Question about Samsung Tablets & eReaders
My samsung tablet 10.1 is charging very very slowly, after 4hrs only have 30%
    Problem Solver:
  • 17 Answers
It potentially could be an issue with the charger not putting out the proper amount of voltage. Id suggest trying a new one that is rated for the Samsung Tablet. If that works then you can eliminate that being the issue.
It could also be the battery wear level. Over time the battery will wear down in regards to the capacity of charge it can hold. You would need to take it to a local repair shop to get a complete analysis on the battery.
Posted on May 15, 2017
Port on 10 inch tablet not working can it be fix
Linda, if it is the charge port, mini USB, yes they can be fixed or replaced by cell phone/computer repair shop.
Check the attached links videos showing port replacement. Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Android tablet charging port fix
Toshiba Tablet AT300SE AT305SE Charging Port Repair
Samsung Galaxy Tablet 10 1 Tab 3 10 1 P5200 P5210 Micro USB Port Replace HD
May 03, 2016 | Tablets & eReaders
My polaroid tablet will not boot
polaroid pmid701c tablet stuck at polaroid screen when rebooting ...
freaktab.com/.../tablet.../polaroid-tablets/835-polaroid-pmid701c-tablet-s...
Apr 14, 2012 - It just won't go past the Polaroid screen when booting. ... At this pointPolaroid has not released the factory ROM to be reflashed, supposedly sometime within the ... There are ROM's from Onda that does seem to work well. ROM ** Polaroid AS8 ** ROOTED + TWRP
Dec 24, 2013
Polaroid ptab7200 does not turn on
May 8, 2012
More results from freaktab.com
my polaroid tablet won't turn on - Tablets - Android Tablets - Tom ...
www.tomsguide.com/forum/id-2079971/polaroid-tablet-turn.html
Jun 20, 2015 - 6 posts - ‎5 authors
I have a Polaroid Tablet, Model PMID702C. ... Now, it will not power b. ... my tablet wont turn on , and when i charge it its not working how can i ... My Samsung tablet will not turn on. - Samsung
Dec 30, 2015
My tablet won't turn on! - Battery
Jun 19, 2015
my tablet pc got boot loop - Tablets
Jul 28, 2014
Help! My tablet won't turn on! what do I do?! - Asus
Nov 5, 2013
More results from www.tomsguide.com
Jan 01, 2016 | Polaroid Tablets & eReaders
How do i restart my tablet /
If the usual methods do not work, try letting the tablet sit while on and unplugged until the charge drains to zero. Then the tablet will shut off. Plug it in and charge it fully and then turn it on. Worked for me and have had no problems since.
May 03, 2015 | Tablets & eReaders
The charge dock on tablet broke so we can not charge tablet can it be fixed? We just got it this October.
Juello. Did some research on your tablet at Amazon, (http://amzn.to/1xWx6S5) and see that they also have an AC charger (AC charger adapter with a 3.5mm power jack and delivering 5VDC 2A). Available for $5: iRulu Black AC Home Wall Adapter Cable Charger for Tablet PC 5V 2000mAh or a there's a nice replacement KB and cover: iRulu New Portable 10 1 10 5 Android Tablet USB Keyboard Case Black . I would guess the connector snapped off inside the tablet, so you will have to remove it with some tweezers. If the pin for the AC adapter broke off inside the tablet, that's a problem, but most everything can be charged from the USB port too see this website:
How To Charge Samsung Galaxy Tab 2 Via USB Port On Computer Laptop PCNEXUS (Samsung used as an example). GL
Jan 08, 2015 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
Hi i have a samsung tablet gt-p5210 &it keeps shutting down sometimes i go to play a different game &it just shuts off help!!! Thanks
specify weather it is plugged in or not when this happens and if the battery is above 30%
if plugged in, is the plug getting loose if so replace the wire that charges it and plug will be tight again . clean around plug with folded paper corner to be sure nothing is inside pressed to back of plug slowly shorting power. batteries do wear out in these things so only plug back into charge when it is below 20% and let it charge all the way up. as each partial charge cost you one of the 1000 charges in the battery's life. get Battery Doctor from the play store it will trickle charge at end of cycle and will tell you the battery's health. good app.
Dec 17, 2014 | Samsung Galaxy Tab 3 Tablet 10.1" TFT 1280...
My galaxy tablet will not turn on and or charge
hold the power button down for 10-15 seconds to force a power off. When turning back on, hold the power button down until you either feel it vibrate or something comes up on the screen.
Jan 13, 2014 | Samsung 7 in. Galaxy Tab 3, 8GB...
When I try to charge my samsung galaxy tablet a yellow triangle pops up on the battery sign
I had this same thing. The Batter image had a red line on the right side and the yellow triangle had an explanation point in the middle.
I searched the net and found a few solutions.
1. Hold the power button down for 30 seconds.
2. Hold the power button down and the volume down button at the same time for 30 seconds.
3. Just let it charge and over night and it should go back to normal.
I did all 3, in the order I wrote them. While in step 3, after about 5 minutes I pressed the power button and it showed that it was charging normal.
Hope this helps.
Dec 04, 2012 | Samsung Galaxy Tab Tablet PC
Tablets & eReaders Logo
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
