Question about Lincoln Welding Tools
I have a Lincoln 305g welder with digital readout and the amperage reading is fluctuating wildly but doesn't affect amperage to stinger,do I simply need to replace the digital display
    Top Expert:
  • Lincoln Master
  • 48,384 Answers
The digital display is just showing what is going on
the amperage is controlled by the voltage setting so the problem is most likely in the voltage regulator
take it in for a proper diagnosis and quote but guessing the fault is like throwing money away
Posted on May 15, 2017
I have a Lincoln 305g with digital readout and the amperage readout is fluctuating wildly but is not effecting amperage to the stinger,is it possibly just the digital readout that needs replacing?
Most likely the coil that is sensing output at the lead terminals. Check it with a hand held Amprobe (digital) to see if out put is stable at the leads.
May 15, 2017 | Lincoln Cars & Trucks
Lincoln 305g kick out breaker with just 4.5 inch grinder
Have you tried another grinder, or a heater is a good test.
Could be a weak breaker. I use a 1500 watt heater to test outlets with.
Feb 10, 2015 | Lincoln Ranger 305g Welder Generator...
My Lincoln welder AC 225 -s sounds like it's running DC ? The only way to get a good weld is with running at a higher amperage
Need more information. Are you using reverse polarity? What kind of rod are you using? What size? What amps? Switch ground and stinger see what happens.
Jul 22, 2014 | Welding Tools
350mp with 25ft. python push pull all of a sudden black carbon sute both sides of weld this welder has always been a great welder sent to dealer but came back same we are welding 4043 .035 aluminum wire
I had this problem with another brand,but the same solution should be effective on your Lincoln. All I had to do was clean my inert gas opening at the "stinger",allowing more argon to shield the weld. If this fails you may have excessive oils or paint residue at the joining edges. Good Luck!
Jul 13, 2011 | Lincoln Welding Tools
I have a fuel a lincon 300 g starts for a couple seconds then fuel stops going into carb and dies, could it be the fuel pump?
If the unit sat for a while the jet in the carb is clogged,if this is the case the carb must be removed and dissasembled,the jet has a small orifice that can be cleanened with a paper lip or a torch cleaning wire.
Feb 26, 2011 | Lincoln Ranger 305g Welder Generator...
I have a 305g machine runs gen works i do not get any read out from the displays
If it is a digital, you need top replace it. They burn pretty easy with overloads.
Dec 24, 2010 | Lincoln Ranger 305g Welder Generator...
My pc control panel is out . I need a new one . Where can i get a new one.
At a welding supply store or business. The can order it or repair it for you. A place that sells welding gases.
Apr 24, 2010 | Lincoln Electric Ranger 305G K1726-4...
I just got a Lincoln ac 225 welder , IT came with no stinger cable or no ground leads I NEED to know were to hook them on the inside?
the stinger is bolted to the amp dial inside the unit,there should be a ground terminal for the ground in same area.
Mar 07, 2010 | Lincoln AC-225 230V
What size battery goes in a 305g?
Group 58 battery with 435 cold cranking amps. Page 3 in pdf manual.
Here is a pdf manual site for your welder...
Mar 05, 2010 | Lincoln Electric Ranger 305G K1726-4...
Anyway to keep it warm at night so it doesnt stuggle to start in the morning
Big heavy blanket or a bottle of isoheet or isopropyl alcohol or a bottle of stabil will keep the gas and lines free of water and cold and condensation. or wrap with heavy blankets.
Dec 08, 2009 | Lincoln Electric Ranger 305G K1726-4...
Welding Tools Logo
83 people viewed this question
Top Lincoln Welding Tools Experts
Robert Monigold
Robert Monigold
Jim Goldsmith
Jim Goldsmith
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
