Question about Book Computers & Internet
Next book ares11a will not stay connected on restart
I have a kindle fire I cant open the books to read it was fine until last week everything else is working fine mary levy
Book Won't Open
Your book won't open on your Kindle (5th Generation), or there's an error when you try to open a book.
Before you perform these steps, make sure that your Kindle is connected to a wireless network. To learn more, go to Connect to Wi-Fi.
There may have been an error with downloading the book. Remove the title from your device, restart your device, and then download the book again.
  1. From Home, select the book or content to be deleted and press the left side of the 5-way controller.
  2. Select Remove from Device.
  3. From the Home screen, press the Menu button and select Settings.
  4. Press the Menu button again and select Restart.
  5. After your device restarts, navigate to your Archived Items, and download the book again
Nov 28, 2016 | Amazon Kindle
How do I access a book after it has been down loaded?
On the Homescreen you will see an item next to *cloud* called *device* Any downloaded books will be listed there if they are not on the homescreen. *Cloud* is your library of books on the Kindle server. If you want a book from the cloud just touch it while you have a 3G or WiFi connection and it will download and then be listed on *Device*. It will also still be listed in the cloud as your books always stay on the cloud regardless.
Just touch the book and it should open for you.
Apr 15, 2015 | Amazon Kindle Paperwhite
Can I connect my hmdx rave to my next book?
Yes, you'll need a 3.5 mm audio cable (PC audio) with M/M ends. Connect the cable between the headphone jack of the Next Book and the Aux Input of the Rave speaker. The Aux Input jack on the speaker is between the charging port and the On/Off switch. The headphone jack is between the power button and the DC Power Input port on some Next Book models; you should check your unit's documentation for the exact location. Only the volume controls on the Rave speaker will work. You'll need to select tracks and press Play/Pause on the Next Book.
I hope this helps.
Sep 29, 2014 | Tablets & eReaders
old post
are you asking diagnostic advice,
or asking for manual or does manual mean stick shift
i toss coin
you wan the books,
click ack-faqs here , full 96 fsm there. book,manual
and tons more 600 pages there.
does it keep running if you keep charger connected
10amp charger ,not less.
green battery cables are first. lugs good, a must be......
Feb 15, 2014 | 1996 Geo Tracker 2 Door
Bluetooth is paired. Works for about 1 day. Then will not connect again.
Did you try the "Device Discoverable in ___ secs?".In settings, Make device discoverable first then set the length of time. Android phone have this limited BT capability i think.
Nov 14, 2013 | Motorola Mobility L512bt Cordless Phone
Computers & Internet Logo
16 people viewed this question
Top Book Computers & Internet Experts
john h
jimmy Leo
Are you a Book Computer and Internet Expert? Answer questions, earn points and help others
