Question about Pool & Spa
I have a st. Croix Hastings pellet stove, the 1 and 4 lights are on at the same time.
5 Suggested Answers
SOURCE: st croix pellet stove
Had the same problem which I discovered this weekend..........
I have an eleven year old Afton Bay....the versa grate was not moving. I look into the inner workings of the stove and saw a bracket which had broken off....
The bracket was attached to the versa grate rod and made contact with the cam system in the stove...this is what moves the versa grate...........
I called my dealer, the part costs about $12.00 and looks like it can be replaced with out having a service guy come out..........
Hope this helps
Posted on Nov 09, 2008
SOURCE: St Croix pellet stove: pellets drop
http://www.jaygaulard.com/blog/2009/01/18/how-to-clean-out-a-st-croix-prescott-exl-pellet-stove/
Posted on Feb 24, 2009
heatman101
  • 43501 Answers
SOURCE: My St. Croix Hastings pellet
Check for power to the auger motor... power but no run equals bad motor and/or jammed auger... no power means bad board or high limit cutout needs reset...
You will need to do some checking and try ti figure out what is going on....
From the mention of the squeaking I would say that maybe a bearing went out on the auger and siezed up which may have also burnt out the motor...
heatman101
Posted on Feb 18, 2011
  • 1709 Answers
SOURCE: My st croix Hastings pellet stove is 3 yrs old and is not blowing as much heat as it has in the past. What could be the problem?
Hi, Check to see if vents are free of debree (spider webs etc...) Clean fan if necessary. Also try a different pellet some pellets will burn hotter. Good Luck.
Posted on Feb 04, 2015
The fan on my langcaster St. Croix stove i think needs oiling is it possable
no point as the oil will burn off in the first application and the fumes will spoil the food being cooked
call a technician to check the fan operation / replace the fan
Feb 13, 2017 | Cars & Trucks
Tip
Alternative Heating Pellet Stoves and Pellet Inserts
Pellet stoves usually use wood pellets as their primary heat source. A pellet stove is defined as a stove that burns either compressed wood or biomass pellets to make heat to warm a home or other space.
Pellet stoves come as either free-standing units or fireplace pellet inserts which can be vented into an existing chimney. As an insert, you are able to replace your wood burning stove with this efficient and cost effect stove. Inserts also give the homeowner more of the look of a fireplace than that of a pellet stove. Pellet inserts can also be a great alternative for people who have busy lifestyles and are looking to get the beauty of a fire but prefer a cleaner burning renewable heat source.
Pellet stoves are freestanding structures that can give you the feeling that an old pot bellied stove did, tucked into a corner of a living room, den, or kitchen. Either the pellet inserts or freestanding stoves are a great alternative heating solution for keeping a house warm during the winter.
Many stove manufacturers recommend the using a corn and pellet mixture, but some are UL listed for many fuels other than pellets. These can include wheat, corn, sunflower seeds, and cherry pits.
Pellet stoves are a bit more efficient, burn cleaner, and are easier to use than conventional wood burning stoves. Pellet stoves often look very similar to wood stoves or fireplace inserts, however the similarities end there.
If you are considering burning alternative fuels then you will want to look into a pellet stove as a great way to heat your home. Pellet stoves and pellet insets have many great advantages over regular wood stoves that make them a practical heat for busy lifestyles.
on Dec 07, 2009 | Heating & Cooling
What is causing the ready light to flash red twice when I try to light my pellet stove
[PDF]INSTALLATION AND OPERATION MANUAL - Wood Pellet...
woodpelletheat.com/WinslowManual.pdf
by P Stoves - ‎Related articles
Please read this entire manual before installation and use of this pellet fuel-burning room .... FLY ASH BUILD-UP: For all wood pellet fuel-burning heaters, the combustion ......Ready Light - lights up when stove is ready to operate. Igniting Light ..
Sep 27, 2015 | Pool & Spa
Feb 04, 2015 | Heating & Cooling
Quadra Fire Pellet stove-will not ignite
I own a Quadrafire pellet stove. I have had this thing for 10 yrs. It seems every year at the start of the season I have some kind of problem. I clean it at the end of the season completely. First couple of burns are fine then get a good cold day and it doesn't work. All the gaskets, the exhaust blower, ignitor, glass front, and exhaust piping have had to be replaced. Now I have a blinking red light in the control box and cannot find anything on line to help. Does anyone know why this red light blinks 3 times every 10 seconds inside the control box? It's not the call for heat light. Think I may change to a wood burning stove to many headaches.
Oct 20, 2011 | Napoleon Auburn Pellet Stove Heater
I purchases an elcipse pellet stove in 1990. It still works perfectly. I need to replace the insulation blocks for the side walls and also need a new ash pan. Do you know where i can purchase these items.
Elcipse was manufactured by Warnock Hersey, but was sold to St Croix. So, their parts may be interchangeable with your stove. Try Pellet Stove Parts.com and click on other brands for St Croix.
http://www.pelletstoveparts.com/mm5/merchant.mvc?
Feb 22, 2011 | Heating & Cooling
St.croix pellet stove
your either burnig the wrong type of fuel, or the fuel you are burning is wet, not burning hot enough resulting in cloudy door
Feb 03, 2009 | Kitchen Ranges
St croix pellet stove
Hope this helps
Oct 21, 2008 | Kitchen Ranges
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
