Question about Refrigerators
Bottom two drawers are freezing cold and cold lock button won't turn off.
  • 125 Answers
SOURCE: Admiral Side by Side Fridge is warm at top, cold at bottom
CHECK TO SEE IF THE EVAPORATOR FAN MOTOR IS RUNNING, ITS IN THE BACK OF THE FREEZER SIDE, MOTOR MAY BE BAD OR SOMETHING COULD BE BLOCKING IT...
Posted on Feb 07, 2008
22yooper
  • 828 Answers
SOURCE: bottom drawer wall is covered s ice/ top shelf not freezing
Sounds like a defrost system problem. Could be related to defrost timer, heaters or defrost thermostat. Have it serviced.
Posted on Jun 15, 2008
docjohn174
  • 943 Answers
SOURCE: Drain freezes and glacier forms inside bottom
hi thanks for the question the drain hose leading from the freezer is clogged up remove the ice from the bottom pull fridge from wall find small drain tube clean the tube now it will drain into tray vacuum out while your there thanks the appliance doc
Posted on Sep 25, 2008
  • 531 Answers
SOURCE: GE Profile produce drawer freezing the veggies
check the dooa and see if it (ajar)
Posted on Apr 01, 2009
  • 236 Answers
SOURCE: Both freezer and fridge Not cold on top
sounds like the circulation fans are jammed/seized or faulty -try a full defrost and see what happens after that.
Posted on Apr 04, 2009
Why is everything in the crisper drawers freezing?
Crisper draws are at bottom of fridge, cold air collects at the bottom and warmer air rises. Turn thermostat dial down, mine is set on 2 out of 6 and every thing stays fresh and doesn't freeze. In very hot weather I do sometimes turn it up to 3.
Dec 03, 2016 | Refrigerators
Where do I put cold cuts and meats I don't want to freeze?
Best place for cold cut meats is the bottom drawer in the refrigerator. It's also good for cheeses. That drawer is the coolest but not freeze place. The upper two drawer are good for veggies and fruits. We put the lever controls in the middle selection for them.
Aug 02, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
All cans in the bottom drawer freeze in a couple of days
What temp do you have the fridge set on? The bottom is always the coldest part maybe dont run the fridge as cold or put the cans in the door or at a higher part of the fridge.
May 22, 2014 | KitchenAid KSRD22FKBT / KSRD22FKWH /...
Freezer not cold
See if you can
change the thermastat so it also freezws the bottom drawer.
Sep 16, 2013 | Zanussi ZRB834NW (865 cu. ft.) Bottom...
The botton drawers are freezing the friut.
Is it a freezer on bottom unit? If so, it's because the fridge part of a refrigerator, doesnt actually cool anything, it uses the cold air from the freezer. I'm assuming the vent from the freezer is right behind the fruit drawer? Try turning the fridge temp. down a little, or unfortunately don't keep anything in that drawer?
Mar 14, 2012 | GE Refrigerators
Fridge is freezing food
Make sure nothing fell below your crisper, deli drawer section. There are some air return vents below them and if they get partially obstructed would allow cold air to pool in the bottom of the fridge.
Make sure your freezer control did not get turned up too high.
Also you may want to check with the manufacturer as they did have some issues with some of the bottom mount models exhibiting this problem and they developed a repair kit for them.
Jun 11, 2010 | Amana ABB1927DE Bottom Freezer...
Freezing in the bottom draw of my LG Refrigerator
YES!!!!!!
Remove the bottom drawer.
In the back you will see a small dime sized hole.
The hole allows cold air to circulate around the crisper.
Plug the hole with tape or anything that will fit the hole.
Set temps back to say 36 in the ref. and 0 for the freezer.
This should help.
Jan 09, 2010 | LG Refrigerators
Maytag Model MZD2768GE
I've got the same problem with my 2nd drawer. Did you figure out the problem with your top drawer?
Oct 06, 2009 | Refrigerators
Both Lights flashing and fridge not getting cold
I turned the fridge and freezer off using the circular dials, I then turned the unit off at the mains. Left it for a few minutes and then turned the power back on. I then turned the circular dials to "max" and then depressed the super cool and super freeze buttons to turn this facility on. This time they came on normally (not flashing) and no alarm sounded. The fridge and freezer then started to get cold. Once the unit had been running for several hours I then turned the dials to the 3/4 mark and depressed the super cool and super freeze buttons again to turn them off. Over night the fridge and the freezer appear to be working properly so I hope that my problem is solved. Maybe the unit just needed to "settle" before being switched on?
Sep 03, 2009 | Freezers
Bottom vegetable/fruit drawer freezing fruit
to the left of the bottom drawer is a veg/meat slide switch.make sure it is all the way on veg.if it is on meat,it opens a small doorway to the freezer and lets the cold air in and will freeze the food in the bottom drawer.in some cases,you will need to remove the drawer and shelf and then take apart the doorway.ball up some putty and jam it it the hole to completely seal it off
Jan 11, 2008 | Amana ARS2661BS Side by Side Refrigerator
Refrigerators Logo
23 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
