Question about Haier 3.6 cu. ft. / 102 liter Chest Freezer HCM036PB
Any possibility you can help troubleshoot a larger upright freezer? Our freezer is 3 years old. It sounds like it is working -- I can feel cold air and hear it humming, but as of yesterday it stopped freezing the food. Everything has thawed. Thanks, Arthur
  • 744 Answers
Assuming the thermostat is set to call for cooling (sometimes they get bumped), check the condenser coils, fan, etc for debris build up and clean as needed.
Is the freezer frost free? If so, it's possible the defrost timer is stuck in defrost. There should either be a mechanical timer or it could be electronic these days. Check for bad connections or any obvious signs of damage (burn marks)
Make sure the freezer door closes tightly
Posted on Jul 25, 2009
20.3 cu. ft. Upright Freezer GLFU2067F: We have an upright frigidaire 20 cu feet that is a...
Sounds like frost bulidup from door being left open warm air gets in making frost and ice. Need to turn off for 24hrs or so to let all the ice melt compleatey then turn back on keep door closed run for 24hrs check Temp. shoud be about 0 to -5 Deg. if good start using.
May 17, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
I have a maytag upright freezer. It is on the coldest setting. A bowl of water on the bottom shelf freezes overnight. The middle one is freezing, but not entirely. The top one is still water, but cold....
check to make sure door seals are touching the frame all round, could be an air leak,also make sure there is no ice build up around the inside casing. if so fully defrost unit,clean all vents/drain pipe, then turn back on and leave it for 24hrs (freezers work beast when full).....and door shut..how many times have you closed door after them????
Mar 01, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
My wife called me home to a thawing freezer.The outside stuff was thawed and the temp was 40 inside.The sides were hot on the freezer and it is a 20 cubic foot upright that is 12 years old. have not had...
Check the fan down by the compressor to see if it's working . If not , it needs to be replaced .Also check the coils to make sure they are clean of dust , lint , etc... Is the fan inside the freezer working ? The hot sides are good . This means the compressor is working ( the " freon " attracts the heat inside the freezer , pulling it out , to make the freezer cold . The air flow over the sides , help dissapate the heat ) . Without the model number , I cant look up to see how the freezer is made .
Aug 20, 2009 | GE 203 cu. ft. General Electric Upright...
Freezer gets cold but doesn't freeze
check tem.p inside cabinet and let us know what you find
Jun 29, 2009 | GE Freezers
Frigidaire not cooling & freezing cold enough
We ahve a two year old Frrigidaire Freezer. every year same time it seems to correct itself(?), like self defrosting etc, and takes a long time come back to its cooling level. This is made in brazil G series. Please help.
V/r Syed
Dec 23, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Frigidaire Freezer is not getting cold LFFU1765DW9
try to vacum the coils on back, if thats the problem u will feel them get a little warm if this doesnt work try to tap the relay next to your compressor, i had this same problem
Aug 28, 2008 | Frigidaire 16.7 cu. ft. / 473 liter...
Won't get cold enough
sounds like a sealed system problem lack of freon, possible tubing leak
May 03, 2008 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Freezer not frezzing
DR....let's go down the list:
First is freeze up. This happens when too much humidity gets into the unit from the air and forms ice on the coils. Defrost the unit using warm air or leave it open and off for two days.
Problems that cause this: high humidity, 'window shopping', unit not left closed or bad gasket. If the gasket looks damaged, it will need to be replaced. Gaskets that have accumulated dirt don't seal. Use a mild cleaner to fix this. If you have doubts about an area where the seal is questionable...use a sheet of paper about 2-3 inches wide, close the door and pull it through. No resistance indicates a poor seal.
Make sure you clean out the condenser...the coils where the heat is rejected by the unit.
It is possible that you have refrigerant or defrost timer issues. To check for low refrigerant, start the unit after defrosting it. Note that the larger pipe attached to the big black thing....the compressor...will start to frost. It should then start to form ice while the unit is running...about 5 minutes. If the frost stays and the pipe is not REALLY cold, you have a problem with refrigerant. Sealed units are warranted for 5 years. Defrost timer issues are best left to a tech.
Dec 02, 2007 | Frigidaire 14.1 cu. ft. Upright Freezer...
GE Upright Freezer problem/door
The door seal is damaged or the hindge alignment have allowed the warm air to enter and the cold air to leak out the of the freezer. Look and feel around the door for the cold air and check the top and bottom hinges to make sure they haven't become loose. Look for tears also around the seal because this will do the same thing. Let me know what you find. JT
Oct 23, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Kenmore freezer not cold at all!
We had a Kenmore upright which worked fine but then suddenly was not keeping food frozen. Long story short, do not store anything on top of the freezer unit. It will insulate the coils that run across the top of the unit, and cause your compressor to work harder than it needs to, and eventually overheat and become ineffective. Says nothing about it in the user manual. We learned the hard way by losing food.
Jul 30, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Haier 3.6 cu. ft. / 102 liter Chest Freezer HCM036PB Logo
145 people viewed this question
Top Haier Freezers Experts
Victor Nwachukwu
Victor Nwachukwu
Charles T Nevin
Charles T Nevin
christian nielsen
Are you a Haier Freezer Expert? Answer questions, earn points and help others
