Question about Furniture
Magic chef dual zone beverage cooler doesn't maintain temperature on lower zone
4 Suggested Answers
SOURCE: Error code in the top zone E3
An E-3 error code on your product indicates a problem with the DC fan in the upper zone. Your issue could be with the fan motor, control board or connecting wire harness. A DC motor can not be ohmed out like an AC motor, so if you detrmine the motor is not running, check for DC voltafe at the motor connections. If there is 12 to 24VDC, then you have a bad motor. If no voltage is present, check the output on the board. Before replacing an expensive circuit board, you may want to have a professional service tech come out and diagnose your problem. ***ALWAYS remove electrical power from the product when removing panels to gain access to components, and also when putting the panels back in place.
Posted on Nov 04, 2009
SOURCE: MC wine cooler MCWC44DZ error code e3
I had an E3 on the upper zone. This fix was simple. Unscrew the 2 screws for the middle tray. Pull tray out as far as you can. Check the wires in the back, those are the wires for the fans in the back. The connectors over time corrode, and break off... All I did was connected the 2 wires that had broken off of their connector directly to eachother. E3 went away and the cooler is working as it should now.in
Posted on Feb 17, 2010
  • 5 Answers
SOURCE: Magic Chef Wine Cooler Model MCWC44DZ Where can I
On the Magic Chef site you can order parts for the cooler. I took mine out and treid to find them on the web somewhere else and could not locate them anywhere except China and England. I know this isn't true but tried every search option I could think of. They are about $22 plus shipping (HIGH). You might try the following: http://www.fixya.com/support/t1814377-magic_chef_mcwc44dz_e4_error
Posted on May 17, 2010
Magic Chef Dual Zone Beverage Cooler...top zone works, bottom zone stopped working
What is the model number I can only guess to an answer not having the model number. Check the voltage that was feeding the bottom fan and top fan
Contact Me Here
Appliance 911 Sea Breeze
Nov 18, 2015 | Refrigerators
My dual zone wine cooler stopped cooling. Power is good and fan is working.
Fan is wired separately from the cooling unit. you may have a wire corrosion issue. take put the shelves, disassemble the back of the unit from the inside and observe the wiring to see if there are broken or corroded wires/connections. R/R if necessary.
Dec 14, 2014 | Magic Chef Dual Zone Wine and Beverage...
Stuck in Stand by mode on MCWC44DZ
Hold the lower zone (right side) temperature up and down arrows until it comes out of standby mode.
Jan 05, 2013 | Magic Chef MCWC44DZ Wine Cooler
If I want to store both red and white wines, what is the best way to store them?
I also had the same indecision and finally I've purchased a dual zone wine cooler. The dual zone wine cooler allowed me to maintain two distinct and separated temperature zones within the same cooler which was exactly what is was looking for, and I think this is the optimal solution for you as well.
Aug 14, 2012 | Furniture
I purchased a 52 bottle kitchen aid wine cooler. No matter where I set the thermostat, it is always 45 degrees and readouts are sideways "T's" instead of numbers.
You will need Adobe Acrobat Reader to view these documents. The Adobe Acrobat Reader is available as a free download. arrow_results_summary.gif Get Adobe Acrobat Reader Click Here=> KUWA244PBS Parts List
and here=> KUWA244PBS User and Care Guide
If you should need the service manual you will need to cant me here=> HERE Reason is Whirlpool does not allow me to publish the SM here.
The beverage center and wine cellars have a temperature display for each zone. 12 volts
AC is supplied to the display board from a transformer in the unit compartment. The displays are only temperature displays and have nothing to do with any cooling function. A thermistor is used to sense temperature for each zone. The thermistor for the bottom zone is located inside the lower portion of the separator. The thermistor for the top zone on the wine cellar, (mid zone on beverage
center), is located in the upper portion of the separator. The thermistor for the beverage center upper zone is located on the inside of the 2-piece evaporator cover. It is on the right-hand side.
The mid temperature for the bottom zones on either unit are 60? Fahrenheit plus or minus 5 degrees. The mid temperature for the mid zone on the beverage center and the top zone
on the wine cellar is 45? Fahrenheit plus or minus 5 degrees. The mid temperature for the
top zone on the beverage center is 38? Fahrenheit plus or minus 5 degrees. I think at tis time you should check each section with a pocket size digital thermometer to cofirm tha the mechanical thermostat is within calibration. Click Here=> 4344690 Temperature Control
Click here for a=> KUWA244PBS Beverage Center Wiring Diagram
I believe the problem may be in the PCB transformer shown at the bottom right corner of the wiring diagram. It is possible o change the transformer but I have not been able to find the board that powers the LED temperature readouts. If needed let me know and I will call Whirlpool mfor you, Thanks, Sea Breeze
Oct 09, 2011 | KitchenAid KUWA244PBS Wine Cooler
May 04, 2010 | Magic Chef MCWC30MCG Compact Wine Cooler
Magic Chef Dual temp. wine Cooler #MCWBC77DZC
I suspect the cooler can only actually regulate one of those temperatures and the other one just drags along behind. Perhaps the weather is now warmer and the cooler has to keep the motor on longer to keep cool. The unregulated bottom temperature ends up cooler as a consequence.
Either that or the opposite effect is doing it.
The answer might be to find a 61 degree place in your house to keep the reds.
Apr 28, 2017 | Magic Chef MCWC30MCG Compact Wine Cooler
Jan 04, 2009 | Refrigerators
Furniture Logo
29 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Furniture Expert? Answer questions, earn points and help others
