Question about The Health & Beauty
Hi,i have a Z1000 and when I turn the ignition key the digital display starts up then after a few seconds cuts out again.
I thought it was a battery issue but its a new gel sealed battery (2 months old) plus when I connect the battery it sparks of the screw driver (which I thought was a sign of a healthy battery.) do you have any more ideas? before I go an purchase a new battery?
    Top Expert:
  • The Master
  • 45,620 Answers
The battery will be under warranty ( 2months old )
take it in for a load test to determine it it is the battery
could be a bad ground point or wiring problem
Posted on May 15, 2017
How do I reset my service engine light on a 2000 mitsubishi galant
  • Turn the ignition key to the "ON" position without starting the engine.
  • 2 Press the button to the left of the display on the instrument panel twice within one second. The oil life status will be displayed on the panel -- this should be past the mileage due for the service interval if the wrench icon is illuminated
  • 3 Turn the ignition key to the "OFF" position within 10 seconds of the status display.
  • 4 Press and hold the button to the left of the display again with one hand while turning the ignition key back to the "ON" position without starting the engine. The oil life status will show once again
  • 5 Continue to hold down the button for a few seconds longer, and then release it. Wait 10 seconds until a chime indicates and displays 6,000 miles for at least another 10 seconds.
  • Aug 16, 2016 | Mitsubishi Cars & Trucks
    This is about to be rather lengthy, so I apologize in advance. I traded for a 98 Firebird on April 19th. Already broke down. The problem doesn't lie within the engine or transmission however. What...
    Sounds like the electrical part of the ignition switch, not the lock cylinder that needs replacing.
    Possible also that cutting that wire to the security module immobilized it.
    May 09, 2013 | Cars & Trucks
    Hi there this is Riaan again .My Isuzu 250 start every time but only run for 3 seconds and then engine stops.I thought that it was the immobilizer that cuts the diesel but i have already changed the unit...
    is your key a programed key you might check sometimes if you are useing just a door key thats not programed to the ignition it will start but not stay running
    Jan 03, 2013 | Isuzu Vehicle Parts & Accessories
    I ahve a 2002 BMW F650GS - a couple of months ago it cut out for no reason. Then a few weeks later when I used the heated handgrips it 'died' again. I turned it off compeltely then restarted and it went...
    Hi, Barbaraten13 and the usual suspects are:
    1. Ignition Switch not in the "ON" position.
    2. Engine Run Switch in the "OFF" position.
    3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
    4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
    5. Security alarm needs a reset.
    6. Starter control circuit, relay, or solenoid faulty.
    7. Faulty starter button.
    8. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
    For more information about your issue, please visit the websites below. Good luck and have nice a day.
    Thread 2001 F650GS won start please help
    F650 Community
    2001 2005 BMW F650CS Service Manual Moto Data Project
    BMW Motorcycle Parts Fiche OEM BMW Motorcycle Parts online 1970 present BMW
    Free Rider Manual Download BMW F650GS Twin
    May 04, 2011 | 2001 BMW F 650 GS
    After starting for a few seconds it will shut down and will not start until i turns off key and turn on again. it seems live it loses spark. it also happened a few time when i accelerate fast from start...
    check your ignition key,,,it may be the alarm cutting the motor off if you have another key near the main one,,,my honda is just like this one is? only keep the bike keys on the key ring,
    Oct 17, 2010 | 2006 Yamaha Road Star
    Keeps cutting off after restart
    SINCE CAR WONT CRANK. NOW IS THE TIME TO REPLACE THE IGNITION SWITCH KEY LOCK CYLINDER ITS BROKEN THAT WHY THE CAR KEYS WOULDNT TURN OFF CAR.DISCONNECTING BATTERY CABLES WITH CAR RUNNIMG WILL.SHORT OUT ALTERNATOR AND PCM.IF IN CASE YOU HAD TO REMOVE BATTERY CABLE REMOVE THE GROUND NEGATIVE CABLE FIRST.MAKE SURE ALL ELECTRICAL COMPONENTS OFF LIKE RADIO. AC SYSTEM OFF.THIS WILL PREVENT LARGE ELECTRICAL ARC FROM BATTERY THIS IS ONE TIME PROCEDURE IN CASE ENGINE WONT SHUT OFF ITS A GAMBLE BECAUSE IT WILL TAKE OUT ALTERNATOR AND PCM.REPLACE THE SWITCH AND KEY LOCK CYLINDER DONT KEEP STARTING CAR BY DISCONNECTING THE BATTERY CABLE YOU WILL DAMAGE IGNITION ELECTRICAL SYSTEM.
    Jul 31, 2010 | 1997 Oldsmobile Achieva
    Yamaha xt 125 battery problem
    RC = ReCharge, either the battery is bad, or drain, but both can be caused by a continuous short circuit on the bike's coil and the body / battery.
    Oct 09, 2009 | 2005 Yamaha XT 125 X
    Flat battery caused immobiliser problems
    1-insert and remove key from ignition two times
    2-close and open driver door two times
    3-insert and remove key once from ign.
    4-close and open drvr door twice
    5-insert key into ign.,then close driver door
    6-turn key to on (not start) then off, twice this is rewrite mode,have all remotes to reprogram it will clear any lost remotes.
    7-remove key from ignition,the door locks should cycle twice.if not start over.it may take a few tries.
    8-press lock/unlock together and hold for a second
    9-release,and press lock on remote,the door locks will cycle confirming program.continue to do other remotes you have,steps 8 and 9.if only one in possession,you are done. To end mode open door or insert key into ignition.
    You'll need to follow the steps with no more than a 1-2 second delay between each step.. hope it works
    Aug 10, 2009 | Renault Sport Cars & Trucks
    1999 malibu, engine turns, won't start, guages not
    You checked all fuses? Dis-connect positive battery lead for a few seconds and reconnect. Do you have spark & fuel?
    Aug 09, 2009 | 1999 Chevrolet Malibu
    Hyundai Tiburon Won't Start
    Possibly the alarm cut-off switch? or Ignition key switch (or wires) going bad?
    But you mentioned you tried to jump start it and it did turn over?
    IF so, you could have severe corrosion or loose connections of the battery cable both at the battery and at the termination points, such as ground and starter motor.
    Check that the battery wires are tight and clean at the battery posts and at the other end.
    Again the No lights suggests either the alarm cut-off, or an absolute disconnected battery cable.
    Finally, it could be ignition fuse, Check fuses. Ignition key switch.
    What makes this hard is that you suggest it would turn over with another battery connected. This makes no sense.
    Good luck
    Mar 16, 2009 | Hyundai Motor 2000 Tiburon
    Health & Beauty Logo
    26 people viewed this question
    Top The Health & Beauty Experts
    Motshidisimary
    Motshidisimary
    Level 1 Expert
    Stacy Harrison
    Stacy Harrison
    Level 1 Expert
    Dave Jacobs
    Dave Jacobs
    Level 1 Expert
    Are you a The Health and Beauty Expert? Answer questions, earn points and help others
