Question about Briggs Garden
My briggs and stratton engine starts with one pull and then immediately stalls....what are the likely causes of this?
  • 928 Answers
I will give the best answer I can with the lack of information.
Make sure the fuel line to the carb doesn't have a quick connect valve. If you were not the original owner of the Brigg & Stratton mentioned here, then it was probably work on and the quick connect maybe was remove.
If the quick connect was removed, it won't regulate the amount of gasoline going to the carburetor, meaning that you will have to adjust the on and off valve yourself until you achieved the right amount of gas.
Posted on May 15, 2017
Spark plugs foul immediately
Fouled plugs may be caused by oil leaking into the cylinder. Does it smoke when running (cold), are you using up the crank oil. Black smoke is excess gas comsumption, blue smoke is oil burning. If your plug is fouled with black carbon, you are most likely running to rich.
Apr 07, 2014 | Briggs & Stratton Briggs Stratton Vanguard...
Toro 4200 time cutter stalls when the handles are pulled in
I believe the timecutter has a safety switch that only allows the unit to start with handles in the out position, then you need to be on the seat to be able to pull handles in without stalling engine. Have you tried checking the seat switch? It sounds like one of your safety switches isn't working. Either the seat switch or the handle switches. That's where I would look first. Good luck!
Oct 24, 2013 | Briggs & Stratton Briggs Stratton...
Lawn mower will not start. It began to run rough and acting like it was going to stall. Then it came to the point where when you pulled the cord it would start then immediately stall. Now it will not start...
It likely needs a carb rebuild. Be sure to check your tank for water in the fuel as well.
BTW lawn boy carbs appear to be the simplest carb ever but are very touchy ( especially with leaking inlet needles) so dont underestimate them and you will be fine.
Jan 02, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
21hp b ANd S engine keeps stalling unless choked
CARB CLEANER FOR CARS WILL WORK JUST FINE,BUT YOU MIGHT HAVE TRASH IN THE BOWL.IF SO YOU WILL HAVE TO TKE THE CARB APART
Aug 17, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Craftsman 7.0 HP Briggs & Stratton mower stalling
Check the muffler, if the muffler is clogged it could cause overheating of the engine, and could keep the engine from getting the necessary fuel-gas mixture.
Aug 09, 2009 | Garden
Briggs and Stratton 22hp v twin OHV smoking badly
First thing to do is pull your dipstick and check for broken or missing O-ring also as you pull it, look to make certain that it was seated properly and all the way locked. If either condition exists, you will be leaking into the crankcase which will cause your symptoms
Jul 11, 2009 | Briggs & Stratton Briggs Stratton Intek V...
7 hp craftsman Briggs/stratton lawmnower stalls
Your engine model # 128602 Type 0212-E1. Forget about ordering from Sears and paying shipping and waiting a week. Go to your local Briggs and Stratton dealer (most shops are) and buy part # 694395. Should cost about $3.00
May 30, 2009 | Craftsman Garden
Garden Logo
24 people viewed this question
Top Briggs Garden Experts
Mike
Matt Olenzek
Matt Olenzek
Are you a Briggs Garden Expert? Answer questions, earn points and help others
