Question about Refrigerators
Just got a new refrigerator. Read the icemaker is on at purchase. Need to turn it off. Model # CRT151RW1
  • 1,830 Answers
Pull the lever on it up.
Posted on May 15, 2017
Which water line or lines do I connect to refrigerator, model # ED22RFXW01, man. 08/99
It's advisable to go with flexible plastic tube with sweet water supply. Please follow the instrction as per video attached.
Even if your refrigerator comes withan automatic icemaker, you will need to connect it to a water supply for it tomake ice. While this is not a particularly difficult job it requires someknowledge of plumbing and the use of tools. ThingsYou'll Need:
  • Compression Nuts
  • Knife Or Scissors
  • T-valves
  • 1/4-inch Copper Or Plastic Tubes
  • Drill Bits
  • Variable-speed Drills
  • Drill Bits
Read theinstruction manual that came with your refrigerator. Specific instructions forhooking up the icemaker may be included. Locate thepipe nearest the icemaker that carries cold water. Most often, this is the coldwater pipe that connects to the kitchen sink. Install at-valve in the main cold water line - not on the 3/8-inch faucet tubes - sothat there are two outlets: one to the sink and one to the icemaker supplyline. Turn offthe water. Put asleeve and compression nut over the line that will supply the icemaker in orderto tightly connect it to the water line. Turn thewater back on, and, holding the end of the tubing in the sink or over a bucket,flush the line to remove any debris. Turn the water off again. Snake theline from the water source to the icemaker connection, drilling holes in thebacks of cabinets if you have to in order to push the line through. Find theicemaker inlet from the refrigerator and attach the other end of the line usinganother compression nut. Turn thewater back on. Throw awaythe first few containers of ice to be sure the line is completely clean beforeyou use the ice.
http://www.youtube.com/watch?v=vB-uUMsckSA&feature=related
thanks.
Feb 05, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
PART THAT SUPPORTS THE ICEMAKER BROKE OFF AND I NEED A REPLACEMENT. I DON'T KNOW WHAT PART TO LOOK FOR. IT IS GE MODEL TFX26PPDACC REFRIGERATOR AND THE NUMBER ON THE ICEMAKER IS 463409G059.
ICEMAKER BROKE AND I NEED A NEW ICE MAKER. I DON'T KNOW WHAT PART TO LOOK FOR. IT IS GE MODEL TFX26PPDACC REFRIGERATOR AND THE NUMBER ON THE ICEMAKER IS 463409G059.
Jul 07, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker arm broken. do i need to replace the entire icemaker or can i repair it?
Individual repair parts are not available for the icemaker. If you cannot figure out how to rig up a make do fix you will have to purchase a new icemaker.
Jun 15, 2010 | GE Profile PDS22SCRL Stainless Steel...
Icemaker not working
it is hard to know what did happend to your unit but it can be check , and there is an arm that also turn the unit on or off but if you need to get new one the # is WR30X10061 for your unit and it is 120-160$
Dec 30, 2009 | GE GSS25LGM Side by Side Refrigerator
GE PSS26GRE SS not dispensing ice
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
Aug 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
Difference in waterline hookup between old and new icemakers
this is so often the case with some of the larger companeys. there are only two types of connections for these water lines. 1st is a compression fitting 1/4 inch 2nd is a push lock style also 1/4 inch. Both styles can be purchased at any large hardware store. they should be with pipe supplies. Hope this helps and good luck.
May 07, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Replacing icemaker in GE GSH25JSTE side by side refrigerator.
generally its very easy. for your model it looks like the icemaker goes across the rear of the freezer section. if you will look on the left hand wall on the icemaker you will see a philips head screw remove this screw and pull the icemaker towards you and it will come out then unplug the wiring harness (this is probably the hardest part) there are 2 clips that keep the harness connected securley and you sometimes have to use a small blade screw driver to release them. onec icemaker is removed you have to remove the fill cup and the end stop off of the icemaker and reinstall on the new icemaker. one done just reinstall and turn it on. youre done!! BTW the new icemaker mostlikely will not have the green light the old one did so dont think youve got the wrong icemaker.. let me know if you need any further help Thanks Peyton
Mar 16, 2009 | GE GSS25SGMBS Side by Side Refrigerator
LFX 25950TT problem
Just had this same problem. We were away at Disney for four days - turned the icemaker off before we left. We have the LG french door double drawer freezer model. Came home, the ER IF code was displayed. Wouldn't dispense water or ice. Took the icebox out, and it was all frozen in the augers. Then I read on the door something to this effect - "if you turn off the icemaker, it will not continue to cool the ice. This will cause the ice to melt and leak out of the unit, and when it refreezes, the dispenser will not produce ice or water."
So, I took the ice box out, emptied it, reinstalled it, and the unit os making ice and dispensing water as I write.
Again, if you turn off the icemake, empty the ice box, or you will get the error message when you start the ice maker again.
Apr 08, 2008 | LG Refrigerators
Whirlpool Refridgerator + ET1FTTXKQ02 - Water leakage!
Own the same model, the icemaker and the dispenser work properly but the leak is top center of the refrigerator compartment.
Nov 08, 2007 | Whirlpool ET1FHTXM Top Freezer...
Hotpoint HSS25GFP icemaker stopped working
are u sure that model # Is right.. DOnt come up in any of my model data bases Seems like u might of got a bad icemaker.. if the water is coming into the icemaker from the water valve.. icemaker has to have power, to do that... all funtions after that would be controled by the iceaker .. The only other thing i can think of is your refrigerator has to be a certain temp to activate icemaker somewhere around 0 give or take some to be safe
Aug 21, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
21 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
