Navagation in my 2013 explore is not working
It says insert disc
How do i use navagation on my 2013 escape
You can probably find a Manual online for that feature. What you will have after choosing Navigation versus Entertainment is 2 tabs in the upper right of the screen. One is Dest (destination) and the other Menu. The Dest will get you a screen which allows you to enter your City or State, then City. Everything is then presented by street, address number and so forth. Some screens allow for Zip code instead of typing the City.
The Menu tab allows setting choices on what type of roads you travel. You can also select notifications of Hazards, avoiding Toll roads or Ferries. You can set volume and even voice types.
Oct 19, 2014 | 2013 Ford Escape
Stopped working
please insert the fifa 07 play disc in to the drive and select Retry . select Cancel to quit out.
Aug 21, 2013 | EA Sports FIFA 07
Pes 2013 for play station 2 won,t start
The game is for the PS3, not the PS2, which means it won't play on an older system.
Mar 06, 2013 | Konami Pro Evolution Soccer 2013 for...
My navagation system keeps saying that it "cannot read disk" please check disk. Do i need a new disk or is something wrong with my system? 2006 Jeep Grand Cherokee?
the the problem is from the laser (lens) of your navigation system. It cannot read disk because the laser (lens) is weak or dirty.
Its might also be that the disk you inserted into the system has some scratches or the disc is bad. Try several discs on the system.
If problem still persists after trying several discs, get the laser replaced and it should read disk again.
Good luck.
Nov 08, 2010 | Cherokee Jeep Grand RB4 Navigation, AM/FM,...
My tempeture reading is -40 all the time but the navagation seams to work on the overhaed system
You need to replace the ambient air temp sensor located on the radiator support in front of the radiator.
Mar 16, 2010 | 2001 Ford Explorer Sport Trac
There is no disc in drive E insert a disc and try again
try with another cd., if still not working.
try to explore the cd., right click on the cd and click on Explore.. it should work.. else time to change the cd drive
Sep 22, 2009 | Computers & Internet
Navagation radio with 6 disc player in dash, cd player is frozen on disc 2 track 1. Won't play and gives message of no disc but the player has 6 disc inside of it. Removed radio fuses but remains the same.
Have you tried running a cleaning device through it? The case may be that the laser that actually read the disc is either stuck in place or it has burnt out on it. That's if the cleaning doesn't work.
Feb 23, 2009 | 2004 Cadillac Escalade
Hitatchi bx35a... after recording no data
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Dec 03, 2008 | Hitachi DZ-GX3200A DVD Camcorder
Navigation on my Maxx digital explorer 1 has frozzen up.
I managed to fix my parents one by removing the memory card and blowing on the contacts then re-inserting the card I guess somehow the card must have dislodged and the map files could not be loaded this should work for you as the system needs the maps files in order to operate the navagation mode...
Hope this helps
Jason
Apr 20, 2008 | GPS
NEC DVD-RW 16x DL
If you switched to a different brand of DVD's try using the brand you used before. DVD burners are tested with certain brands of DVD's and sometimes the brands that aren't on that list don't work.
Jun 11, 2006 | NEC 16X Multiple Format DVD+/-R/RW/DL...
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
