Question about Frigidaire Refrigerators
Frigidaire Refrigerator FGHB2844LF1 white plastic with styrofoam piece fell into the icemaker.
A white piece that is 3" x 1.5" x 1/2" and is a molded plastic piece attached to Styrofoam fell into the ice tray. Ice cubes look melted and frozen together in large clumps. How can I fix this? Where does this white piece go?
  • 2651 Answers
SOURCE: Clumps of ice cubes in back of ice bucket
sounds like your just might not be using enough ice and they are defrosting and clumping together.figure your pulling ice from front of bucket the the backs hardly get used espescially in winter your not using as much ice. or ice maker is slightly over flilling water and dripping over rear of unit
Posted on Feb 24, 2008
SOURCE: Ice cubes melting then refreezing in clumps
check the flap door to see if it is slightly open letting warm air in
Posted on Aug 10, 2008
  • 351 Answers
SOURCE: Ge Profile ice maker not working
you either have a bad water valve, which it is sticking open or B. the ice maker is not shutting the valve off.
Posted on Apr 19, 2009
  • 286 Answers
SOURCE: U-Line clear Icemaker clr2160 cube shape
Hi Joe
That is normal. You will get that dimple because the grid is shaped that way. You can try adjusting the thickness. Hold the up arrow then press the down arrow 3 times,then release the up arrow last.You should see a number 0-5 or 0 to -5. when that happens use the up arrow to 3 then press the light key. This should take it back to ice on the display. Wait 24 hours and check the ice.
Posted on May 14, 2009
  • 18 Answers
SOURCE: ice maker not dumping as frequently and cubes freezing one large chunk
The first thing I would check is the cleanliness of the condenser coil under the fridge. Make sure the fan under there is running, and that the coil is clear of dust. The ice maker requires 15 degrees for a period of time before it will make ice and dump. If the temp in the freezer is colder than this, then it is likely the ice maker needs replaced. They can be replaced fairly easily with just a couple tools. (1/4" nut driver and a flat screw driver). There is a plug where it plugs into the freezer side wall, and a bent tube that supplies water to the tray. If not sure what to do, have a service tech look at it.
Posted on May 29, 2009
Ice maker was jammed or not working so I pulled the tray out. Inside the tray was a plastic piece about 3 inches long with a piece of styrofoam on it. Inside the maker there is now a white cord han
Good Morning Friend,
I understand the ice maker was jammed on your Frigidaire refrigerator, model# FGHB2844L. I also see that when you pulled the tray out, there was a 3 inch plastic piece with a piece of styrofoam on it. Now there is a white cord hanging inside the ice maker. I suggest contacting your local authorized technician for further assistance. They will be able to determine what exactly is needed to repair your ice maker. Hope this is helpful.
-Best Regards-
Jun 23, 2014 | Frigidaire FGHB2844L (27.8 cu. ft.) French...
Fghb2844lf1 ice machine is not work
Good Afternoon Friend,
I understand that the ice maker in your Frigidaire refrigerator, model# FGHB2844LF1, is not producing ice. I suggest turning your ice maker off and taking out the ice tray and dumping any ice that is in the tray. Wait 3-4 hours. Dry the tray out and put it back into position. Turn the ice maker back on. It will take anywhere from 2-3 hours for ice to produce. If your refrigerator is still not producing ice, please feel free to reconnect. Hope this is helpful.
-Best Regards-
May 13, 2014 | Frigidaire Refrigerators
Our icemaker drawer was stuck and when we finally got it out a piece had fallen out from above and we can't figure out where it goes. It's about 3" long by 1.25 " wide and made of packing material wit
It should "snap" into the twist tray mold. The white thermistor should be placed below it. A plastic cable tie can be used to hold it in location better. Please unplug the refrigerator while you place it back in position
Mar 23, 2014 | Electrolux EW23BC71I (226 cu ft)...
Have a tube w/rubber end hanging down in ice maker. Also a molded styrofoam w/ plastic loose in ice bin on model#253.70313211 French door bottom freezer. Wher does this belong and how do I fix it.
It fell of the bottom of your ice maker put your model number into and you can find a pic or video that shows you how to put it back together
Mar 02, 2014 | Kenmore Bottom Freezer French Door...
What does the inside of 131763202 look like? I opened to get broken piece of striker out and white piece and spring fell out.
That piece cannot be reassembled. The case is injection molded and the parts are not insertable. If it has failed, chances are that the plastic has shattered somewhere. You can order it online though. I highly recommend
Oct 24, 2013 | Frigidaire ATF6000ES Front Load Washer
Frigidaire gallery dishwasher top arm fell off
Reva Daniel, I have actually had this happen to my Frigidaire Pro Series d/w. We have put some tall stemware in the upper rack and this was blocking the rotation of the top arm it actually unscrewed the nut that holds it on. So here is how I have fixed it.
1. Locate the 3 pieces (the nut), (the arm) and (the white plastic connecting piece). the white piece is very small it will most likely be on the very bottom of the dishwasher.2. The small white plastic piece sits inside of the nut and protrudes through the nut and snaps into the arm.3. take the 3 assembled pieces and tighten back on to the top of the wash tub. be patient when tightening this ,it is easy to cross thread. That is all there is to it. if some of the parts are damaged go to Be sure you have your model # (its on the inside right side just as you open the door.)
Hope this Helps Joe
Nov 22, 2011 | Frigidaire Dishwashers
Experienceing condensation in the refrigerator portion. Cannot locate a leak but always have water on the bottom shelf
The gasket between the fridge and freezer on many of these frigidaire models is made of
styrofoam. It is located under the the cold control assembly. Usually 4 screws holding
this assembly in. Unplug fridge, remove these screws, lower the cold control, clip off wire tie and unplug the control. Slide the assembly out and look closely for
water runs. Sometimes the divider even has water run down the side of it
on the molded in catch/drain cup. Look at the styrofoam (This may also be two types
of foam due to a design change) If it looks corroded and water stained, carefully dry it
with a hair dryer and silicone the mating surfaces which are "V" shaped and reassemble
the unit and allow to dry for a bit. Hard to explain in writing but becomes obvious
when disassembled. Hope this helps.
Jul 04, 2011 | Frigidaire 14.7 Cu. Ft. Top-Mount...
My icemaker works slow to make ice. Sears Kenmore side by side refrigerator. Model.57572791
check temperature in freezer compartment,needs to be near zero,if it is,there may be a problem with the internal thermostat on the icemaker,also checkthat the icemaker mold is filling completely with water,all the cavities should fill
Jan 22, 2010 | Frigidaire FRS26H5AS Side by Side...
No power going to water solinoid that services ice maker
you will only get power there briefly when the icemaker nears the end of its can initiate the cycle on this icemaker by rotating the fingers in the mold manualy you should get power at solenoid for 3-5 secnds as the icemaker nears the end of cycle if not the swich is part of the icemaker and should be serviced by qualified technician
Jan 17, 2010 | Frigidaire FRS23R4A Side by Side...
Wires hanging in ice maker area
Look underneath the 2nd row from left in the ice tray there should be a white plastic piece that pops in and out from the bottom of the ice tray. Pop it off. There should be a piece of styrofoam on top of the piece you removed. the white wire runs along the bottom of the ice tray there may be little plastic hooks to place wire along the way. The sensor should fit right where the white piece of plastic and styrofoam you removed goes. Just place it there and pop that piece back in. It really doesn't attach to anything just lays there.
May 26, 2009 | LG LSC26905TT Side by Side Refrigerator
Refrigerators Logo
57 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
