I have a 6yo F&P MW613 top loader...seems to be nearly every 1st spin cycle we get a violent out of balance. Should these models have a cut off for this type of scenario? Can't leave unattended..
Good stable environment and always well spread loading. Been doing this intermittently for a long time now but constant for the past 6 months. Works fine afterpausing to adjust and restart...most times very minimalif anyclothes adjustment.
  • 11 Answers
SOURCE: Kenmore Waher spin cycle out of balance
Sounds like your front to back spring is pulling to tight, sometimes you need to replace it and sometimes you can take it off and stretch it. hope this helps
Posted on May 20, 2007
SOURCE: Washer does not spin
I had the same problem in october- my had a bad wiring harness, some board problem, and a bad sensor. if it hadn't been under warranty the cost of parts alone would have been over 1000bucks.
Posted on Jan 09, 2008
SOURCE: Kenmore Front Loading Washer Slow Final Spin Cycle
I have exactky the same problem Replaced the drum and now it will not final spin, I touched nothing else.Can't figure what could be wrong,speed board too sensitive?
It worked fine before the bearing went.
Any ideas?
Posted on Aug 22, 2008
  • 415 Answers
SOURCE: Maytag top loader on final spin cycle leaves the clothes soaked
how much water is in the bottom of the tub and is it louder than normal if so could be small droplets of water leaking from tub seal if not the pump is restricted by something and req replacement
Posted on Aug 20, 2009
  • 4090 Answers
SOURCE: LG wm2277hw front load shakes violently
Barry The repairman was right. The drum is out of balance because of the load amount .Thed clothes or items need to be distributed around the drom rather than just throwing in. When it comes to spin the imbalance causes the machine to shake and move across the laudry.
As it sometimes works This is probably when you are not doing a heavy load of washing, so it appears to work OK.
Pack it with less, also adjust the front legs a full turn higher than the rear so prevent walking when it spins.If you cant find the spanner that was included , just use an adjustable one.
Posted on Aug 21, 2009
Makes clicking noise spin cycle
it may be any part of the balance mechanism under the machine..remember if you did not balance (level) it prior to installing, it has to self level on its own..this usually calls for some noise in the linkages when spinning..
Mar 04, 2014 | Maytag MAT15MNAWW Top Load Washer
During spindrying the WFT9230TP shakes violently although the feet are all pressing tightly against the floor.
The clothes must be balanced inside the drum in order to stop the violent shaking. Unlike a front loader, the top loaders must be balanced before starting the load.
If you need more assistance, let me know.
Sep 12, 2011 | LG WFT1071TP Top Load Washer
I replaced the base assembly and completely level the machine and it still is unbalanced at the 11 mi. mark.
Is your washer a front loader because if it is then one possible solution is by putting less close. I have a front loader and when I put 8 blue jeans along with some other close. The spin cycle is violent and by removing 4 jeans, the cycle spins better and it end up balancing its self. Usually jeans soak up a lot of water, so try to put in lee close and less heavy close.
If this does not help then you might have a problem with the damper shocks (leaking) or springs (broken) if it a front loader washer.
Jan 11, 2011 | Washing Machines
WATER PUMPING IN SPASMODICLLY AND THEN THE BEEPS COME AND MACHINE TURNS OFF. i HAVE A FISHER PAYKEL MW058U TOP LOADER. SAME THING HAPPENS ON SPIN CYCLE.
there r 3 reasons this happens. 1st the out of balance switch is faulty. 2nd the rotor senor near the motor is faulty. 3rd your control board is faulty. have u got an electrical test meter to test the components? please reply 4 more help. 95% of the time the faulty part is the the out of balance switch.
May 01, 2010 | Fisher and Paykel Washing Machines
GE profile top loader, agitator and spin start and stop
Is this a newer model washer? I have one of the newer models and it does the same thing. It is supposed to do that.
May 23, 2017 | GE Profile Prodigy WPSE4200A
Top loader Maytag washer cannot balance load
The shock absorbers that hold the tank are broken. Then the load will move the washer all over the place.
Look online for an exploded diagram and order the new shocks for it
Nov 12, 2009 | Dryers
Washer bangs loudly in middle of spin cycle
Make sure the back spring is still on the back of the tub. That tends to come off sometimes. Check all the other springs while you're down there too. You can balance the unit if you tilt the back side of the washer and then set it back down. it has auto leveling feet. What's happening is once the water is all drained out, the unit will enter the final spin cycle and spin very fast putting the unit off balance so the tub bounces around.
Good luck, let me know if this helped.
Aug 10, 2009 | Kenmore 23012 Top Load Washer
Whirpool top loader unbalanced spin cycle
First change the springs - both the leveling and suspension. You may also need to change a few other parts on the brake and drive tube including the thrust ring. But replace the springs and let see what happens.
Post your results . Remember to rate this solution
Regards
Jul 27, 2008 | Whirlpool LSB6200KQ Top Load Washer
Walking during the spin cycle
Try placing it on a rubber mat or carpet that has a rubber backing. The floor may be too smooth and allows it to walk.
Oct 12, 2007 | GE WSXH208A Front Load Washer
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
