Question about LG Ovens
I have a LG refrigerator model: LFC20760ST. It stopped working all together. None of the LED panels work. None of the controls work. What now?
I asked a question of another tech and his abridged answer was not helpful. I have taken the PCB OR electronic control board out and visually inspected it. The two fuses are visually perfect. No burns, no blackened areas on the glass and no burnt parts on the board. Also, the board itself is not burnt. Can the PCB be damaged without any visuall sign? The breaker and the outlet have power.
Amigaman
  • 248 Answers
SOURCE: Kenmore 47779 double oven; lower oven doesn't work after self clean
Sounds like a thermal overload has opened up during clean. It may be mounted on the back.
Posted on Nov 04, 2007
the dr
  • 447 Answers
SOURCE: Whirlpool Oven Control Panel Thermal Fuse
If the display is totally out it is likely the thermal fuse this is located where the wire connectors plug into the board it looks like a small resistor in a platic shrinkwrap type sleeve. test it with a continuity meter.
Posted on Oct 27, 2008
  • 86 Answers
SOURCE: GE Double Oven doors locked and circuit not responding
Hi, well this is a brain tester!! I think you need really to look at this in a simple way. Check to see where the door lock wires come from first? Find where the mains power comes into? then if it goes directly to the main control board then check to see if there is any power getting through the board to the otherside where the wires disapear into the cooker. I would consider checking the control board for any signs of burn damage and then look at the clock unit to as these are normally the main components in the cooker that will stop it from working.
Good luck,,,,,,,,,,,,,,,
Posted on Jan 02, 2009
  • 111 Answers
SOURCE: GE Profile Performance Spectra Range error code F0
F0 - F1 - F7 Stuck keypad may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Posted on Jun 20, 2009
  • 25 Answers
SOURCE: Whirlpool wall oven stopped working after power outage
Ouch...sounds like the control module is blown. Thats the electronic timer. I've known this happen on several occasions. Bad luck!
Posted on Jun 25, 2009
Cannot turn the oven on
Too vague need model number an what steps you use to turn on
Feb 17, 2015 | Whirlpool Ovens
GE profile convection double oven. Model#jkp56w0w1ww 1.The touch panel on the Oven is off and none of the button works. There is not light or code in the display area. 2. The light inside the oven...
Oh, you probably got this fixed already. If it happens again, it helps to take the control panel off, insert paper towel folded up neatly and slotted into the ribbon (it absorbs the moisture which causes the ribbon to short out). Sounds crazy but it's true! I saved our family hundreds of dollars with a piece of paper towel!
Aug 18, 2013 | GE Ovens
GE profile oven model # JSP26 display panel flashed and flutters, cannot read any of it, and it will not turn the oven off/on, none of the controls on the display panel work. Had to turn the oven off with...
Disconnect power to the range.
Remove the rear panel cover.
Disconnect....then re-connect all the wires on the oven control.
Replace the panels.
Plug the range in and try it again.
If this does not work the ERC(clock) must be replaced.
Apr 01, 2011 | Ovens
After putting my 10 yr. old Whirlpool Model RBD276PD double ovens thru the self cleaning cycle the bake and broiler elements in the bottom unit stopped heating. All the controls on the panel work and the...
This sounds like it blew the thermostat on the back of the lower oven. They are inexpensive and easy to replace. You will need to uninstall the unit and remove the back panel to acess. Check it for continuity if none replace. This is a fairly common failure due to the heat of the self cleaning. Here is a link to your part and diagrams are also available there AP3055316
Sep 28, 2010 | Ovens
"Door Lock" LED flashing
that means you have door or lock problem may be the door latch failed after the oven self-cleaned,the heat might have blown a thermal overload fuse.first unplug the range and check the wires and connectors between the control and the door switch for damage. if they are okay , pull the range out and remove the back panel. check for the small gear motor that controls the latch and rotate it to unlock the door. . In the open back panel, look to your 10 o'clock position for a round part about the size of a quarter fastened with two screws. You can find out if this is your problem by unscrewing the fuse and taking the wires out, then joining the two wires together. Plug in the oven and see if the led disappears and the door lock works again. If it works, that fuse was your problem. if not then its the door hinge but be careful when doing this,to avoid more damage to the oven
Jan 09, 2010 | Whirlpool AKZ159IX Oven
The LED control panel on my Thermador double oven is out
I solved this. Its a vaccum flourescent display. The voltages that drive it are reducing because the capacitors on the control board deteriorate with temperature. Replace the 3 capacitors and its good as new.mine still working after 2 years...$.20 at radio shack...or have a repair place do it for you...saves $250 for a new board
Nov 16, 2009 | Thermador SEC302 Electric Double Oven
Jun 24, 2009 | Whirlpool RBS305PD Electric Single Oven
LED display stopped working
Hi!!! your clock or control board has malfuction.You can get access from the back of the unit pull the unit out and look at the back remove the screws..Your control board clock board went bad..Good luck..
Jan 04, 2009 | Belling XOU252 Electric Single Oven
Power outage issue
You unit is stuck in the "Display Model Mode". Hold the stop/clear button for at lest five seconds in insure the interlock activates. If it does not activate then the electronic range control (erc) is not functioning. Replace the erc (Clock/Display.)
Jan 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
Top LG Ovens Experts
pawnpower
Dave Harrison
Are you a LG Oven Expert? Answer questions, earn points and help others
