My washing machine finished its cycle in the evening the next day it would not turn on.
SOURCE: washing machine not working
I just had the same problem. In my case, a pen cap was stuck in the impeller of the drain pump and prevented it from working. To access the drain pump remove the lower kick panel on the washer by removing (3) Torx drive screws. Make sure you get the water out of your tub before working on the pump or it will spill out on the floor. The pump is front & center. First check the clean-out filter for blockage by turning the big knob on the front of the pump. If that doesn't appear to be the problem, you can take the pump out by removing (1) screw and disconnecting (2) hoses and the electrical connector. The pump itself consists a white housing and a black motor assembly. Remove the motor assembly by removing (3) screws. This is where you will see the impeller and and item that may be preventing it from turning. Besides dealing with the water, the most difficult part of repair is reconnecting the hoses using the hose clamps. Best of luck! RDam
Posted on Jun 29, 2007
  • 3 Answers
SOURCE: fisher paykal top load washing machine
I had the same problem. I unplugged the machine for a while (overnight) and it then worked properly when I plugged it back in. Probably just a circuit board issue that was cleared with the power removed.
Posted on Oct 14, 2007
aborcass
  • 2651 Answers
SOURCE: KitchenAid Washing machine stops mid-cycle and stays stopped
sounds like you need to replace your lid switch asssy part number 285671, unit not recognizing the door closed so for safetyreasons stops after first rinse and wont drain/spin. your tripping the switch by bangin on it
Posted on May 12, 2008
ginko
  • 19396 Answers
SOURCE: I have the hotpoint BWM129 super silent 1200 spin,
The flashing lights means that an error had been detected.
The machine must be unplugged from main to check the drain hose and the drain pump.
The most common is that the drain pump is clogged with debris and must be unlocked.
Posted on Feb 18, 2009
SOURCE: washing machine fault
im having the problem now with my daewoo that every time i put a wash on its giving me a H6 message error
Posted on Dec 17, 2009
My washer will not switch from one cycle to the next
I understand that your washer is not advancing and stuck on one cycle. If you provide a Model and serial number, it will be helpful.
Jul 22, 2016 | Washing Machines
Washing machine water not draining even finished the whole cycle? ANYONE have same problem? please help, thanks
I have had this when over filled my washer, repeat spin cycle several times and eventually the water will be goneso the door will open. Note turn power off if the cycle is set by rotating dialor more water may go into machine
Oct 15, 2015 | Washing Machines
Bosch classixx 1400 express
have you cleared the filter
Feb 03, 2014 | Washing Machines
Indesit Evolution W16s washing machine H20 error code
if there a advance cycle button push it an see if the timer will advance to spin if not turn the power off to washer an wait a couple mintue an the door will open
Apr 24, 2010 | Washing Machines
Leaves white marks on coloured clothes
I'd try putting the machine on a hot fill wash, max water level put in half a cup of baking soda when the machine starts to washer turn it off and leave it to soak overnight, then let it finish the cycle the next day. Also make sure you tip some of the hot water down the beach dispenser and clean all around the top of the machine
Cheers
Mar 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
LWH0050P Stackable Compact Washer not spinning
sounds like it could be the transmission. Does the tub turn when you turn the pulley in either direction with your hand? And take the belt off see if the motor turns when you close the lid and turn it on without the belt??
Aug 30, 2008 | Washing Machines
Fisher and Paykal GWL 10 US - Stops before rinse
52. (00110100) Eco - Diverter Top-up Fault diverter valve made be stuck in half open position ,may be a mechanical obstuction or the wax filled solenoid that actuates it may be faulty .located under machine beside pump .
Jun 17, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
