Question about Garden
Disconnect reverse kill switch or modify
Craftsmen roper made 4218.(917)
2 Suggested Answers
  • 48269 Answers
SOURCE: Craftsmen safety switches
iot is a safety switch so modification or bypass is not a good idea
better to replace the switch or fix the wires or adjust it properly
Posted on May 15, 2017
May 15, 2017 | Cars & Trucks
Hi I have a 12hp roper lawn tractor it won't go in gear
All of these machines have safety switches all over; try to disconnect the cutting blades.
Jul 14, 2015 | Garden
How to replace a dryer switch Roper
Hi J L B , I could help you with that . With a Phillip screwdriver remove two screws under the lint screen , next remove the two screws on both sides of the door switch . Now pull the top panel towed you and lift . Finally disconnect the old door switch and replace it . Good Luck APPLIANCES R EN
Apr 28, 2014 | Roper RGX4634KQ Gas Dryer
Timer clicks on dryer but want work
A lot of times the small white fuse will melt and kill the door switch circuit on these.
I removed a bunch of junk from this one's blower housing/filter chute:
So if your door switch is fine check the thermal limit:
Ya might want to give that Roper dryer a good going over. I did a complete overhaul of a Roper dryer and took some photo's for DIY folks: Roper dryer tuneup
Nov 02, 2011 | Roper REX4634KQ Electric Dryer
How can I disconnect the kill switch fuse on my 2002 envoy
What "kill switch fuse" are you talking about? There is no kill switch on the Envoy.
Jul 30, 2011 | 2002 GMC Envoy
No spark
Eigther the kill switch failed or ignition module. Disconnect wire to kill switch if you get spark then switch is bad. Still no spark with kill wire disconnected ignition module quit.
Sep 29, 2010 | Mtd Garden
I am trying to install a new igniter, but cannot find an access. What do I do. Roper Gas Dryer Model #RGX4625E111. Thank you
moz-screenshot-2.pngmoz-screenshot-3.pngDisconnect power then pull the lint trap out and remove the screws under it.
Pry the top cover
on both sides as shown then raise it to the rear of the dryer.
Disconnect the door switch harness and remove the screws attaching the top of the front panel to the cabinet then lift and remove the panel. You now have access to the igniter.
Sep 10, 2010 | Roper Dryers
Will not start after going dead
Sounds funny but have you tried checking the oil. Most of the newer model small engines have a oil shut off switch that kills the engine if it runs low on lube. Also try looking around behind the control panel I know that my craftsmen mower has a inline fuse on one of the hot wires that run to the engine elctrical and when it blows absolutely nothing will happen. You may also check the seat safety switch witch kills the mower if you stand up. Not recommend you run it this way but you can test it by lifting up the seat and unplugging the switch and putting a jumper wire across the body harness connecter. Again this is just a test procedure the switch is there for the protection of the operator and if faulty I highly recommend replacing the switch.
Jul 21, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Something is inside the gears of the machine
ok llangis,,ready always unplug first,,good,,,now look at the front console you see a screw in each corner,,phillps head,,remove them now flip the console back and just let it hang backward,,,now your looking at that white connector thats your lid switch..disconnect it ,it has two gray wires and a green on one side,,and the other side has brown wire with whit tracer at booth ends of the cabinet you see a brass clip take screw driver and pry just pull cabnit only, to your in,,,reverse to put together,,,onthejob
Jan 06, 2009 | Roper RAS6233KQ Top Load Washer
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
