Question about Velodyne Audio Players & Recorders
I have a Velodyne ULD 18; servo-mechanism circuit is in oscillation as if there is a leak behind the woofer but there is not
4 Suggested Answers
  • 124 Answers
SOURCE: woofer,s outer ring is ripped.
To fix this problem, you will need to contact Velodyne.
They may be able to replace the surround or recone this driver.
Because this system has the "servo" control, you need to have the accelerometer conected to the amplifier. With out it, the amplifier will not operate.
Posted on Jan 04, 2009
  • 124 Answers
SOURCE: Velodyne ULD-12 driver voice coil sensor availability
Contact Velodyne. That is the only source for this part.
  • 124 Answers
SOURCE: No sound for Velodyne ct-100 sub woofer
Sounds like a dead amp. You could check the xformer output and the amp IC's with a VOM.
These amps do not cost a lot, about $40.00. and are easy to replace.
Contact Velodyne
Posted on Mar 26, 2009
My sub woofer making noise like machine gun w out connect toamp
Disconnect the sub-woofer and see if the noise stops, if so the amplifier is OSCILLATING and so produces the noise.This can be related to fault with the pre-amp or audio processing section. Try and heat up the circuit using a hair dryer and if the fault clears then there are faulty electronic capacitors. If leak is seen then the pcb must be washed after the capacitor is replaced which can solve the issue.
Mar 12, 2012 | Infinity BU-120 Subwoofer
I have velodyne hgs15bg powered sub.. After a prolonged hard run, it developed a rattle at mid to higher volumes. what went wrong ??
You possibly ripped the woofer cone or welded the voice coil - something mechanical. There's only one thing in there that moves on purpose.
Mar 03, 2011 | Velodyne HGS-15 Subwoofer
Velodyne sub woofer: Series S Model: VA08BVX10
The volume control pot can be replaced.
Any good quality audio shop or electronics repair shop should be able to fix this.
Nov 17, 2009 | Velodyne SPL-1000 Subwoofer
I just bought a used Velodyne hps 18 subwoofer. I am hearing popping sounds even at idle. What might be causing it?
This is related to the "servo control" circuit.
For repair you will need to contact Velodyne.
Nov 16, 2009 | Velodyne HGS-18 Speaker
Need schematic for velodyne 5 pin din servo amp
Only available from Velodyne.
velodyne at www velodyne com
Nov 16, 2009 | Audio Players & Recorders
My velodyne subwoofer is making "clicking" sounds and is not producing normal sound (e.g. music). What may be the problem?
You did not state what model this is.
If it is a servo controled unit, you may have a problem in the control circuit.
The models that use the servo control stystems should only be serviced by Velodyne or one of the listed service centers.
Velodyne is the only source for parts for these units.
Oct 01, 2009 | Velodyne Audio Players & Recorders
Contact Velodyne
Feb 25, 2009 | Velodyne CT-100 Speaker
Woofer,s outer ring is ripped.
Jan 03, 2009 | Velodyne VRP-1200 Subwoofer
Lost manuel
The Q55 is not a velodyne product
Nov 17, 2008 | Velodyne CT-80 Subwoofer
Oct 05, 2008 | Velodyne DD-18 Subwoofer
Top Velodyne Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
Are you a Velodyne Audio Player and Recorder Expert? Answer questions, earn points and help others
