Question about The Computers & Internet
Height adjustment knob - is there a way to loosen the knob so I can turn it?
It is VERY hard to turn
    Top Expert:
  • The Master
  • 77,186 Answers
It is meant to be hard to turn.
Posted on May 18, 2017
I need help with the outside walking foot on a singer211 it has to much pressure on it I need to know how to adjust.
I am NOT familiar with your Singer model 211, BUT.... Most machines [most brands too] have a knurlled screw knob on top which is attached to the long vertical shaft upon which the foot is mounted at the bottom.
"Normally," turning this screw clockwise tends to increase the foot pressure, while counterclockwise rotation tends to loosen the spring pressure on the foot!
Jan 09, 2015 | Sewing Machines
How do I adjust the height of the drafting table?
You should loosen the knobs, adjust the height and then tighten the knobs once you are happy with the height. Screw it tightly and lock them in place.
Jan 07, 2013 | Furniture
How do I adjust the leg height of my drafting table?
There should be screws/knobs at the table base. I've also seen these at the front legs of the table. You have to loosen the knobs, adjust the height and then tighten the knobs once you are happy with the height.
Water level in bowl low
Turn knob on top of float ball to increase ball height which will increase water column. Up to 1" of overflow tube.
Nov 08, 2012 | American Standard Cadet 3 Right Height...
How to adjust height on tractor mower model no. 917.270812? I turn the adjustment knob and it will lock in only on the highest and lowest heights and nowhere in between.
You need to turn that knob to its highest point with the deck height lever to its highest setting. Now turn that knob counter clockwise a few turns and let the deck lever all the way down. That knob will stop the lever part way down. If it mowes to high rase that deck lever again and turn that knob counter clockwise some more and let that deck lever down again. Repete till you have the correct cutting height. If you were cutting to low turn the knob clockwise insted of counter clockwise in the instruction above. The knob only set the stop of the deck lever. Once set the deck lever lifts the deck up and holds it but when you let that lever down it returns to its mowing set height.
Aug 12, 2009 | Craftsman Garden
Height adjustment not adjusting
The height adjustment wont engage unless the handle is in the down position. Not knowing this led me to overturn the hight adjustment knob.
Step on the handle release, pull the handle back and lay the vac on its side. Then you can get the knob and the plate back together again.
BTW, the reason I had this problem is because the front brush slows dramatically when using on carpet, I thought it was set too low, and turned the knob (in a manly fashion, putting it past its limit). Still working on that one. After inspecting the belt, looks like one worn and cracked spot gumming up the works.
Jun 21, 2009 | Bissell 3920 Bagless Upright Vacuum
I need help on how to replace bit on router craftsman style
You didn't state the model number. The older Craftsmen routers had a red lever lock on the top of the router, one position allows the spindle to turn, the other position locks the spindle. Here's the instruction for the older style routers:
  1. Unplug the tool.
  2. To lock the spindle press the red button in and slide it to the locked position.
  3. Unlock the height adjustment knob.
  4. Raise the router motor using the height adjustment collar until you can get a wrench onto the collet nut.
  5. Loosen the nut until it turns freely.
  6. The bit may still be locked in the spindle, tap it gently (not on the blade!).
  7. The bit will come loose in the spindle and can be removed.
  8. Replace the bit, tighten the nut snug but don't use excessive force.
  9. Unlock the spindle, returning the red lever/button to the free position.
  10. Adjust the height of the bit as you wish, then lock down the motor using the locking knob.
Mar 19, 2009 | Craftsman Tools & Hardware - Others
Bought model 3400 skil table saw. have no manual. can't find control for tilting blade. how do i tilt blade
This model does not have a knob on the side.
There is only a locking lever on the front next to a single rotating wheel for height adjustments. To tilt the blade simply twist the locking lever to the left and push the height adjustment wheel to the right. It can be a bit stiff at times to move.
Feb 26, 2009 | Skil 10" Table Saw 3400
Dirt Devil Featherlite Bagless Upright
Check the brush roll, are the bristles worn down? Check the belt also, if it is stretched, then it won't drive the brush roll like it should.
Oct 02, 2007 | Dirt Devil Featherlight Bagless Upright...
Computers & Internet Logo
43 people viewed this question
Top The Computers & Internet Experts
Darren  Means
Darren Means
d3yavu3
kimblebear
Level 1 Expert
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
