Channel selector will not work remote or on the side
3 Suggested Answers
  • 51 Answers
SOURCE: up and down channel selector wont work on remote for Toshiba MD 13Q41.Remote is identified as CD-SB1
this is usually caused by dirty contacts due to prolonged use, basically oils from your fingers caked up beneath buttons
Posted on Aug 06, 2008
SD Tech
  • 14553 Answers
SOURCE: channel selector doesn't work
If only 1 button does not work it may be a problem where some liquid got inside--
Some units have a lockout feature which will disable most or all buttons on the remote and or the set.
If set changes channels with the buttons on the set problem is with the remote--they can be tested easily.
Posted on Apr 16, 2012
Ive doesnt know to change the channel of toshiba regza for cable because its japanese
Program remote to code 061, then see if the channel selector is working.
Aug 13, 2013 | Televison & Video
Channel selector doesn't work
Apr 15, 2012 | Samsung Bn59-00996a Remote Control
I can't move the channel selector on the remote up or down. I can depress the control but nothing happens. I can key in the channel number OK but to change channels I have to key in another number. The...
when I press any buttons on remote control cant move the channel and there is a message showing on tv screen "the operation with remote control is prohibited
Feb 23, 2011 | Sharp RRMCG1687PESA Remote Control
We have two gyros S107G remote control helicopters. the instructions say to "set the band selector on the transmitter and helicopter to the same frequency." the switch on the transmitter is...
Had the exact same problem. Found the solution on an Amazon posting:
1. To enable this function make sure both remotes and both helicopters are off.
2. Set the first remote's channel switch to the leftmost position (it says A, B, and C, but the s107 only supports 2 channels). Turn the remote on.?
3. Turn the helicopter that you would like to bind to the remote on and set the helicopter down on a flat stable surface for about 5 seconds. Try the throttle and the helicopter should respond to this remote.?
4. Next, to enable the second helicopter, set the second remote's channel switch to the rightmost position (it says A, B, and C, but the S107 only supports 2 channels). Turn the remote on.?
5. Turn the second helicopter on and set the helicopter down on a flat stable surface for about 5 seconds. Try the throttle and the second helicopter should respond to this remote.?
This worked for us.
Dec 25, 2010 | Air Hogs Havoc Heli Helicopters
My remote control's input select button wont work.....how do i do it manually?
Not sure about this particular TV, but usually, you select inputs by channel selector. Go to Channel 1 on TV not Cable or dish, Use the channel selector button on the set itself, go down from 1. You should see somthing like Aux or Line, then aux 2 or Line 2 etc.. eventually (3 clicks or so) rolling around to ch 115. But usually between the highest ch on the set and ch 1 are the auxillary input selections.
Nov 11, 2010 | Emerson EWF2004 20" TV
Need channel selector for durabrand tv model #dwt1304
Do you mean the remote? Try remotes.com:
http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=dwt1304&uuid=12726469932350
Pick your model and you'll find a substitute remote that will work for most of your TV's features.
I hope this helps.
Apr 30, 2010 | Televison & Video
Quasar model VV2008 tv/vcr
in side the mother board(kit)  there should be vertical IC gone.   check the vertical section  for  the IC number  and  replace it  ,     this  will solve ur problem
thanks
Oct 26, 2008 | Quasar VV2009 Combo
Up and down channel selector wont work on remote for Toshiba MD 13Q41.Remote is identified as CD-SB1
Aug 06, 2008 | Televison & Video
Cannot locate an input selector to change from cable to a recorder
Try selecting channel 00 enter on remote.....I am assuming
you are missing the original GE remote that has an input button
on it ............? Let me know.........T.
Dec 22, 2007 | GE 31GT659 31" TV
Ghost in the channel selector
the problems due to the microprocessor on the remote reciever present inside the tv .i think the remote is normal working. as the only problem with your iinfra red reciever microprocessor.microcontroler circuit. Replace the IC to solve this. Check electrolytic capacitor coupled to the memory block of the micro processor. Contact service if you are not well verse doing all this rectification works. it is off high risk and caution
thank you !
Nov 17, 2007 | RCA F36650 36" TV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
