Question about Cutter Tools
Change blade Stanley 10-989
Was able to open knife, the blade fell out attached to the slide knob. Can't get the blade out....
4 Suggested Answers
cargurudude
  • 26 Answers
SOURCE: stanley knife blades fell down drum and under
Probably the best thing to do in this situation is to empty the washer out, then unplug it and turn the water off at the spigot.
Then invert the washer, leaning it back, so as to reach the blades under the drum.
Posted on Mar 04, 2009
SOURCE: stanley 10-788 how to change blade
Push the top metal button all the way foward as if pushing the blade out to it's (farthest) 3rd setting. Then push foward and down one more time which locks the mechanism down. Push and hold the yellow side button as you insert the blade. When the blade locks in all you have to do is release the yellow button and return the top slide to it is fully retracted home. The blade is loaded
Posted on Feb 04, 2012
cjdl52
SOURCE: Stanley 10-777 utility knife: I need to reinsert
I had the same trouble. The blade holder was out of the knife and would not go back in. I fixed it this way: open the screw knob all the way to the least tension. Slide the two parts open but not all the way- there is a tab on the blade holder that gets in the way if you try to drop it in at the fully open position. With the two halves SLIGHTLY open- slide the blade holder in making sure that the tab is seated in it's slot. Depress the thumb tab and bring it to the most forward position and the two halves should be able to be seated together again.
Posted on Dec 12, 2013
Describe how you put a blade in FatMax model 10-778
The model in your picture is a fixed blade utility knife (model 10-816). Your question asks for instructions for model 10-778, which is a retractable knife. I'll guide you through the 10-778 which you asked for, if you need instructions for the pictured 10-816 please re-post the question.
Push the thumb slide forward as far as it goes exposing the blade. Press the blade change button on the side of the knife (the small button on the left side near the blade) and pull out the old blade.
Insert the new blade and slide thumb slide back to fully engage blade in the internal lock.
Dec 26, 2010 | Stanley Fatmax Xtreme Retractable Utility...
How do I put the first blade in the new knife?
open the blade all the way and turn the knob to loosen, then scissor the two halves to open
Oct 22, 2010 | Stanley Fatmax Xtreme Retractable Utility...
I unscrewed Stanley 10-379 Interlock retractable knife and now I don't know how to put back the gizmo that fell out or the three blades that came with it.
Google: how to change blade in Stanley 10-379 utility knife. Stanley website shows how knife & blade look on the outside. Put it together so it looks like that. Sorry, but ain't don't know how to send the picture to you.
Oct 21, 2010 | Garden
How do i change the blade in a stanley fatmax?
You do not have to remove any screws. Extend the blade outward using the thumb slide on top of the knife. There is a small black pushbutton on the opposite side from the lock button. Depress the button on the side and using the other hand, grab the blade with your thumb and forefinger to pull the blade out. It may require a little wiggling. Now the new blade can be slide in and locked into place. The black pushbutton controls the locking mechanism that keeps the blade from pulling out.
Aug 07, 2010 | Stanley Utility Knife
How do you load a new blade?
At the back end of the knive (the curved end) press the black piece through the yellow rounded part and the yellow front and the black back will part, now slide the yellow part back to reviel the blade folder. Fit new blade then refit the yellow part on top of the black part and slide the yellow part foward to lock it back in.
Jul 31, 2010 | Stanley Utility Knife
Just purchased a Stanley FatMax 10-778 retractable knife. Cannot figure out how to load the blade for use.
1. Make sure the side lock is unlocked.
2. Push the thumb tab all the way to the front of the blade handle.
3. Insert the blade in the opening, you may notice two notches on the top side of the blade.
4. Press the small blade release button as you slide the blade into the knife. You may have to jiggle up and down to get the two notches on the blade fully into the handle.
If properly inserted, the exposed area of the blade should look very close to an equilateral triangle.
make sure both notches of the blade are inside the handle. They notch into the thumb lever.
good luck
Mar 20, 2010 | Stanley Fatmax Xtreme Retractable Utility...
Stanley 10-788 how to change blade
Jan 14, 2010 | Hand Tools
Stanley 10-777 utility knife: I need to reinsert the retractable blade slide back into the knife body. I try but the knife won't close.
Oct 27, 2009 | Stanley Hand Tools
Stanley knife blades fell down drum and under
Mar 04, 2009 | LG WFT1071TP Top Load Washer
Cutter Tools Logo
290 people viewed this question
Top Cutter Tools Experts
JOHN LAPIER
Are you a Cutter Tool Expert? Answer questions, earn points and help others
