Question about Shredder Office Equipment & Supplies
How to repair base for 5 cone hand crank shredder
2 Suggested Answers
pastorey
  • 47 Answers
SOURCE: MTX Thunder7500 T7512-04 needs repair
can try to repair it is it around the outside rim ?? use SILOCONE to repair it as it will flex when used DO NOT USE SUPERGLUE
Posted on Sep 05, 2009
The rubber material around the paper cone is falling apart,it's decaying. Can it be repaired or replaced?
I assume you speak of the loudspeaker or drive unit which is fitted with a thick gasket material around the edge of the cone where it is bonded to the outer flange of the speaker chassis.
The gasket material and the outer edge of the cone will be clamped when the speaker is mounted to the baffle and screwed down tightly.
The clamping force greatly reinforces the bonding of the cone to the speaker chassis.
The gasket material is important to provide an air-tight seal which is especially important when used in an infinite baffle enclosure.
With extreme care the gasket can be removed and replaced with fibreboard (the traditional material), closed cell foam or cushioned vinyl.
Water based adhesives must be used with care so wetting of the cardboard or paper cone is avoided. The finished gasket should be the same dimensions as the original so it doesn't restrict the travel of the cone and speech coil. A uniform thickness is also important so the chassis is not twisted or distorted when mounted to the baffle board.
It is possible to have a loudspeaker drive unit repaired or overhauled and it might even be possible to obtain spare parts. The process requires much experience. The cost of mass-produced drive units is so low professional repairs are uneconomic and so such a service is only suitable for special, high performance, high quality, hand-built units.
Mar 05, 2016 | Pioneer SW100 Subwoofer
Where do I get replacement gear for the shredder?
try a appliance repair shop for a supply agent for parts
office supply shops that sell shredders may be able to give you the names of repair agents
if it is more than 5 years old then junk it and get a new one as the cutter rollers will be blunt and probably the reason the plastic gear failed
Jun 19, 2015 | Tech Solution TS-6000 Shredder
How do I get my hands on a technical repair manual for a Dahle 20606EC shredder with all the specs, part #'s, troubleshooting, etc..
Good luck with that! Getting tech repair manuals is like finding gold. Call Dahle and they may sale you one. Otherwise just open the unit up, find what the issue is and then call them. Dahle's are phenomenal units and virtually never break down. What is the problem? If you're simply trying to pre-empt an issue then I say don't worry about it.
Feb 13, 2015 | Dahle Office Equipment & Supplies
2008 touring rear axle torgue spec
Holding weld nut on left side of axle, proceed as follows:
a. Tighten cone nut to 95-105 ft-lbs (128.8-142.4 Nm).
b. Loosen cone nut one full turn.
c. Retighten cone nut to above specification.
NOTE
If the axle moves during tightening of the cone nut, then the
belt deflection procedure must be restarted.
Recheck belt deflection to verify that it is still within specification.
If the belt deflection is not within specification,
loosen cone nut and then snug to 15-20 ft-lbs (20-27 Nm).
Recheck belt deflection. Apply 10 lbs. (4.5 kg) of force at
the midpoint of the bottom belt strand. Belt deflection
should be within the range specified. If belt
is still not within specified range, readjust accordingly.
FLHT/C/U - FLTR - FLHR/C 3/8-7/16" or 9.5-11.1 mm
FLHX 1/4-5/16" or 6.4-7.9 mm
Jul 03, 2014 | 2008 Harley Davidson Street Glide Base
I used WD-40 just once. How can I know if I damaged it completely?
WD-40 probably hasn't killed it, most of it will evaporate in time. It can cause the shredder to get gummed up with little paper particles so you might need to clean it out with some compressed air. I wouldn't use any sprays on a shredder unless Fellowes recommends it.
Apr 16, 2014 | Fellowes DM12C Shredder
Aurora shreader stopped working
here is a very small micro interlock switch on the bottom left hand corner of the unit. This switch needs to sit securely on a small shelf protrusion that comes out of the base basket. If the switch isn't properly pressed the unit will not operate. If you search the bottom corners you'll see the tiny switch. If you press it the shredder will begin to work again. You just have to reseat the unit into it's original base and the little shelf will press it for you.
Jan 16, 2013 | Aurora Global AS501X-MS Shredder
My schreader was working and just stopped schreaeding . It is not jammed . Do you know what might cause this . How can I fix it ?
There is a very small micro switch on the bottom left hand corner of the unit. This switch needs to sit securely on a mall shelf protrusion that comes out of the base. If the switch isn't properly pressed the unit will not operate. If you search the bottom corners you'll see the tiny switch. If you press it the shredder will begin to work again. You just have to reseat the unit into it's original base and the little shelf will press it for you.
Jul 18, 2011 | Aurora Global AS501X-MS Shredder
Hi, I am looking for a replacement bass cone for a pair of Tannoy 611's mk1's. I had them from new in the early 90's but a few years back, my son picked out all of the foam that joins the plastic cone to...
If you found second hand 605s you can swap entire sub speaker. Your other option is check your local yellow pages for a pro audio repair shop that does re-coning. Re-coning is a specialty operation and it's not a procedure for the novice. You can also check online for re-coning services.
Jan 06, 2011 | Audio Players & Recorders
NEED TO RETURN TS4500..WIRE AT BASE OF SHREDDER BOX IS FRAYED AND MAY CAUSE ELECTRICAL SHOCK. HOW DO I GET IN TOUCH WITH THEM?
Your local handyman can probably fix the wire for you a lot cheaper than shipping it plus repairs.
Jul 12, 2009 | Tech Solution TS-4500 Shredder
21 people viewed this question
Top Shredder Office Equipment & Supplies Experts
Ross Keen
Dave Reilly
Level 1 Expert
gbob59
Are you a Shredder Office Equipment and Supply Expert? Answer questions, earn points and help others
