Question about HP Computers & Internet
Neither the Cubase ASIO driver nor the Zoom H4n Pro ASIO Driver can remain connected to the HP Spectre x360 Realtek Audio onboard chip. Recording, playback loop is awkward.
  • HP Master
  • 2,252 Answers
Ok , x360 got that.
what are you doing, attempting
then tell the story.
what OS?
W7,W8 or W10
is it virus infected.
what are you doing.
making a movie
what? what job are you you doing, and the results are./????
Posted on May 16, 2017
Lexicom Lambda is not working! New user
right click my computer goto properties-harware-device manager then right click the lambda click update driver browse it with ur cd driver...hope this help
Jan 21, 2008 | Lexicon Lambda Usb Desktop Recording...
Are asio drivers available for the Ceative Labs SB0270 USB unit
http://download.cnet.com/%7Bvalue=http://www.download.com/usb-audio-asio-driver/3000-2120_4-10066659.html
USB Audio ASIO driver helps you connect USB audio interfaces to music applications via ASIO at latencies down to 4ms. Features: USB-audio support for ASIO compatible applications like Cubase, Logic Audio, Reason, Native Instruments soft-synths; 32KHz, 44.1 KHz and 48 KHz sampling rate support; 16 bit, 20 bit and 24 bit sample resolution possible; ASIO 2 support and ASIO 1 compatible; Dithering (e.g. for use of a 24 bit input within a 16 bit application, or vice versa).
hope this helps
May 06, 2011 | Creative Labs SB0270 External Sound System
Hello I am trying to install CUBASE LE4 for usewith my Zoom H4n recorder but having diffultity getting the ZOOM H4 ASIO driver as mentioned in the setup guide. thanks pat
Hello Pat, you will probably have to download driver from the internet. I had a similar problem with another synthesizer software program. Even though the HD series Zooms come with cubase cds, they are not always compatible with the pcs. You should be ok after that.
Mar 23, 2011 | Computers & Internet
Recording on cubase le4 using my tascam us122 mk2
You're probably not recording through your tascam interface. Go to control panel -> sound, and then select the us122 as your default sound device. Close cubase and open it again. Then go to devices -> device setup, and then under your asio drivers, select asio us122. That should solve it
Oct 25, 2009 | Tascam US-144 Sound Card
It says I can not record pick the asio duplex but i don't know how
What recording software are you using? What version of Windows are you on? The ASIO driver for the Lambda should have been installed when you loaded the software that it came with, and if so there should be a control panel that will allow you to select that. The other option is to use ASIO4ALL. It is a free ASIO driver that works really well for most sound cards and software instruments and recording software like Cubase, Nuendo or the many other programmes out there.
If you need more help let me know.
Cheers.
Dec 22, 2008 | Lexicon Lambda Usb Desktop Recording...
H4 randomly stops recording on cubase le
I may possibly have solved this. I didn't realise that when I log off from Cubase, the ASIO driver returns to the Multimedia ASIO driver, which seems to be the default setting.
Every time I want to record with the Zoom H4 in future I'll need to reconfigure the ASIO driver to the H4 one.
I thought once I'd set the driver, it would remain there every time Cubase booted up. Apparently not.
Aug 28, 2008 | Zoom H4 Handy Recorder
Cubase REcording/Playback Problems
check first the sample rate maybe its to high like instead of 44k. its in 48 96 or something like that so the buffering isnt catching with the recoding . alogn with your lattency configuration must devices are ok in 512 latency.
and also be shure not to be recording directly to tyour external hard drive
in case of plugin overload issue it would not stop recording suddenly it would slow down first with some crackles and then stop or must shure freeze.
so impretty shure its somethin else.
hope it works
good luck
May 10, 2008 | Steinberg Cubase SX3
Lexicon Omega/Cubasele4
I've had this problem and similar ones. Following these steps seems to help:
Starting Cubase before switching on the Omega.
Go to 'Devices' and then 'Device Set-up'. Make sure you're in the 'VST Audio System' part of the menu. Make sure the Omega is selected as the ASIO driver - if not, switch it. Then click on 'Set to Defaults', then 'Apply' and 'OK'.
Or re-setting the Omega sometimes helps too.
It's a pain, though.
Mar 31, 2008 | Lexicon Omega Desktop Recording Studio...
My Lexicon Lambda is not working
Go to your devices tab click on the ASIO driver Lambda and when you get that message click reset and try again it should work.
Computers & Internet Logo
48 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
