How do I get the color back, it is too light, everything look like a ghost
Only on color printing am I getting ghosting of the images. How can I adjust this?
hello,when i see one color dusting, ghosting i usually change that color drum unit.If multi color ghosting probably the transfer belt cleaner blade.thanks don
Nov 10, 2009 | Canon imageRUNNER C3200 Copier
Loss of red color and dual images
Ur convergence is dead,U know how to solders?Buy a convergence kit,use what in that kit.ur tv should be back to normal.This website have the convergence kit
Tv repair World.com.
Oct 21, 2009 | Hitachi 57F500 57" Rear Projection...
Poor picture (fuzzy ghost image/aura)
well you should check the settings and read menual
Jul 22, 2009 | Panasonic TC-P50G10 Plasma TV
AKAI PT5598HDIX, the picture is ghosting
Convergence - many other posts here. A sample: http://www.fixya.com/support/t634294-replaced_convergence_board_picture_still
May 01, 2009 | Akai PT5598HD 55" Rear Projection...
Visio 32L color goes bad with ghost images after about 5 minutes.
This sounds like one of the two things that destroys electronics. Heat. You can try this. Place a fan blowing into the vents of the set before you turn on the set. See if the set run longer before the problem occurs.
You may have a marginal part or bad connector/connection.
Feb 14, 2009 | Vizio L32 32 in. LCD HDTV
Getting Ghosts and color line separation.
my sony kp-57wv600 is showing a ghost of the image in all three colors.. anyone no how i can fix
Dec 27, 2008 | Televison & Video
Mitsubishi wd 52525 Problems, but no blinking lights.
Are you using an hdmi cord or av cables?
Apr 10, 2017 | Televison & Video
Pink highlights on LCD screen
IT SOUNDS LIKE THE MAIN BOARD IS BAD. THERE IS 2 DIFFERENT VERSIONS FOR THIS SET .AM02 UNITS OR VERSION 0001 UNITS. THE PART NUMBER IS BN94-00695E. THEY BOTH ARE ABOUT $210 + $50 CORE.
DON..
Jun 02, 2008 | Televison & Video
Color ghosting on left side
A magnetic field such as would come from a speaker might cause the ghosts but would not stop your set from coming on when it's hot. You may have a horizontal deflection problem such a bad flyback transformer or some other component that gets worse with temperature. You need to have it checked out by a technician. Stargazer
Mar 15, 2007 | Mitsubishi WT-42315 42" TV
Open Questions:
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
