Question about Sony PlayStation 2 (PS2) Console
PS2 Internal Clock Stuck
Have a PS2 version V4 and it will play cds but nothing else. Read online it could be a simple clock fix. I went and tried to change the clock and it is stuck. Could something be wrong with the battery or could something have disconnected. It isn't the laser because I don't get a disc read error, it just sits at the main screen if there is anything inside other than a cd. The orbs are all together also. Any help would be greatly appreciated. Thanks.
You shouldn't use alcohol, since it can make the lens even dirtier, best use Butane lighter refill, and then wipe it with cotton
Posted on Jun 19, 2008
  • nesmaniac Nov 08, 2010
    Rubbing alcohol works fine, I've fixed several ps2's this way. I use a little on a qtip then I dry it with the other end of the qtip slighty going in a circular motion. I've even cleaned the lens under the lens you can see which is bigger and if it gets dirty cleaning the top lens won't work. It takes either tiny philips screwdriver or tiny torx to remove 2 tiny screws and you can lift the top laser lens off the larger one and clean the larger one which must focus the laser light onto the main lens. Oh, and if your old ps2 gets that grinding noise and won't read disc you need a new laser guide gear which simply rides in the work gear that moves the laser back and forth. It has two little teeth that ride in the worm gear and over time they wear down enough to slip on the worm gear. My ps2 was 6 years old with 1,000 hours on it before I had to replace that little piece on it.
  • 709 Answers
Hi Dominicano77,
It sounds like you PS2 needs a good internal cleaning. You can replace the battery and you will still have the same problem. I have repaired over 100 Playstations like yours and never did the battery thing work or help anything but keep the Parental password set. You do not always get Disc Read Error Message. I believe your Laser has a dirty lens. Clean it wil a Cotton swab lightly dampened with Alcohol. Then Dry the lens with the dry swab. i suggest you Clean the entire PS2 of all dust and lint. The orbs should fly around in a circle, not be all grouped. This indicates your have a motherboard data flow problem.
If your not comfortable with this , you need to Click on " Repair directory" at the bottom of the screen. Then click on "Video Game Consoles" and after that pick a Repair shop.
Posted on Nov 21, 2007
How do I change the time zone on the Sharper Image Big Digit Atomic Clock Model SN001?
To access TurboTax, you need to have a valid username and password for the system. Now, different people use different versions of the device. Turbotax Support Number Some users opt for the online version or browser based version, while some users opt for the simple desktop version.
Oct 22, 2016 | Sharper Image Audio Players & Recorders
My new ps2 does not read some cds
If your new PS2 is NTSC and you are trying to play PAL cds then it would not play and also if you it is a PAL console then it won't play NTSC cds. You can program it also to play both cds, its going to cost you any way.
Best regards
Aug 12, 2010 | Sony PlayStation 2 Slimline Console
PS2 wont play DVD movies!
Hi. It seems that you might have an old version of the PS2.
The original PS2's had a problem with the laser that read CDs and DVDs, often failing, creating problems with reading DVDs and in rare cases, CDs.
Unfortunately, the class action lawsuit filed against Sony is too old to get yours fixed for free, but there are ways to attempt to fix the laser yourself, if you would rather not send it in to Sony.
If you have any other questions, respond and I'll help you the best I can.
Good Luck!
Nov 25, 2009 | Sony PlayStation 2 (PS2) Console
Emerson Smartset Clock Radio setting for everyday alarm
You will need to reset the Clock/Radio's microprocessor. To do this you must unplug the Clock/Radio and remove the internal battery (CR2430). Let the Clock/Radio set without any power source for at least 2 hours. Then put the internal battery back in the Clock/Radio and plug it in to the a/c outlet. Test to see if the Clock/Radio functions have returned to normal. If the function have not returned to normal, you will need to replace the internal battery. Then let the Clock/Radio again set with out power for a period of at least 2 hours. after a 2 hour period, put the new battery in the Clock/Radio and Plug it into the a/c outlet. Test the functions to see if the microprocessor has reset to normal operation. If you are still having a problem with the Clock/Radio's operations , you will have to give the Emerson customer support a call. The Telephone number for the Customer support is 1-800-898-9020. You can call them between the hours of 7am-5pm CT. Give them the make and model number of your Clock/Radio and ask them for assistance with your problem. I hope this information helps you fix the problem with the alarm in the Clock/Radio.
Jan 30, 2009 | Emerson Smartset Clock Radio
Ps2 Disk read error
Its almost always the laser. I would bet on the laser.
Jan 21, 2009 | Sony PlayStation 2 (PS2) Console
Can ps2 slim play ps1 cd?
harpy_125..yes they do .but you do need an old version memory card to memorise your games. does it play music cds . if so it should read the games as these are only cd and not dvd..
Feb 09, 2008 | Sony PlayStation 2 (PS2) Console
Does not read psone cds and only a few ps2 cds
both of you needs to clean your lens. how? just buy cd lens cleaner there is a liquid type by dropping 3drops to the brush of your cd cleaner then play this. ther is also the dry type you just play this and wait a few minutes until a notice appears that cleaning procedure is already completed
Dec 08, 2007 | Sony PlayStation 2 (PS2) Console
CDs won't play
Maybe you should fix the cds or clean them or try to fix the disc reader in the radio.
Nov 09, 2007 | JVC MX-KB30 CD Shelf System
Sony PlayStation 2 (PS2) Console Logo
778 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
