaker chassis.
The gasket material and the outer edge of the cone will be clamped when the speaker is mounted to the baffle and screwed down tightly.
The clamping force greatly reinforces the bonding of the cone to the speaker chassis.
The gasket material is important to provide an air-tight seal which is especially important when used in an infinite baffle enclosure.
With extreme care the gasket can be removed and replaced with fibreboard (the traditional material), closed cell foam or cushioned vinyl.
Water based adhesives must be used with care so wetting of the cardboard or paper cone is avoided. The finished gasket should be the same dimensions as the original so it doesn't restrict the travel of the cone and speech coil. A uniform thickness is also important so the chassis is not twisted or distorted when mounted to the baffle board.
It is possible to have a loudspeaker drive unit repaired or overhauled and it might even be possible to obtain spare parts. The process requires much experience. The cost of mass-produced drive units is so low professional repairs are uneconomic and so such a service is only suitable for special, high performance, high quality, hand-built units.
Mar 05, 2016 | Pioneer SW100 Subwoofer
What is the volume of a cone that has a radius of 3.5 and a height of 18.5?
Here is the formula for the volume of a cone. Use it to calculate the volume yourself.
Volume of cone =(1/3)(area of base)*(height)
If the cone is a right circular one
Volume =(1/3)(PI *radius^2)*(height)=(1/3)*Pi*[(3.5)^2]*18.5
assuming that the radius and the height are expressed in the same units. The result (after you calculate it) will be in cubic units.
Sep 30, 2014 | Office Equipment & Supplies
Aurora shreader stopped working
here is a very small micro interlock switch on the bottom left hand corner of the unit. This switch needs to sit securely on a small shelf protrusion that comes out of the base basket. If the switch isn't properly pressed the unit will not operate. If you search the bottom corners you'll see the tiny switch. If you press it the shredder will begin to work again. You just have to reseat the unit into it's original base and the little shelf will press it for you.
Jan 16, 2013 | Aurora Global AS501X-MS Shredder
My schreader was working and just stopped schreaeding . It is not jammed . Do you know what might cause this . How can I fix it ?
There is a very small micro switch on the bottom left hand corner of the unit. This switch needs to sit securely on a mall shelf protrusion that comes out of the base. If the switch isn't properly pressed the unit will not operate. If you search the bottom corners you'll see the tiny switch. If you press it the shredder will begin to work again. You just have to reseat the unit into it's original base and the little shelf will press it for you.
Jul 18, 2011 | Aurora Global AS501X-MS Shredder
Is there somebody speaking french ?
Oui je parle francais, quel est ta question?
Feb 15, 2011 | Office Equipment & Supplies
Safety-rod of bowl does not depress microswitch of Cuisinart processor
Cuisinart does not have the original pieces available, but you can order a replacement work bowl, lid, sleeve, etc that will work from the company. First do a motor test to make sure the motor is still working:
Cuisinart Food Processors – Motor Test
First, do a motor test by removing the work bowl completely and using a pen to press in the grey button on top of the base (with the food processor turned on of course), toward the back. If the processor spins, the motor is still good. At that point, I would inspect the work bowl pieces, lid, pusher assembly, etc for cracks/damage. If all appears well, insert ALL the pieces back into place and try again. If even one piece is out of place, the processor will not spin.
If it no longer spins, the motor has a problem.
-Tha Mp3 Doctor
Oct 20, 2008 | Cuisinart DLC-5 Food Processor
Cusinart little pro plus
I have this food processorfor years and I love it. If you need a copy of the manual go to the Cuisinart website - they have all of the maunals listed there. But, here is the instructinos for the juicer. Good Luck. Using The Juicer
The Citrus Juicer
Attachment includes:
Strainer Basket, which
locks into processor work
bowl. It has grooved cam
on one side and smooth
locking device on opposite
side. In its center is the:
Juicer Stem Adapter,
which fits over motor shaft
of Pro Plus™.
Small cone, for lemons
and limes. It must always
be attached to Adapter
when Attachment is in use.
Slot in center of underside
fits rib on Adapter.
Medium cone, for oranges
and large cone, for grapefruits.
Both fit over small
cone.
1. Place work bowl on Pro
Plus™ base in usual way.
Hold Strainer Basket
open side up, with
locking device facing
you. Align locking device
slightly to left of locking
tab on front rim of work
bowl.
Place strainer basket on
work bowl, fitting Juicer
Stem Adapter loosely
over motor shaft. Turn
basket counterclockwise
as far as it will go, until it
clicks into position.
Turn Juicer Stem
Adapter clockwise until it
drops into position.
Check that it is down as
far as it will go on the
motor shaft.
2. Hold small cone by top
and place it over Juicer
Stem Adapter, fitting slot
over rib on adapter.
Cut citrus fruit in half and
hold cut side down over
cone. With other hand,
hold control lever in
PULSE position and
press down fruit to
extract juice. For continuous
operation, move
control lever to ON. Twist
fruit to extract most juice.
Do not allow juice to
overflow center tube of
work bowl.
To remove attachment,
remove cone from Juicer
Stem Adapter. Loosen
adapter from motor shaft
by lifting it slightly, straight
up. Hold Strainer Basket
on both sides and turn
clockwise to unlock it from
work bowl. Lift straight up.
Remove work bowl from
base and pour out juice.
Feb 03, 2008 | Cuisinart DLC-5 Food Processor
Stuck dough blade
On the DLC 7 Pro cuisinart the blade was removed by removing
the plastic bottom. Make sure the unit is unplugged. Remove the four rubber pads on the bottom. This was the hardest part because the pads are glued so securely that the inner rubber surface tears as it's removed. I used two flat blade screwdrivers and worked carefully, back and forth. Using a #2 philips, remove the four screws. Place the unit on its side and while inserting a screwdriver between a spoke and the motor frame gently turn the blade counter clockwise. Be careful not to put pressure against the cooling fins. Very little pressure was needed and the blade came right out. I might have been able to hold the shaft from turning without removing the bottom, by going through the vent slots in the bottom, but I was concerned with cracking the plastic. To replace the rubber pads I matched the design of the torn rubber pad with the shape (design) of the surface glued rubber and used thin two-sided tape.
Dec 27, 2007 | Cuisinart DLC-5 Food Processor
Sunbeam 2436 not working properly
did you mean model 2346? If you did, I am having same problem
Dec 17, 2007 | Sunbeam Heritage 2346 Stand Mixer
Top Shredder Office Equipment & Supplies Experts
Ross Keen
Dave Reilly
Level 1 Expert
gbob59
Are you a Shredder Office Equipment and Supply Expert? Answer questions, earn points and help others
