Question about Cub Cadet Garden
Cub Cadet w/ Kohler sv725-3021.Oil light came on,stopped,add oil to full. Restart, light off then blinking off and on. Rechecked oil, full. Started again same thing. Comments please Thank you,Charlie
  • 97 Answers
SOURCE: oil light blinking
Screw a test gage in the engine where the electric sending unit is. Check to see what the pressure is cold and after it is warmed up. It may be a bad sender.
Posted on Mar 17, 2009
  • 376 Answers
SOURCE: finding the oil plug on Cub Cadet LT 1050 with Cohler engine
It is probably on the right side in the middle of the engine. It should have a yellow cap on the end of the drain. Take the cape off and slide about a 12" piece of 5/8" x 1/2" clear vinyl tubing (available at Home Depot, Lowe's, etc.) on the end, turn the plastic body to the left (about 1/4") and pull out about a 1/4". Oil will flow. Reverse to shut off.
Posted on Jun 12, 2009
SOURCE: I have a cub cadet lt1550 and the oil light is
The mower is programmed to remind you to change the oil every 50 hours. It will continue blinking for 2 hours. It will begin blinking again at 100 hours and every 50 hours after that. There is no manual reset.
Posted on May 25, 2010
wilsodfarm
  • 986 Answers
SOURCE: Cub Cadet Riding Lawn Mover with Kohler Engine -
you need to change your ,and if you already have,the light come on evevy 50 hours to let you know to change your oil, the light will go out after about 2 hours,there is a way to reset it in your owner manual, I just unhooked my battery and it reset
Posted on Aug 20, 2010
Testimonial: "Thanks much for very fast response. Don't remember seeing this in manual. Expect this to work. Was puzzling.,"
SOURCE: how do i reset the change oil light on a 1040 cub
The Service Monitor meter contains a service minder function that utilizes the 4-digit LCD display. The letters "CHG" will display followed by the letters "OIL" and then followed by the meter accumulated time. "CHG"/"OIL"/TIME will alternate on the display for five(5) minutes after the meter reaches 50 hours. The display will also flash as described above for five(5) minutes every time the tractor has been started during the maintenance time interval. The interval will occur every 50 hours and will be in effect for two(2) hours ( Example: this feature will display from 50-52 hrs., 100-102 hrs., 150-152 hrs etc...). While the LCD is displaying the "CHG"/"OIL"/TIME letters, the red LED "oil symbol" will also be flashing for the entire five(5) minutes. The meter display will return to normal function automatically after the reminder maintenance time interval of two(2) hours.There is no method of manually re-setting this Service Monitor gauge.
Posted on Sep 01, 2010
Cub cadet 4621 zx390 single cyl. oil comes out of dip stick tube where is breather located
Find your carburetor assembly. you have a rubber tube coming from that to your to your oil breather. you can also look up your parts manual using the same info you gave here. Cub cadet 4621 zx390. looks like a kohler engine.
Aug 29, 2017 | Cub Cadet Garden
HOW TO RESET THE BLINKING OIL LIGHT ON A CUB CADET RZT
The dashboard for Cub Cadet/MTD mowers includes hour meter, Low oil, or time for oil change, PTO, and other lights. If the oil light is flashing, it means 1 of 2 things. Low Oil Level, or it is time to perform maintenance by changing Oil and Filter. After this process, the light will reset itself after a few more hours of running.
Sep 08, 2014 | Cub Cadet RZT L42 42" 22HP Zero Turn Mower...
Cub cadet starts and then quits
you should see some gas in filter no usually full though
Jul 27, 2013 | Cub Cadet Garden
Cub Cadet shuts down, oil full but blinking light, runs like a champ til then
oil light says on for about 2 hrs from when it due to be serviced by the hr metre not when you have serviced
Apr 08, 2013 | Cub Cadet Riding Lawn Garden Zero Turn...
Cub Cadet Riding Lawn Mover with Kohler Engine - oil light stays on.
Aug 20, 2010 | Cub Cadet Garden
My Cub Cadet oil light was on it read 100 hours
Yes, you overfilled it with oil. Drain the oil and fill to the correct level. If you are not sure how much to put in, add small amounts until the dipstick shows a full reading.
Jun 15, 2009 | Garden
Oil light blinking cub cadet model gt 2542 it started blinking the frist time . has oil in the ttractor . tfe tractor has less then 100 hrs 2 yrs old.
Mar 08, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
29 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
