The washing times are all changed after a power outage. How can I reset them? Whirlpool Duet Steam
fridgetech
  • 473 Answers
SOURCE: Code F1 @ Whirlpool Duet Sport Washer
An F1 is almost always a defective main control board. Could try unplugging the unit for a few minutes and see if it will reset. The part # for the board is W10110072. Sears sells it for $119.46 http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=WFW8300SW01&productCategoryId=0153200&brandId=1198&modelName=RESIDENTIAL-WASHER&diagramPageId=00003&componentDescription=CONTROL%20PANEL%20PARTS&documentId=W0607261&backToLink=Return%20to%20Sub%20Components%20list.
Posted on Dec 12, 2008
jonniewalker
  • 1031 Answers
SOURCE: error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
Posted on Mar 14, 2009
jsrock516
  • 5911 Answers
SOURCE: where can I download a owners manual for a whirlpool duet steam washing machine?
Go to managemyhome.com and register. This is a FREE service. Once registered, log in and click on the "Home Manager" heading at the top center of the page. Look for the "Owner's Manuals" link under the drop down menu and click on it. Fill in your information on the following page and your manual is available in a downloadable .pdf format. Hope this helps you.
Posted on Apr 29, 2009
  • 17 Answers
SOURCE: What is the cu. ft of my Whirlpool duet washing ma...
3.7 CUFT
Posted on Aug 11, 2010
blueextc3221
  • 15935 Answers
SOURCE: whirlpool duet dryer f70 code
The F70 and F71 error codes on this model of washer indicates a communication problem between the user interface control board and the central control unit (main control board). These error codes can sometimes be caused by a power surge or glitch through the electrical lines. Try unplugging the washer to completely disconnect electrical power. Wait 1 minute and then plug the washer back in to the see if the fault code clears. If it does, then the washer may work normally.
If the code reappears, then you could have a wire harness connection problem, a failed user interface control board or a failed central control unit. I recommend calling a service technician to properly diagnose and repair this type of problem so that the correct component can be replaced.
Be sure your unit is plugged into a 3 prong grounded outlet as well.
F71 is a "heatbeat failure" which means that your front interface control board is shorted and will need to be replaced. it's actually fairly easy to replace and can definitely be done by yourself. To access the part, just pull the unit forward and remove the 3 screws coming in from the back of the top panel. Remove the top panel by pulling it back, up, and off. Then remove all the screws going into the top of the control panel. Remove the dispenser drawer and remove the screws coming in through the dispenser. Remove the screws coming from the inside of the dryer going forward into the control panel, then remove the control panel (it's just clipped in on the bottom. After that you can disconnect the wire harnesses to the front interface control board and replace that part.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 28, 2010
F-35 code My washing machine Whirlpool duet steam machine keeps going into the F-35 Code and stops washing.  I don't have the book.  Please, if anyone knows what this means or how to fix it, my email is...
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Sep 12, 2008 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
WHIRLPOOL DUET GAS DRYER WGD87HEDW1
Unplug for 1 minute. Plug back in. Check status
Apr 17, 2016 | Whirlpool WGD87HEDW Duet WGD87HEDW 7.4 cu....
My whirlpool steam duet washer won't pour water in the wash cycle
There is no output from the control panel to switch on the inlet valve, so check the inlet valve at this time of the cycle. Also check the water level pressure sensor switch.
Choose another program to confirm if not the controller seems to be suspect.
Jan 24, 2013 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
I have a Whirlpool duet washing machine. We had a
Unplug the machine.
Remove the lower front panel.
Reach your arm up inside on the door latch side. Feel for a pull ring and pull it to release the door.
Feb 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet accidentally put into "control lock". How do you reset it?
The following link explains how to correct the control panel lock issue on a Whirlpool Duet:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
The control panel lock is actually a designed safety feature that allows you to lock the control panel to keep small children from manipulating the controls. It can be inadvertently set by leaning against the control panel buttons, or following a power outage.
If you have questions, please let me know. I hope this helps you.
Oct 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet 4.4 Washer (not steam) power cord too short
Hi, you might be able to find an 8 foot dryer power cord at your local building supply or hardware, or electrical supply store. It will be labelled for a dryer. First look at the dryer receptacle. The cords come in two types, 3 or 4 wire, so get the one that will match youyt receptacle. The wirte should be # 10 minimum.
Jun 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sportwon't respond after power outage
IF YOUR MACHINE IS A WHIRLPOOL DUET TRY THIS ;
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED status light turns off.
Good luck
Jun 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
