No sync signal on hatichi ultravision digital 60 in tv
Its black with sound please help just changed bulb
SOURCE: Mitsubishi 60 inch projection
They are not BULBS by any stretch of the imagination. They are CRTs (Cathode Ray Tubes, also known as "picture tubes," and each of them are small television screens, in essence), which are optically enlarged for projection onto the back of the front screen. Don't be tempted to think that you will merely be able to replace a "bulb" and have everything work!
Although you will be able to replace all of the components on the PC board if necessary (they all remain available), and may be able to fix the coolant leak that caused the failure, the CRT may have overheated. Considering the advanced age of the television, the tubes are likely already somewhat burned-in. Best to just dispose of the set.
Posted on Nov 20, 2007
ctf1800
  • 4402 Answers
SOURCE: hitachi ultravision
Check IC601, C603 for leakage, I601 and vertical pulse detector QN05
for poor convergence check RK42 for open circuit.
Posted on Jan 07, 2008
  • 72 Answers
SOURCE: hitachi ultravision 2005 turns on for about 5
could be shoted convergence ICs
Posted on Jun 07, 2009
  • 1382 Answers
SOURCE: i have sound but no picture on my hitachi ultravision digital tv
When you use the remote control can you see the on-screen menus, volume or any stuff? if yes, then you may be lucky and have a cable problem. Can you try with another source (DVD, VHS) if you see video with them then you still can be lucky.Check the cables and the hdtv cable box. If you answered NO to any of the previous then its a TV problem and you can't fix it by yourself..
Posted on Aug 27, 2009
techman007
  • 1112 Answers
SOURCE: Toshiba DLP 60" TV not showing TV programs, sound ok
Have the tuner signal board replaced. HDMI does not use the regular tuner bands, it is bypassed when using hd inputs.
Posted on Oct 24, 2009
Hitachi 55vg825 - sound fine / but no picture- only indicates No sync signal on tv-
It could be the lamp---if you remove the lamp look to see if it is shattered inside---average life on lamp is 2,000 hours or 2 years.
May 16, 2012 | Hitachi UltraVision CineForm 55VG825 55"...
Were are both of the cooling fans located on my Hatichi Ultravision Dlp tv?
Some have cooling fan Located under the light Engine, Lamp Fan,Ballast Fan.on the Ballast Board.
Aug 17, 2011 | Hitachi 50V720 Television
Hitachi 42" ultravision...power light on, hear
Tries pushes the power switch on the remote few times,each times push wait like a 1 mins or 2 mins for the tv Tuner signal board to take it effect.This process should get ur tv picture back,because the tv Tuner signal board it is old and having problems,evenually require replacement of a refurbish tv Tuner signal board.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
May 23, 2011 | Hitachi UltraVision 42HDS52 42 in....
HITACHI ULTRAVISION DIGITAL TV.MODEL NO: SP60WS lamp light is red
The lamp should be replace to fix the no picture since the lamp light is red.
Download the user's guide and see pages # 69-72 for lamp replacement.
Jul 10, 2010 | Hitachi 60V710 60" Rear Projection HDTV
Aug 25, 2009 | Toshiba 52HMX94 52" Rear Projection HDTV
Is my Hitachi 61uwx10b ultravision hd ready digital tv ready when they switch over to digital vrodacasting or will i need a converter box,
This TV will need a converter box. It was made in the days before the digital tuner was required on big TV sets.
Just remember the converter is only needed if you get off-the-air reception with an antenna for local channels. If you have cable or satellite and get your local channels that way, you don't have to do anything. The change to digital will not affect you.
If you are now using rabbit ears or an old worn-out outside antenna, you might think about upgrading your antenna when you get a converter box. Signal strength is very important with the new digital broadcasting. Too weak a signal means no picture at all or one that freezes up or turns blocky. The antenna that worked for analog may not be adequate for digital.
Jun 06, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Hear a click when turning on, but the red light, no picture
Please make sure that the video source is on and that the source input on the TV is set properly. I am thinkig that the TV is working properly but has no input signal to display.
Feb 26, 2009 | Hitachi 60UX57B 60" Rear Projection...
Hitachi ultravision 50v500
there should be 3 sets of video rca jacks on tv or receiver they might have put them on the wrong rca jack in which they just need to be moved over
usually the 3rd set of rca jacks are component jacks not for tv or video but for low output signals say like cameras and only one set of rca's can be used at a time svg on one of them rca's will over power the vid's. so have no picture
Apr 14, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi ultravision
Dec 20, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
