How do you refill the central heating system on a fortic tank
  • Heating & Co... Master
  • 2,461 Answers
Close the drain **** .open hot water tap upstairs . releases ball **** tank should fill and water will come out of hot tap keeping air bubble in tank . bleed rads as normal .
Posted on May 16, 2017
  • 230 Answers
SOURCE: My oil fired central heating
Since you have done a good job bleeding the system, I will suggest that the impeller on the pump is bad. Many times these will simply deteriorate in the volute causing the symptoms that you describe.
This looks like it is in the wrong forum. Try reposting this in the heating section of the FixYa web site to get more responses.
Posted on Jul 03, 2008
  • 659 Answers
SOURCE: My Central heating system as no vent
You are talking about a gas fired system I assume. So no, it's not a big deal. Code now states that you need to vent the gas furnace from the attic or a crawl space and not from the living space. They change this code back and forth all the time. It's nothing to worry about if you do not plan to sell the home.
Posted on Apr 01, 2009
heatman101
  • 43501 Answers
SOURCE: st6400c thermostat wont run the central heating independantly
This does not sound like a thermostat problem. I would be looking for a zone valve or circulator pump problem.
Posted on Nov 12, 2009
SOURCE: Step by step instructions on how to refill the
water pressure keeps coming down
Posted on Dec 19, 2009
  • 149 Answers
SOURCE: I am considering fitting a Fortic tank. I require
what you have is better than a fortic. fortics should only be used if you have a lack of space to put in any thing else. if you are planning to heat water with the emersion just cap the ends that went to the rayburn and you are good to go. or fit a floor standing oil boiler and heat rads as well. you may have to add zone valves for that to keep water in the tankat the right temp
Posted on Mar 25, 2010
Water in tank continuously slowly flows out. No flapper but a central tower.
What ever functions as a flapper is defective and needs to be replaced.
Nov 10, 2014 | Home
I have Drayton Heating System in new home. I seem to be unable to put my central heating on without also having the water heater on. The boiler will come on if the water heating and central heating is on...
you will only be able to have the central heating on seperately if the system is fully pumped. Why would you not want the water to heat? it is more cost effective to use the residual heat to heat the water and keep the temperature up. Costs alot more to heat a cold house and a cold water tank
Nov 06, 2011 | Honeywell Programmable Thermostat Heater
On a back boiler central heating system my hot water works fine but cant get my central heating working i have changed the pump there are no motorised valves on the system i have checked the the expansion...
In most cases problems with the circulator pump boil down to two problems.
The most common is air in the lines causing an air lock.
The next problem is that the pump gets stuck and is not running even though itmay be hot and seem to be running. In this cause the pump can sometimes betaken apart, cleaned and it will work, but usually it needs to be replaced.
Here is a tip that I wrote that will explain circulator pump problems in moredetail.
Heating Circulating Water Pump Problems
heatman101
May 09, 2011 | Water Heaters
Which way do you fit a central heating pump. pump in to boiler are out.
most moder boilers are pumped on the flow out however if it is an open vented system the vent over the tank should be fully open with no valves or pump between it and the boiler
Oct 29, 2010 | Broan-NuTone (N9965) Central Heating...
I am considering fitting a Fortic tank. I require it to provide hot water to the kitchen and bathroom sinks and the bath. An indirect cylinder is currently installed because there was a Rayburn which...
Jan 04, 2010 | Mansfield Plumbing Products Mansfield...
My small tank in the loft off the central heating is boiling over?
you have back syphening coming from your open vent pipe,the pipework needs looking at,could be that the open vent pipe is in the wrong place
Nov 21, 2009 | Ruud Central System Air Conditioner
St6400c thermostat wont run the central heating independantly
Nov 05, 2009 | Honeywell Programmable Thermostat Heater
I need to restart my boiler after running out of oil
Try a website called www.repairclinic.com and see if that will answer your problem.
Jan 19, 2009 | Water Heaters
My oil fired central heating system has stopped heating up stairs.The rads and pipes have been flushed out,when the system was refilled the upstairs rads heated ok untill the system was switched off for...
Jul 03, 2008 | Heating & Cooling
Help fortic star
you could j tag it go on some fta forums
Nov 21, 2007 | Fortec Star Lifetime ULTRA
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
