Question about Cell Phones
Bush spira 2 8" sidebar started flashing then mirrors image and has black white lines.
This is 3rd replacement as other 2 charger ports went. I rebooted it and nobdifference its ver half charged. Only had this about 4 weeks
jerryg50
  • 1689 Answers
SOURCE: lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Posted on Apr 12, 2008
  • 146 Answers
SOURCE: TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
Posted on Nov 15, 2008
projdoc
  • 2237 Answers
SOURCE: White vertical lines in image w/ 2 inch black bar horizontal.
the black bar is from the light tunnel collapsing. the white lines are from the colorwheel or the main board has a cold solder joint. replace the tunnel and colorwheel and have the main board looked at.
Posted on Dec 29, 2009
  • 36 Answers
SOURCE: 42 Plasma TV has many vertical lines (stripes)
screen itself would seem to be the problem here
Posted on Feb 15, 2010
SOURCE: Dv9000 split in half
Sounds like the NVIDIA chip. I had a guy on ebay fix mine a month or so ago for a real good price but I wasn't able to find the listing to give you the information.
Posted on Apr 01, 2010
Hello I have a bush spira c1 smartphone and I've broke my screen and can't find a replacement screen anywhere where can I get one from?
Bush is an Argos own brand, so take it in and ask them to have it repaired. Screens are not available online.
10 months, 1 week ago2 Likes #1 Reply Bush is Argos own brand now. Like Goodman's I believe.
SIM FREE BUSH SPIRA C1 SMARTPHONE 391 2858
Jun 02, 2016 | Cell Phones
Faulty screen, horizontal lines
Battery is stuffed, replace it. White lines is the early signs or the LCD is damaged and needs to be replaced.
Jan 15, 2013 | Tomtom ONE 3rd Edition GPS
I needto replace the battery charger on my Rascal 600F scooter
Hi. Most chargers with only two wires, have a small bridge wire from the
black ( negative ) wire to the middle terminal of the connector. This disables the controller while the machine is charging. The charger will still work without this bridge wire, but the scooter will still operate normally.
There are a few different chargers around that have an internal relay that disables the scooter, but these chargers are normally "on-board" chargers.
Good luck. Neil.
Jul 05, 2010 | Electric Mobility Power Electric Scooter...
Philips 60PP9200D went black and white.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixelation ,black and white picture,even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 05, 2010 | Philips 60PP9200D Television
No image
hi,easy clean optics section that include mirrors.if the mirrors full of dust there is the poblem.
try the first then another solution check scanner section or replace.
May 14, 2009 | Toshiba 1360 Black and White Copier
Hp 4550 vertical line down center of page
From the service manual:
Vertical lines or streaks
 Check for a leak where light might be entering the printer.
 Check for circumferential scars on the photosensitive drum. If scars are present, replace the
drum cartridge if the line goes through all colors.
 Check for circumferential scars on the upper fusing roller. If scars are present, replace the upper
fusing roller if the line goes through all colors.
 Remove the imaging drum and inspect main charger or imaging drum for a contaminant, such as
a fiber, if the line goes through all colors.
CAUTION Do not expose the imaging drum to light for more than 15 seconds. The drum is light sensitive, and
exposure to light can cause permanent damage.
Vertical black lines
 The toner cartridge is defective.
 The toner cartridge is not seated properly.
 The fuser entrance is dirty.
 The fuser has scratches on it.
 This might be a repetitive defect. If so, the lines will repeat at a consistent interval down the page.
 The printer needs to be cleaned.
 There is a problem in the heating element.
Vertical white lines
 If white lines or streaks appear only in the black areas of the printed media, print several
configuration pages to clear the anomaly. If this does not clear the problem, check the sleeve
surface to confirm the defect, then replace the black toner cartridge.
 If white lines appear only in a particular color, try printing several configuration pages to clear the
error. If the error does not clear, check the sleeve surface to confirm the defect, then replace the
defective toner cartridge.
 There is a lack of toner or the toner cartridge is faulty.
 There is dirt in the laser path.
 The fuser is defective.
 A mirror in the laser scanner is dirty.
Apr 07, 2009 | HP Color LaserJet 4550 Printer
My apple ipod nano 8gb 3rd generation's screen went black
It probably hangs on you, right? I get that problem on my silver 3rd gen nano when i jog. What i do is press the menu button and the middle circle button at the same time, and it'll restart the whole thing. Make sure you unlock it (bottom next to charger port, make sure it's white, not red) first. You'll see the apple screen as it starts back up and it'll go to the main menu. I run a lot so maybe it got jarred or something on mine. I hope that's all it is, or it might be a static problem. That I'm not helpful with. :| Good luck.
OH and it won't delete your songs so no worries on that.
Feb 13, 2009 | Apple iPod nano 8 GB Pink (3rd Generation)...
Nov 12, 2007 | InFocus ScreenPlay 7205 Multimedia...
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
