Question about The Office Equipment & Supplies
How to put the base together for cordon blue hand crank 5 cone shredder
2 Suggested Answers
  • 7 Answers
SOURCE: cone leaks dont suond good in eny box porly pot together
go with earthqakes if you can still find them cheap but can take a *** whipping.
Posted on Apr 20, 2010
Is it true that even though you have a crisscross paper shredder there are devices that can put all those piece back together?
no there isn't anything that can put the paper back together, if you are worryed about that then tear the paper in piece and then shred
Jan 07, 2016 | Industrial Paper Shredders Office...
Paper has filled up the spaces between the gears in some spots so that even one sheet of paper does not shred - it just gets holes poked in it. I have tried the usual needle nose pliers to pick out t
I just had mine apart yesterday to clean the paper sensor and remove some paper that fed the wrong way. First unplug the unit. Tools needed Philips screw driver and needle nose. Remove the paper bin and put the shredder on its back then remove 4 screws that hold the base cabinet to the top.Once you have the top off put the top upside down on the floor / table. There are 6 screws that hold the top together. Be careful of the wires for the bin full and bin in place sensors that connect between the bottom and top half's. You can gently lift the bottom up and swing it away to access the cutters. From here you should be able to clean most of the paper. The cutter assembly isn't screwed in but has some wires that will have to be removed if you need to remove the cutter assembly. Also there is lots of grease on the cutter assembly so be careful of where you touch.
Feb 11, 2014 | Royal 160MX Shredder
I have an Achiever CCS5000 shredder. On the base that holds the shedder part the safety post that must be up to run is broken. I need the part to fix. Where can I buy this part?
I also have one that i use off of the base. You can take the top off, 6 screws, make sure it is unplugged and locate the safety switch, cut the 2 wires & twist them together then use electrical tape to secure & insulate them. that will take care of the problem.
Feb 07, 2011 | Achiever CCS5000 Shredder
Cone leaks dont suond good in eny box porly pot together
Apr 19, 2010 | Lanzar VW12D Car Subwoofer
Our Achiever CCS5000 worked well until it was
Hi Alan,'
it is not available, you could find the interlock switch and jump them...cut wires off of switch and twist together, then use electrical tape.
Mar 03, 2010 | Achiever CCS5000 Shredder
Our tv is magnitized by our surround sound base speaker what can we do.
Hello. Here are the steps:
1.put your hands in the form like you would if you are about rub your hands together for warmth
2.Put the magnet between both hands at the palm areas
3.rub your hands together and turn the magnet so that the north and south ends magnetize the TV simultaneously
4.make sure you know where the north and south ends are located on the magnet
5.Hint - The Constant switching between the north and south polarizations causes the magnet to equalize the magnetized areas on the TV returning it to it's original color!
Regards, Joe
PS kindly rate my answer. thank you.
Jan 24, 2010 | Quasar SP-3235 32" TV
I can't get my Royal SC800 apart. I removed the 5 screws but something is holding it together still.
There should be 6 screws to remove to release the top cover...2 at each end left and right hand sides and 2 more or less towards the middle.
Jan 09, 2010 | Royal JS800 Shredder
I have a Fellows Powershred ps 60cc and removed the shredder top to empty the shredded documents. When I put it back on, the red light will not go out and it will no longer work. It was working perfectly...
the shredder has a safety switch that closes when the unit is put back on the basket. check under the cutter head for the hole that has the switch and check your basket for the acuator put together so they will line up
Nov 03, 2009 | Fellowes Powershred PS-60 Shredder
Hoover mach 3 cyclone vacuum shut off during useage. can't turn it on. cleaned it out and let it sit thinking overheated? this is 2 months old. help?
I had same problem. Turned out to be the filter that sits above the waste cannister. Remove the waste cannister. There is a little orange lever that releases the filter. It was caked with dirt not allowing any air flow causing the motor to overheat.
This foam filter gets dirty pretty fast.
Jul 12, 2008 | Vacuums
ALESIS M1 ACTIVE MK2 CONE VIBRATION!
Hello!
my speaker Alessis M1 Active 620, with a roar is very strong in the speaker, the potentiometer does not attenuate, change the volume. Ja switched capacitor C8, based on my research of other users, but got no result. When you press the power button, the LED lights in blue, and even change the color to red, producing a noise (snoring) very strong.
help!
Please help me!
Mar 17, 2008 | Alesis M1-Active-MK2 Powered Studio...
23 people viewed this question
Top The Office Equipment & Supplies Experts
thetraveler
Level 1 Expert
Folusho Adeyanju
Folusho Adeyanju
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
