Question about LG Heating & Cooling
I have a LG refrigerator model: LFC20760ST. I need to know how the grounds are reattached from the cord to the start device, compressor, and back of refrigerator.
The start device, capacitor, chord and grounds were removed and am not sure about the grounds.
SOURCE: craftsman compressor motor/capacitor problem?
I had the same tripped breaker problem with a similar Sears model 919.195060 (25 gal) and luckily I had access to another, almost identical sears compressor to swap parts to diagnosis it. It turned out to be the run capacitor, but from what I was finding in my on-line research, it could have been a bad winding on the motor or the start capacitor just as easily. If your resistor is outside of the capacitor, just cut the wire right at the capacitor and add flag termnals Mine had 3 wires coming out of the capacitor (not the normal terminal cap style), and two of them were basically just tied together (same color). I didn't have an external resistor. I bought a GE 97F9614 run capacitor (40 mf, 370vac) and other than having to cut out a bit of the plastic on the mounting bracket and buying "flag" style 1/4" terinals from radioshack, it fit and worked perfectly. It seems if GE is the only one that has the right dimensions (1.75dia x 3.88 long, not including the terminals. That capacitor cost $27.50 with tax at a local electric motor shop. Sears doesn't even have any info on the motor parts, like capacitor - they want to sell you a new motor for almost as much as a new whole compressor. I ended up looking at parts forr the motor on a Devilbliss (that's what the 919 means on the model number, that it's made by Devilbliss), but it was not an easy way to go and really didn't help that much). The easier/normal way of matching capacitors is to measure the case dimensions carefully and match up the voltage and uf (or mf) specs,
Posted on Dec 22, 2008
jaysonemanme
  • 500 Answers
SOURCE: How to remove refrigerant lines from a/c compressor
there are 2 bolts that hold the lines in...you need to evacuate the refrigerant 1st- into an aproved tank for recycle, it is illeagal to release it into the air.
Posted on Jun 20, 2009
  • 98 Answers
SOURCE: Craftsman 25 gal compressor -- need MOTOR wiring schematic!!
Hey joe if the motor starts up and runs you have wired it correctly if the capacitors werent correct it would not start up and go into run position
Posted on Jul 21, 2009
  • 401 Answers
SOURCE: I just replaced the start relay (start device) on
Leave the capacitor on and don't worry about the cover. The capacitor really helps the compressor to not use as much electricity, thus saving energy.
Posted on Jan 06, 2010
  • 289 Answers
SOURCE: I have a GE refrigerator that just stopped
you may ov had a power problem,by turning the unit off you alowed the compressor to reset the presure,moniter unit,if it aint brock dont fix it.
Posted on Jan 19, 2010
How do I troubleshoot my LG refrigerator model:LFC20760ST that has stopped working?
Disconnect the power cord wires on the fridge side after you unplug the cord....for continuity on each wire.
Jan 28, 2017 | LG LFC20760ST Stainless Steel Bottom...
I cleaned my refrigerator out the next day it stopped working
unplug the fridge and plug it back in after a couple of minutes. this will reset the control board located behind the fridge. if after plugging it back in, it doesn't work, then you need to have the board replaced.
Jul 16, 2011 | LG LFC20760ST Stainless Steel Bottom...
Does the LGLFC20760ST refrigerator come with water/ice dispenser on the door?
Hi and Welcome to FixYa, I am Kelly
This refrigerator does not have in-door ice feature. It also does not have a water filtration system. You should install an external water filter on your ice maker water supply line if you purchase this unit.
Unit details can be found here:
http://www.lg.com/us/appliances/refrigerators/LG-french-3-door-refrigerator-LFC20760ST.jsp
Make sure to click on the drop down menus lower on the page for EACH section using the specifications tab.
Also if you choose the Gallery tab you will see there is not an in door ice feature.
Thanks for choosing FixYa,
Kelly
Dec 12, 2010 | LG LFC20760ST Stainless Steel Bottom...
All power to the refrigerator has gone, all lights have gone out and compressor isnt working
ck the main power board as i think its failed .. ( in the back under a metal cover plate . ) board has fuses on it and will cause your problem when failed . the fuses are not a service part .. the p c control board is . mm hope this helps / feed back please ..
Nov 08, 2010 | LG LFC20760ST Stainless Steel Bottom...
Hi, My fuse is out on my refrigerator, 2008 model LFC20760ST. The fuse sits right on the circuit board and I'm not sure how to release it. Can you help?
the fuse is soderedto the board and is not to be replaced as a replacement part . but that doesn't mean that you cannot replace it . it may blow again and if so find out why . the board may be very costly and the fuse is not . so it's worth a try .. mm
Sep 23, 2010 | LG LFC20760ST Stainless Steel Bottom...
Refrigerator is getting no power compressor does not run, no light in the upper or lower compartment electrical outlet is good checked with an omn meter power to circuit board but not beyond board .board...
If it feels like the whole thing is dead in the water, then it is probably your fuse in the back. always include the year and the make of your unit. then people can help more. fuses on modern refrigs are mounted on the circuit board in the back and have to be soldered off and on.
Aug 07, 2010 | LG LFC20760ST Stainless Steel Bottom...
My lg fridge just stopped working no lights or power, the receptacle works and no breakers tripped
I have a similar manual that shows just what you are up against. How about the power cord itself? Is it ok?
FRENCH DOOR REPAIR MANUAL
Feb 16, 2010 | LG LFC20760ST Stainless Steel Bottom...
Rrefrigerator not running no lights on no power, it worked today, and now nothing! The fridge is only 1 1/2 years old
check to see if you have a ground fault circuit on the receptacle you are using the frig on. Or maybe a breaker in the breaker box might be tripped.
Dec 16, 2009 | LG LFC20760ST Stainless Steel Bottom...
Fridgew/ice maker. ice tastes like sulfer.
This sound like you need a water filter change to the refrigerator.
Aug 05, 2009 | LG LFC20760ST Stainless Steel Bottom...
Heating & Cooling Logo
27 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
