Blue sheet doesn't want to go trough my Pogo printer. Everything i've done was step by step bwith user manual.
3 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: need a manual for Polaroid pogo printer
You can get the manual on link below.
http://www.polaroid.com/media/document/PolaroidPoGoInstantMobilePrintermanual20090624.pdf
Posted on Dec 23, 2009
Ray-Tosh
  • 124 Answers
SOURCE: windows vista toshiba satellite A
@csmuradian
Have you tried the following:
1. Scan for viruses on your computer.
2. Try to boot into Safe Mode with Networking (you need to press F8 continuously upon boot-up and choose Safe Mode with Networking) and try to check if issue still occurs.
3. If Step 2 fixes the issue, try to disable start-up items that might be causing the issue, step by step guide here.
4. Set you power settings to High Performance, you can do that by going to Start > Control Panel > Hardware and Sounds > Power Options and choose High Performance on the power scheme.
Also, there are freewares our there that you could use like ccleaner to help you speed up your machine.
Good luck.
Posted on Sep 03, 2011
Why does it print with streaks through the pictures even when ive done the cleaning method a million times?
I've had that problem and running the special blue sheet that comes with the paper pack through the printer seems to work. I've had to run the blue sheet through before each printout for a while, but the problem seems to have gone away - I guess it finally got cleaned out. It also seemed like running the blue sheet through after not using the printer for several weeks was a good idea before printing. When I get a new pack of paper, I run the blue sheet through as instructed. Instead of throwing the sheet away, I store it on top of the blank sheets inside the printer. That way I can use it again if needed.
Sep 29, 2011 | Polaroid CZA10011B PoGo Instant Thermal...
My printer has the blue light on the lightbult and low toner (but ink is fine) - it will not print anything. The stuff sits in the print queue and i have to eventually delete it. The report will print...
My work-around for this problem is to feed paper in manually through the front. I turn the printer off and make sure all paper is out of the printer. When you turn the printer on - and the blue light stays lit (if it doesn't turn it off and wait - I've had to wait quite some time sometimes).. then manually feed 1 sheet of paper in the manual feed tray at the front. When the paper is inserted... you should be fine to print - and keep feeding paper in until you get your job. If you miss - you might need to hit the "continue" (triangle button)..
I've been trying to find out why mine locks up - and why it keeps jamming - but this is a tried and proven menthod - althought it is annoying it might help you for now.. Good luck
Sep 02, 2011 | Lexmark E250dn Laser Printer
Streaks in pictures tried to do what it says in the instructions did not help
Try sending the blue registration paper with the barcode through the printer.
Jan 08, 2011 | Polaroid PoGo Digital Photo Printer
Polaroid PoGo Digital Photo photographs streaky with purple edge
TO CLEAN PRINT HEAD, TAKE AN A4 SHEET OF PAPER CUT IT TO SIZE FOR THE POGO,BUT MAKE IT (3) THREE THIKNESSES THIK, FEED IT IN UNDER THE PRINT HEAD AND CLOSE LID, WHILE THE PAPER IS BEING EJECTED PUSH UP ON THE PAPER THAT IS BEING EJECTED WITH YOUR FINGERS, YOU MAY NEED TO DO THIS A NUMBER OF TIMES, BUT IT WILL CLEAR THE STREAKING. IT WORKED FOR ME AND MY POGO DOSE BRILLIANT PRINTS.HOPE THIS HELPS PEOPLE. JB
Dec 13, 2009 | Polaroid PoGo Digital Photo Printer
I got a Pogo a couple of months ago....it worked ok then.I put it away,then yesterday brought it out again.Now it won't work all.The battery is charged up.
you may need to feed the blue alignment sheet through the printer again first if you have not used it for a while. you normally get this with a standard 10pk of paper. hope this helps
Oct 18, 2009 | Polaroid PoGo Digital Photo Printer
My polaroid pogo wont print
when printing make sure that the paper is inserted in the pogo shiny side up and logo facing down. also try putting through the blue alignment sheet first as the pogo will not work without this. hope this helps
Jun 13, 2009 | Polaroid PoGo Digital Photo Printer
Streaks in my pictures
You can clean the print head by using the following procedure from the troubleshooting section of the manual:
Take paper out of the printer
Take a single sheet and put it back in - upside down (i.e. shiny side down).
Close the door and wait for the sheet to eject.
Put all the paper back into the printer in the correct orientation (shiny side up), close the lid and print again.
I've discovered even better results by keeping the special blue sheet that comes with each paper pack. I run the special sheet through before I'm about to use the printer for the first time (after not using it for a few days), and also after every three prints. The result is much better printouts for me. The special blue sheet cleans and calibrates the print head. Just put the blue sheet in the paper tray at the bottom of the stack with the bar code facing down and close the lid. It will automatically eject.
May 11, 2009 | Polaroid PoGo Digital Photo Printer
Lexmark 1270 only prints green!
Sounds like you're missing blue. Using the Lexmark software (maintanance section) that's on the PC, Clean the print heads. You should see all 3 colors (blue, red, yellow) and black. If not, buy a new cartridge as the head on the blue ink are clogged.
Hope that helps...
Geno
Apr 04, 2008 | Lexmark X1270 All-In-One InkJet Printer
22 people viewed this question
k24674
