Question about Bosch Dryers
I have a Bosch WET2820GB/13 washer dryer. The dryer timer will not advance when in the auto mode (washing program followed by drying) where it continues to dry.
Oddly, it will advance if its in a drying program only. In both instances, the heater for the dryer seems to come on but in the auto mode, I have to manually cancel the program or switch it off to stop drying.
  • 833 Answers
SOURCE: Maytag atlantis electric dryer
Sounds like the moisture sensor has gone away. Not sure where it is located on this model, though.
Posted on Dec 21, 2007
SOURCE: My WVF 2402 washer/dryer washes clothes ok but doesn't dry them.
Sorry I'm way late with this but I've only just noticed it. Unplug the machine from the mains! Remove the lid (with a torx screwdriver) and you'll notice a small circular device with 2 leads attached on the top of the machine, in the centre there's a small button, press it and it should click......you've fixed it This is a thermal cutout safety device designed to switch the drying heater off if it becomes too hot. The probable cause for this is that you've over filled the machine and the air didn't circulate freely. as a rule of thumb, dry 1/2 as many clothes as you wash.
Posted on Apr 26, 2008
onthejob5130
  • 640 Answers
SOURCE: LG all in one washer dryer fills with water on the drying cycle
the unit is made to bring water in in the drying cycle ,,the water dont touch the clothes..the water is to take the lint away and to cool the drum,,you must remember that you can was 22 pounds but you can only dry 11 pound..so you must dry about half of what you wash..and drying the 11 pounds it will take 3 to 4 hours,,no exhaust...
Posted on Dec 25, 2008
  • 20 Answers
SOURCE: dryer stops after 2 min run
change its thermistor.
Posted on May 23, 2010
SOURCE: Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Posted on May 25, 2010
Admiral dryer timer not turning and no heat
It could be the high temp fuse on the element and the timer not turning depends doyou have it on the auto dry because it will not advance if it is not heating because the sensors are not detecting a decrease in the humidity levels because the element not working.
Mar 14, 2014 | Admiral 3.4 cu. ft. Top Load Washer in...
I have a Frigidaire Gallery Heavy Duty electric dryer, the dryer run non-stop even on auto-dry mode (timer doesn't advance) but the clothes aren't drying either.
Timer will not advance unless the element is working. Suspect bad element or bad thermal fuse on element housing
Dec 11, 2013 | Washing Machines
Indesit WDG1095W combined washer/dryer - program wheel stopped
I'm a bit confused you posted under Bosch but you specify Indesit, which is a UK machine. The really bad news is you need to replace the timer. the really really bad news is you can only buy the timers from Indesit, I can't find them anywhere in the US. The really really really bad news is they want 117.99 british pounds for them! plus shipping and handling. Here is a link to the Indesit site where you can purchase one.
http://www.4indesit.co.uk/cgi-bin/product.pl?PID=111846&query=Indesit%20WDG1095WG&model=WDG1095WG&path=52691
May 22, 2009 | Bosch Exxcel WFO 2264 Front Load Washer
Dryer Timer dial will not move but dryer works
Will the dryer move forward in timed dry? if it does not then you need a new timer. If if will advance in timed dry but does not advance in auto mode then the high limit needs to be replaced on the heater.
Apr 10, 2009 | Roper REX4634KQ Electric Dryer
Dryer will not turn off in Automatic mode
look to a faulty/clogged/blocked vent befoer switching partsno your machine. nost common fault for too long to dry on auto-- or wont advance on auto dry is innadequate venting
Jan 27, 2009 | Dryers
Maytag atlantis dryer model # mde6400ayw
sounds like the timer is not completing the cycle in this mode will the dryer shut off if you manuelly advance timer in that mode
Oct 21, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Bolsh E-NR WET2820GB
In order not to mistaken the connection draw it the connection or take some picture to compare your work will be perfect.
Jan 03, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Tumble dryer not working
I managed to solve the problem the following way: I noticed that if you unplug the Sensor-NTC(part nimber 154431 https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=WET2820GB%2f13 ) that controls temperature of air in the air channel, the drying cycle runs as you describe above. So this circute was checked up to the power module. Contacts of the Sensors plug were tightened; I think this solved the problem; resistance of the sensor checked. It must be 4.8K at 25 degree C. and decrease when temperature increases. I dipped the sensor in a glass with hot water.
Oct 25, 2007 | Bosch WET 2820 Front Load Washer / Dryer
Dryers Logo
23 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
