Question about Samsung Washing Machines
Samsung top loading washer was laid on it's back and now it will not fill
Buffalo12980
  • 625 Answers
SOURCE: Maytag top load washer leak
underneath the agitator is a graphite seal ring and nut that seals the inner tub and the outer tub. a suitable spanner wrench or a 6 inch channel lock plier will remove this locknut. replace the seal.
Posted on Sep 02, 2007
dididsaythat
  • 291 Answers
you have a bad water valve.. replace the valve where the hoses are hooked to your washer
SOURCE: Maytag PAV2300 Top load washer
check your hose from the side of the tub all the way up to the water selector knob. if its loose or has even a pin sized hole in it, it will cause the maching not to sense it has reached the level selected.
Posted on Dec 07, 2007
  • 1073 Answers
SOURCE: Frigidaire top load washer FWS933FS not filling
cold water has nothing to do with the water level this is the normal level for this machine
Posted on Apr 16, 2008
Illeagle
  • 525 Answers
SOURCE: washer does not fill
Firstly, check to see that your water temperature is selected properly. Next, check to confirm water supply to the washer is adequate, both HOT and COLD. If confirmed, try replacing the fill valve.
Posted on May 27, 2008
Were is the valve
the water valve is located where you hook up the hoses to the washer in the back of the washer.
Apr 23, 2014 | Samsung SW62ASP Top Load Washer
I have a Samsung top load washer #WA5451ANW. Will only fill with water. Had to turn the power off so machine would stop filling with water.
Possible that the cut off to the Inlet valve has failed which means that the controller unit is a suspect. Also if the inlet valve is staying ON even when the power is cut off , then it is a case of inlet valve failure.
Dec 31, 2012 | Samsung WA5451ANW 4.7 Cu. Ft. White...
Water leaking from deyergant compartment
Make sure these isn't any foreign objects in the tube that leads into the drum from the detergent tray.
Remove the top of the unit. 2 screws in the back. Top left and top right and slide the top off. Look under the tray and locate the tube and feel around. You may have to remove the tube to get a better look.
Dec 24, 2009 | Samsung WF218AN Front Load Washer
How doyou change a belt on a top loading washing
If you cant get to it from a cover on the front, It must be laid on its back or side to fix.
Oct 21, 2009 | Kenmore 22422 Top Load Washer
Maytag washer pours water out bottom instead of filling up
Check the water pump for physical damage from the move. If the washer was laid on it's side, you may have either snapped off the pump outlet or broke the pump body. You may have broekn the body of the water inlet valve fill flume. A visual examination should provide a lot of insight as to what the problem is.
Dec 20, 2008 | Maytag Washing Machines
Washing machine Whirlpool Lsn1000pq1
My washer is doing the same thing. I put it up on blocks so I could see where it was leaking from. On mine it was leaking from the pump which a big white piece of plastic in front of the motor. The pump has two hoses connected to it the **** the water out of the tub and pump it out the drain hose. Disconnect the two hose clamps, remove the hoses (use force). There are two spring clips on top and one bottom. I laid mine on it's side to remove them. There two slots one top, one bottom for you to use when prying the clips off. Place screwdriver under clip and between grove and push/pull until they come off. Carry pump to the sink, fill with water and see if it leaks from somewhere, should be obvious.
Jun 01, 2008 | Whirlpool LSN1000LW Top Load Washer
Fix it myself
Hi
You are on the way.  Since you have the switches laid back now with clear space in front of the washer.  Remove the Screws from the back and roll the whole Body forward.  This will expose the inner workings of the washer for you.  I like to bring the washer out of the house to an open area to do this.  It makes the job a whole bunch easier. The lid does not pop up.
Nov 01, 2007 | Roper RAX7244KQ Top Load Washer
Washing Machines Logo
27 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
