Question about Garden
I have a 425 JD and it will mow for awhile and then shuts down I have replace the coils the thermostat, cleaned the radiator and replace the module and tune it up but it did not help
RJones1125
  • 373 Answers
SOURCE: 91 mazda 626dx 2.2liter shuts off while driving
sounds like the fuel pump relay
Posted on Feb 23, 2009
  • 208 Answers
SOURCE: shut off wont srart 92 dakota 5.2 auto
broken timing belt
Posted on Jun 22, 2009
honeymokey
  • 3113 Answers
SOURCE: I have a 1994 buick lesabre it starts ok but stutters and stalls
Try a crank sensor yet?
Posted on Apr 23, 2010
co7196
  • 3433 Answers
SOURCE: I have a 2010 Gas that after it warms up for
No need for diferent carb. Make sure your fuel is fresh, clean. Drain or clean out the sediment bowl. Make sure the engine dies;'t have an overheating problem. You have symtoms of overheating. Good luck Keep the rpms up, don't lug sround in too high of a gear.If it's water cooled with a radiator, ck the coolant level and that the radiator is not obstructed. Chk your fan belt if equiped.
Posted on May 28, 2010
  • 407 Answers
SOURCE: johndeere 345 keeps quiting 1996 unit 657 hrs, pin
Sounds like an ethanol problem.Try some carb cleaner,if that wont help,rebuild on the carb would be the next step.
Posted on May 14, 2011
Husqvarna YTH2348 just quits while mowing...
check the coil on it,not a fuel problem if the coil gets hot it will shut down and when cool cranks back up,my dad is a lawnmower mechanic!!!
May 14, 2012 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Our cub cadet will run and mow for a short time then it shuts down and won't start if we let it set for awhile then it starts it done this about 4 times now it acts as if it needs the battery char
Take your battery to Oreilly's or autozone,, ask them to check the CCA (Cold Cranking Amps).. this is the true measure of battery quality... if its low, they will tell you and get a new one... see if it runs better,,, it not... you may need the assistance of a qualified professional.. ( may be a coil)..
Aug 10, 2017 | Cub Cadet Garden
MY ******* WILL SHUT DOWN AFTER ABOUT 30 MIN OF MOWING LET COOL OFF ABOUT15 MIN WILL START WRIGHT BACK UP AND MOW AND WILL DO IT AGAIN CAN YOU HELP ME
You have a Ignition Coil (Module) going bad. This is how they act right before they quit completely. You may be able to pick one up used pretty cheap from a small engine shop.
Good Luck!
Jim
Aug 10, 2011 | Garden
My engine cooling module or radiator assembly will not hold its fluid. It is back filling into my reserver tank. The fluid makes my reserver tank fluid boil. The gages says that the car is not...
Your radiator might be air bound or clogged. When the car gets up to temperature and the thermostat opens shut the car off and try to feel all the corners of the rad. if its cool in any spot you might need a flush or new radiator. (When thermostat opens let car run for about 5 min before shutting down) Hope this helps
Sep 13, 2010 | 2006 Chevrolet Impala
I have a 2010 Gas that after it warms up for awhile and while i am using it to mow it starts spitting and sputtering. Shut everything down and let the tractor sit for awhile it starts up and runs for...
May 28, 2010 | John Deere 2010 Tractor Basic Carburetor...
Have a JD STX 38. Put an ign light on it, no
have same tractor same problem mine was coil ran but when i shut off after mowing wouldnt start changed coil no problem since
Aug 17, 2009 | John Deere 420,1020,2010,2020,2510,2520...
JD Lawn Tractor L130. will not start
They have an auto shutoff for low oil, start there check your fluids. If Ok check for spark. Try full throttle choke off in case it might be flooded. See if any of that works and let me know.
May 10, 2009 | Garden
JD mower-only one coil firing
I just switched the coils around. The other cylinder went dead, so I knew I had a bad coil. Replaced the coil and mower runs great.
Apr 01, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
