Question about Refrigerators
Water comes out of wrong area in door just changed filters
  • Refrigerators Master
  • 9,783 Answers
It is possible that heat from the light bulb has cracked the tubing that delivers water to the glass when you push the paddle on the dispenser. This condition will let water go all over the place
Posted on May 16, 2017
I just changed the water filter on my whirlpool refridgerator and got the message off the door. Now neither the ice maker or water dispenser will work.
Possibly the filter is not in all the way or maybe it has a clear sticker/seal over the middle hole. Most filters need pushed in slightly while turning about a 1/4 to 1/2 turn. If it worked before the filter change it has to be in that area.
Apr 14, 2015 | Whirlpool Refrigerators
Have changed water filter, but indicatot panel calls for order h2o filter, and comes on every time we dispence water. why?
Most models also have a filter indicator reset button located in the same area. After changing the filter, reset the filter status light by pressing the Filter Indicator Reset button or by pressing and holding the Filter button for 3 seconds. The status light will change from red to green or the status display will change from "Replace" to "Good" when the system is reset.
If your model has a water filter indicator, but no reset button, press the light switch in the refrigerator compartment 5 times within 10 seconds to reset the system. The status light will change from red to green when the system is reset.
Oct 16, 2012 | KitchenAid KBFA25ER Bottom Freezer French...
Water dispence slow
do you know if it is a whirlpool made model, 27ft french door, ice maker in ceiling, they had issues with a seal between ice compartment and ref side- leaks freezing air to water tank area, freezing tank. other wise if its not the filter -then water flow to unit. ck where it connects to ref, if good( should have steady stream with press. replace ref valve if bad look at your valve in wall or at sink.
Sep 14, 2012 | Kenmore Refrigerators
It's a Kenmore Model 106-56712500 , can't shut off alarm after changing filter, and now won't make ice or dispense water! How do I do a proper re-set code?
The 106.xxxxoooo Models are made by Whirlpool.
  • Whirlpool and KitchenAid - press the light switch 5 times within 10 seconds.
  • NOTE: If the fridge has a filter button, press and hold it for 5-10 seconds.
  • Changing the water filter should not cause the water and ice in door to not work. The actual freezer door switch will cause this problem. When the door is open ice and water in door are disabled. The door switch is a 3 contact switch. One contact is common, one turns the light on / off and one disables / enables ice and water in door. Manually depressing the door switch in the door fold hinge area should enable the water in door function. Do NOT test the ice function. If after you depress the light / door switch the light does not go out and the water in door does not work then the door switch has failed. The door switch is released from the cabinet by sliding either a putty knife or a knife blade along one side to unlock the locking tab. If the switch only has 2 terminals you have removed the wrong door switch. Check the other door.
    If your refrigerator has the wiring harness on the bottom of the door hinge there is the possibility that during the water filter change the connection of the door wiring connectors was loosened or broken. Just check to make sure that there is not a harness on the bottom of the door hinge. If there is a harness on the bottom of the door hinge make sure the connectors are connected.
    If you need more assistance just respond here and I will gladly help you.
    Thanks for choosing FixYa,
    Kelly
    Jan 11, 2011 | Kenmore Refrigerators
    I have a GE Refrigerator GSS22JFMD WW with a ice
    The water supply in the recessed part of your door is frozen. very common with this model. You will need to turn unit off and with freezer door open use hairdryer on the area where water dispenses and on the recessed area as well. This is time consuming but only other remedy is to leave off and door open for 24 hours. hope this helps.
    Feb 12, 2010 | GE Refrigerators
    Water dispenser suddenly not dispensing water
    Remove the bottom kick plate . Follow the plastic line about 6" and you'll find a connector . Push in on one end of the connector and at the same time , pull the line out . Close the door and press for water . If no water comes out of the disconnented line , the water valve is probably bad . If water does come out , the line inside the freezer door is frozen . If this turns out to be so , you can lower the freezer temp for maybe days , or , put the food on the door, inside the freezer , tape the light switch down ( to keep the lite off and fan running ) and tape plastic over the freezer door opening so the freezer will continue to work . Reinstall the line back into the connector by pushing the hose firmly into place . Leave the freezer door open for maybe 1 or 2 days for thawing out , going by ocassionally and pressing the water dispensor . Important : lower the freezer temperature slightly to keep line from freezing again . ONLY CHANGE THE FILTER WHEN WATER FLOW SLOWS OR ICE CUBES GET SMALL . The change filter lite comes on by the amount of times water dispensor is used and to make money for the vendor .
    Aug 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
    WAter dispenser stopped working
    Change the filter in the refrigerator. ..just change it..
    Is there something wrong with the kitchen faucet?..
    drinking bottled water..??.. are you drinking ACID RAIN??.... think not...??
    read this:
    Acid Rain Students Site PH Scale
    now read this..
    Analyzing Comparing Brands of Bottled Water
    Oct 11, 2017 | GE CleanSteel GSL25JFTBS
    No water from door outlet
    Hi. Thanks For The Question. I Would Check The Water Valve. Disconnect The Water Line From The Valve ,Leaving The Water On. Now Push The Water Button. If Water Flows You Have A Blockage. If Water Does Not Flow. Replace The Valve .Thanks The Appliance doc
    Oct 02, 2008 | Maytag MSD2656G Side by Side Refrigerator
    Refrigerators Logo
    26 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
