Question about Crafts & Hobbies
How can I use my cricut expression 2 with cricut craft room
How can I link my cricut expression 2 with Cricut craftroom?
  • 9 Answers
SOURCE: need to update firm ware on cricut expression so i can use sure cuts alot could not find at cricut.com
Go to
http://torrent-finder.com/open/36-Fulldls.com/%20update%20drivers%20
and use torrent to download the program
Use it to update any driver
Enjoy
balboul@gmail.com
Posted on Jul 05, 2009
CricutAddict
  • 13 Answers
SOURCE: Cricut Expressions Machine error
  1. Make sure your cricut is off when you plug it into your computer via usb.
  2. Make sure your usb cable is plugged directly into the machine, and not to a usb hub.
  3. Start up the DS Once the DS is fully loaded, choose HELP > UPDATE FIRMWARE.
  4. On the cricut machine, hold down the STOP button. Keep holding it down and briefly hold down the power button. Keep holding down the stop button and in about 3-5 seconds, you will hear a beep. That means you are good to go.
  5. On the "update firmware" screen on your computer, select the model you have and then click "begin updating now"
  6. Go and read a magazine or make a cup of tea because it takes a while to update. If it goes really fast (no matter how cool your computer is) it means it did not install properly and you will probably have to do it over again.
Hope this helps you.
Posted on Mar 25, 2010
diodeic
  • 1622 Answers
SOURCE: after "updating my cricut expressions
You can use the below for help to get the parts for replacement..
http://www.cricut.com/shop/
Take care..
Posted on Apr 11, 2011
tlargent365
  • 6 Answers
SOURCE: I need a manual for a cricut expression
www.manualsonline.com/
Posted on Feb 18, 2012
  • 36580 Answers
SOURCE: How do I get a spare handle for a Cricut Expression Cutting Machine from Provo Craft
Check with a craft supply store which handles Provo Craft products.
Posted on Jan 29, 2015
My Cricut Explore Air wont cut
If your Cricut machine is not cutting all the way through your material, or is only scoring the material, choose a machine below for specific troubleshooting tips. Fortunately this issue can usually be resolved with basic troubleshooting.
correct cut settings.
  • Remove the blade housing, then remove the blade and ensure that there are not any bits of paper stuck to the blade or lodged inside the blade housing. Ensure that you replace the blade housing correctly into the machine. Once clean, test your cuts again. If the blade and housing are already free from debris, or cleaning it did not help, proceed to 3.
  • Try an arm buoyancy test: gently press down on the black arms that surround the blade housing and then release them. Do they bounce right back up, or do they stick or rub in any way? If they stick or rub, please contact Customer Care through one of the options below for further assistance. If they bounce right back up when released, proceed to 4.
  • Increase the machine pressure settings and try your cuts again. If this does not change the cut result, proceed to 5.
  • Increase blade depth by turning the dial at the top of the blade housing. If this does not change the cut result, proceed to 6.
  • Perform a Hard Reset on the machine. If this does not help, proceed to 7.
  • Check your machine's firmware version. If the firmware is not up to date, perform a Firmware Update using Cricut Craft Room, a Gypsy device, or Cricut Design Studio.
  • Retry your cuts with a new blade housing.
  • If the machine is still not cutting through materials, or is only scoring the paper, please contact Customer Care through one of the options below for further assistance.
  • Forced Firmware Update on the machine through Cricut Sync.
  • Retry your cuts with a new blade housing. If the issue persists, proceed to 8.
  • Attempt a Format and Restore on the machine through Cricut Sync. Please note that this step should only be taken if all other steps have failed to resolve the issue.
  • If this does not resolve the issue, please contact Customer Care through one of the options below for assistance.
  • new blade. If this does not help, proceed to 5.
  • Adjust/increase the Multi-Cut setting in the Cricut Craft Room cut preview screen and retry your cuts. If this does not change the cut result, proceed to 6.
  • Retry a cut using a new blade housing.
  • If the machine is still only scoring or not cutting through the material, please contact Customer Care through one of the options below for assistance.
  • Jan 16, 2017 | Crafts & Hobbies
    One or more of your cut images are not positioned entirely on the mat, They will be skipped
    Just follow the steps given at this link, and your cutter should begin to cut again. I just tried it and my cutter is back cutting. Cricut Craft Room Troubleshooting Cricut Help Center
    Aug 01, 2016 | Provo Craft Cricut Mini Electronic Cutting...
    When using a design in Cricut Craft Room, and select cut, my Expression 2 begins, but does not complete, the cut. The arm moves to the paper and then makes a croaking sound and then nothing.
    Search cricut.com for support faq go to expression 2 search format and reset. Watch the video on format and reset and do as it says. Calibrate when it's finished. If this doesn't work re download ccr after deleting it from your computer.
    Jan 10, 2016 | Provo Craft Cricut Expression 2 Electronic...
    My cutting tool icon along with 5 or 6 other icons are grayed out. How do I get them back?
    It won't cut when it is greyed out. Try moving the image slightly on the craftroom mat or turn it on an angle
    Feb 26, 2015 | Provo Craft Cricut Expression 2 Machine
    How can I get a new Encoder board V2Encoder for a Cricut Expression?
    You may be able to get a replacement circuit board from the source where you purchased your Cricut Expression. More likely, It will require an inquiry to Provo Craft to determine availability and source.
    Feb 02, 2015 | Provo Craft Cricut Expression Personal...
    My cricut wont turn on
    Hi, My cricut expression is more then 5 years old. I used it one day and the next day I would not come on (it dose Nothing at all). I brought a new power cord from cricut and still nothing. I'm unable to buy a new one Please help if you can. Thanks!!
    Jan 26, 2014 | Cricut Expression Cutting Machine
    Cricut mini flashing red light
    1-Open Cricut Craft Room with circuit on and flashing green/red
    2-Hold power & feed button together until both are solid green
    3-You'll be prompted to update firmware
    4-Press & hold two buttons again (keep holding)
    5-initiate firmware update
    6-Let sequence go until 99% ...you may hear a sequence of beeping, don't be alarmed
    7-Release buttons
    8-You'll be prompted to restart your machine
    9-Unplug all plugs from Cricut
    10-Wait 30 seconds
    11-Plug in both cords
    12-Power on Cricut
    13-Light should be solid green
    14-Press OK on Craftroom prompt on computer
    15-Done
    Jan 03, 2014 | Provo Craft Cricut Disney Font Cartridge
    Is there a replacement strip for under the slide
    http://www.cricut.com/shop/#0/1/349/3/Cricut/Cricut%20Expression%20Machine%20Replacement%20User%20Manual
    This has a list of all the replacement parts on the left side.
    Mar 09, 2011 | Cricut Expression Cutting Machine
    Crafts & Hobbies Logo
    516 people viewed this question
    Top Crafts & Hobbies Experts
    R.A. Ellis
    R.A. Ellis
    Debbie
    Are you a Craft and Hobby Expert? Answer questions, earn points and help others
