Question about Food Mixers
My power mixer EMX5016cf is not turning on when I try to switch it on. What's the problem?
  • 10,028 Answers
There are fuses on the power supply board. You'll have to open the case to get access to them.
Posted on May 16, 2017
My Kitchenaid mixer's power switch is jammed...
By pass the switch and put it on power strip and turn on/off with strip. Or just replace the ****** switch. Or just bypass switch and plug and unplug to turn on and off.
Jun 15, 2017 | KitchenAid KSM150PS Artisan Series Stand...
Power switch turns on by itself
Bring the mixer to a place that services these appliances. They will have to replace the switch. This is common on appliances.
Jerry G.
Nov 25, 2011 | KitchenAid KSM5PS Heavy Duty Stand Mixer
I just replaced worm wheel on my KitchenAid Stand Mixer. Power was working prior to worm wheel breakage. Mixer was running, but not spinning. Dismantled Mixer, and replaced worm wheel. Put back...
Check the carbon brushes, look inside the hole, it is keyed, the brushes only go in properly one way. Match the missing corner on the brush to the blocker inside the brush holder.
Sep 07, 2017 | KitchenAid Food Mixers
My KitchenAid KSM90 will not turn off. All the speed settings seem to work, it just won't shut off. I have it open, but don't understand how the switch operates such that it turns the mixer off. The...
I determined that the switch that controls whether the mixer is on or off is controlled by a copper bar with a contact. The contact got fused to the copper bar, possibly due to a short. Since the contact got fused to the copper bar, the circuit was always connected, so the mixer was always on. The solution was to 1) unplug the mixer, and 2) take a screw driver and gently pry the contact away from the copper bar. When the mixer is in the off position, the copper bar and contact are no longer in contact. When the mixer is on, the copper bar and contact make contact. My mixer now works just fine. Yea!
Jan 28, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Blade will not turn
motor will hum but no blade turn if bottom seal worn and material leaks into shaft. Rekove drive head and try turning shaft if nio go dissasemble entire unit ,clean and service, replace seals
Sep 20, 2009 | Robot Coupe MP600 750 Watts Hand Mixer
MODEL KP2670 KITCHEN AID MIXER,IT WON'T TURN,POWER SUPPLIED,BUT NO POWER BETWEEN SWITCH OUTPUT TO MOTOR.
fault in the armature is a possibility. danger of electrocution if you try to self repair. See service centre
Sep 14, 2009 | KitchenAid RRKP50 350 Watts Stand Mixer
Can't move the lever to start the machine - it's frozen on off position.
Unplug first. Mixers can detach from the bowl base. You may have a lockout either in the latch mechanism or in the beaters. Try removing the mixer head from the base and the beaters from their sockets. Then plug in and try switch. If not working, unplug and attach beaters. Replug and try. Then attach to base and try again.
Make sure speed control does not have safety feature requiring to press in before turning control.
Good Luck.
Jul 09, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Mixer will not turn on, mixer ran then stopped
CAN REPAIR OR REPLACE MOTOR. IT NEEDS A CAPACITOR KIT FITTING OLD ONE WORN OUT.
£25 PART EXCHANGE PLUS POST. 07507400101
Apr 02, 2009 | Kenwood KM800 Major Classic Stand Mixer
NO POWER TO UNIT, NO POWER TO SWITCH.
Hi all. Goto mendingshed.com and download the free kitchenaid repair manual for free. These older mixers were well built, unlike the new ones. They are well worth repairing. The repair manual is very comprehensive and will assist you greatly should your mixers need repair at a later date. Good luck!
If this solution has assisted you, please rate it. ricardok45
Mar 29, 2009 | KitchenAid K45SS Classic Stand Mixer
Food Mixers Logo
51 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
