Question about Mongoose Cycling
I need a owner'sed manual for this model
MONGOOSE MGX/dxr Owner's manual Bike# r4502wmoto9sl5jb
3 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: I need a chain for
Look around for a 7-speed chain. Special tools are involved for 'cutting' it to size so why not just establish a relationship with your Local Bike Shop now?
http://www.parktool.com/blog/repair-help/categories/chain-repair-and-service
If it's really worn you'll probably also need to replace the cogs and possibly the chainrings. Old drive train parts don't mesh well with new ones.
Use the web to answer common questions.
http://sheldonbrown.com/chains.html
Posted on Sep 20, 2011
  • 1145 Answers
SOURCE: Where can you find Mongoose replacement parts for MGX DXR full suspension bike? I need a matched crank set and pedal replacements.
The crankset and pedals on that bike or any other are not unique to one model. Either the original or compatible replacements are available at a variety of sources, but there are several dimensions that are important. Best to go to a bike shop or bike co-op to get info on what is needed and available.
Posted on Jul 11, 2016
Mongoose MGX DXR crank set replacement. How to determine what to buy online?
How about just go to the source (manufacturer)?
Mongoose Contact Us They may be able to give you the required specs, and perhaps sources. That being said, from pics I pulled up it appears to use a cartridge type bottom bracket (would need to know proper spindle length) probably a "square taper" type, and you would also need to specify crank length. Pedals are standard 9/16" - whatever style you want.
Depending on how much is missing (cranks, bottom bracket and pedals?) this could end up costing you quite a bit, so I hope you paid very little for the bike, which sold for less than $200 new, worth well under $100 used in rideable condition.
Jul 13, 2016 | Mongoose Cycling
Jul 11, 2016 | Mongoose Cycling
How can i get a mongoose mgx dxr manual?
Mongoose is made by Pacific bicycle. try mongoose. com or pacific bicycles.com
Aug 15, 2014 | Cycling
Can i stiffen up the tension in my front forks on my mgx dxr?
Sorry to inform you, but there is no adjustments available for the forks that come with your bike. Adjustable forks (just the fork) start in around $250-.
On the positive side since there is not adjustment capability the fork does not need regular servicing like the adjustable forks.
Dec 01, 2010 | Mongoose MGX Maxim Dual Suspension...
Forks
There are a wealth of online stores; search bike stores on Google.
Sep 03, 2009 | Mongoose MGX Maxim Dual Suspension...
I HAVE A MGX MOUNTAIN BIKE. WERE THE PEDAL ARE
im certain that model has a 3 piece crank set up. the inner crank bearing jam nut has loosened up or the bearings themselves have gone bad.first check to see if its tight, if it is then it will require a replacement set of bearing that are a pretty standard size to all bikes and can be purchased at nearly every bike shop.
Jul 08, 2009 | Mongoose MGX Maxim Dual Suspension...
Cycling Logo
43 people viewed this question
Top Mongoose Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
Rommel Balcita
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
