Question about Samsung Washing Machines
Samsung washer wf210anw/xaa display panel does not light thanks wid
2 Suggested Answers
rickead1
  • 1998 Answers
SOURCE: samsung dryer dv317aeg/xaa has code on display
http://www.washingmachinereviews.org.uk/fault-codes/errors-and-solutions/ use this site try this solution is what the company suggests simply folo down the list till u see your error code with there solution if this does not work u willhave t call a tech to do test on your heater as well as the wiring going to the heater
Posted on Jul 26, 2010
Water leak at front left corner of our Samsung WF210ANW/XAA01 front load washer
You will need to order and replace the door seal, also verify the door is not loose due to worn hinges. Go to www.applienceparts.com for parts if you like.
Oct 26, 2016 | Samsung WF210ANW 3.5 cu. ft. front load...
I need to fix my front load washer
drums don't get loose, their bearings wear out. if it is old most likely it is toast, if newer then may be worth repair
Nov 21, 2014 | Samsung Main Board Washer Dc92-00301e...
Need WF210ANW Samsung Service Mode Entry Codes
i tried to open the door during cycle, now locked and wont open. how do i get it to release?
Apr 15, 2013 | Samsung WF210ANW Front Load Washer
I have samsung and it displays l5
If it is E2 15 then it may be a switch error (Main Relay error) Check for stuck button switches or power button switch for sticking. May need to replace the main PBA. Verify the error and provide the model number to verify the error code specific to your model.
Aug 28, 2012 | Samsung WF210ANW 3.5 Cu. Ft. White Front...
What does ds mean on Samsung high efficiency washing machine
A dS code means that the door was opened during the cycle. (At least this is true for the WF210ANW/XAA washer.) Close the door tightly and restart the wash cycle.
If the error persists, you probably have a problem with the door latch.
Samsung has the manual and trouble-shooting FAQs for many of their appliances here: http://www.samsung.com/us/support/ . Click on Washers & Dryers (in the rightmost column) then use the drop-down menus to select Washers and then the model.
I hope this helps. Please add a comment with the model of your washer for additional assistance.
Mar 20, 2012 | Samsung Washing Machines
Washing Machines Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
