Question about Panasonic Lands Phones
I have a Panasonic KX-TS4200B that i can not get to connect to another of the same units in the office.
I can make outgoing calls but when I try to connect to another basestation i only get a busy tone even when i know the other units are available. Thanks for any help.
night71
  • 328 Answers
SOURCE: ring tone
Here is the instructions The full manual can be found here.
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Business-Home-Systems/System-Phones/Digital-Hybrid-IP-PBX-Phones/model.KX-T7633
Posted on Oct 29, 2007
SOURCE: How to change ring tone of kx-t7730
sir please i want to when call my consol i'm not there i picup phon our telephone set plz suggest
Posted on Jun 17, 2008
  • 16 Answers
SOURCE: My KX-T7730 can't display, no tone.
KX-T7730 Phone must be connected with a 4wire line cord. you may be tested it with a 2 wire line connector.because other normal phones only needed 2wire line cords.Just connect a new 4w cord to under socket located to main unit & other end connect directly to the tel;system & see is the phone confirmed OK.
& let me know .Good luck.
rishanranatunga@gmail.com
Posted on May 27, 2009
SOURCE: panasonic cordless phone model kx tg3521 is keypad
panasonic cordless phone model kx tg3521 keypad locked .I can attend incoming calls but I can't do outgoing calls .its say dial is locked
Posted on Sep 03, 2010
SOURCE: PBX Panasonic KX-TEM824 configuration
Operator /automatic line
Posted on Aug 13, 2011
KX-TG8421 Panasonic cordless phone
unplug the base unit for an hour. Take the batteries out of the handset for an hour. If this doesn't help, call Panasonic support.
Phone: 800-211-7262
Jan 26, 2015 | Panasonic Lands Phones
How can I get my KX-TGE263 corless phone to connect
Please refer user guide available at the attached link.
I am assuming you have trouble answering incoming landline calls from the phone and there is no problem with making outgoing calls on landline. Also I am assuming you are using cell phones and do not have any panasonic handsets.
First thing to check is whether you can answer using the base unit or not. From there on you will have to then check if the cell units are actually working with the base unit. Follow the bluetooth setup instructions and make sure your cell phone is compatible.etc. http://service.us.panasonic.com/opermanpdf/KXTGE260-MUL.pdf
Aug 10, 2014 | Panasonic KX-TGE273S Link2Cell Bluetooth...
Telephone Panasonic KX-T7730. Taken over in a school office and phone has an outgoing message saying "Please press 0 to speak to someone" This message was recorded by previous member of staff. ...
Let's pretend that this is a TA-824 system with DISA and it's answering all phone calls. It's not likely that you can do much of anything unless you know what system the phone is connected to and have the manual and ability to do programming. With a bit of reprogramming, you can make the system perform like a regular system.
I'd suggest a call to the Panasonic service company.
Carl
May 18, 2011 | Panasonic KX-T7730 Corded Phone
How to configure panasonic exchange Model KX-TEM 824 to work with telemanager call tracking software using telephone KX-T7730
It's pretty straightforward. The DB-9 connector on the cabinet is turned on by default for incoming and outgoing calls, so all you have to do is connect your serial port to the Panasonic serial port at 9600,n,8,1 (default). In the Maintenance console, tab 1.7 adjusts the output. How you set up the software is part of the manufacturer's instructions. The Telemanager software on my search engine was designed for the NANP only.
Carl
Mar 01, 2011 | Panasonic KX-T7730 Corded Phone
KX-T7730 - Used to have 3 incoming/outgoing lines. Have cut this down to 2(lines 1 and 3). Outgoing calls are automatically selected by line 3, 2, 1. When calling out the second person can't get an outside...
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system.
From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
1. Press PROGRAM * # followed by the system password ( default is 1234).
2. Now press 400 and then SP-PHONE. Enter the line number you wish to change. ( In your case 2)
3. Press AUTO ANS / MUTE to change between Connect and Not Connect.
4. Press AUTO DIAL / STORE to save your changes.
5. Press PROGRAM to exit program mode and you are done.
Mar 17, 2010 | Panasonic KX-T7730 Corded Phone
Panasonic cordless phone model kx tg3521 is keypad locked I can atten incomeing call but I can't do outgoing calls
Feb 25, 2010 | Panasonic Lands Phones
How to erase incoming and outgoing calls in
go to resent calls and delete the incoming and outgoing calls
Jul 17, 2009 | Panasonic KX-TGA101S Cordless Handset
Panasonic KX-TS4200
Try changing the extension numbers, separating them as much as possible - e.g. not 11, 12, 13.14 but say 12, 16, 20, 24. Not sure if this will help, but seems to have alleviated my problem - which only occurred on intercom connections. Extension differences are presumably just frequency differences, which could interfere with each other, or some other system.
Mar 06, 2008 | Panasonic KX-TS4200B Corded Phone 4-Line...
Lands Phones Logo
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
