The unit is too close to the roof causing report higher temperatures. what size pipe do I need to extend the unit higher
3 Suggested Answers
chillmaster
  • 104 Answers
SOURCE: oil trap for 2 ton split unit
Pipe size is okay, not that I know any better than the manufacturer, but I would recommend at least two and possibly even three oil traps in the vapor line on the way back up.
Posted on Jun 15, 2008
  • 3092 Answers
SOURCE: can you extend the vent and if so how far
Check with the makes the flue could get cold and not work google make modle for manual which should have flueing in there .
Posted on May 12, 2012
Air condition is in attic but is leaking water from a pipe that is staining house & dripping on the roof of the porch why does it do that?
An aircon condenses water vapour from the local atmosphere. At times of high humidity the amount of liquid water produced can be considerable and must be allowed to drain away safely.
The answer to your problem would be to move the pipe or to modify it, perhaps by extending it all the way to the ground.
As the aircon is in the attic it is probably higher than the rainwater guttering and it might be possible to move the pipe so it drains into the rainwater system.
May 20, 2017 | Heating & Cooling
What Will A Roof Inspection Cost?
I am In Australia and just paid $160 for a roof inspection and report.
It was $400 for a full house inspection and report. Both these costs were fairly similar to two other quotes. Cheers Bob
Dec 15, 2016 | Cars & Trucks
What is the minimum vertical vent distant from top of water heater to top of cap. Water heater is stand alone outside furnishing water for military force provider showers unit.
Generally 40 feet for ordinary atmospheric-vented household water heater...
Straight run to roof.
Atmospheric means no power vent... just hot air drafting upwards
Google search: gas vent height code
Atmospheric venting code depends on 4 basic factors:
Diameter of vent--- bigger vent, more draft
How many water heaters are connected to same vent
BTU per hour rating of water heater-- the more gas that is burned per hour, the bigger the vent needs to be
How straight the pipe is -- are there any horizontal or lateral runs
http://www.ameri-vent.com/files/assets/files/1366372183_Sizing26ApplicationGuide1.pdf
http://waterheatertimer.org/pdf/Bosch_Checking_the_draft.pdf
http://waterheatertimer.org/pdf/checking-the-draft2.pdf
Other factors can include
-wind conditions... higher wind across top of vent pipe on roof can reduce draft, and cause downdraft that blows deadly CO into same room as water heater
-vent termination near high walls, trees, high roof peak etc will reduce draft or cause downdraft
-amount of incoming air supply... if water heater is inside a closed room, then there is no air to draft up the pipe, burner will shut down or burn lazy yellow instead of clear blue
-stuff piled up around water heater that obstructs air intake
-dirty air intake screen that reduces air intake
-vent fans inside same room as water heater that pull air down the vent and cause reduction in water heater draft
-generally elbows reduce draft by 10%
-vent cannot terminate near any window door or air intake for another gas appliance
-bird build nest on top of vent pipe after vent termination falls off
-highly acidic gas by-product causes large amount of condensation inside pipe that burns hole in pipe or drips down and damages combustion parts...blower and inline condensate trap and drain might be required
-multiple water heaters installed on same vent line.
Gene
Water Heater Timers Save Money
Mar 27, 2015 | Water Water Heaters
Ford escape 2014 power moon roof barely tilts open
This is normal. The reason it raises higher is due to the design of the sliding arms in the moon roof. without going into too much detail, the reason it raises before closing is to "unlock" itself from from the "Locked" open Position in order to get to the "Locked" closed position. Its a fancy way of making it seal well when closed and not rattle when open
Apr 10, 2014 | 2014 Ford Escape
Sun roof wont close
theres a way to close it by taking off the panel above that covers the motor and putting a allen wrench into the middle of the motor unit and turning it i think clockwise. If the gears are stripped it wont work...but if its just the motor then manually turning the gear should close it. I figured out which way it needed to be turned to close then put a allen attachment on my cordless drill and made it easier cause it will take awhile
Dec 12, 2013 | 1997 BMW 328
Cracked sunroof glass
No way to tell really, it can be rapid temperature change caused by any number of condition.
Oct 11, 2017 | Cars & Trucks
My high efficiency furnace has water (possibly condensation) running down the air intake pvc pipe into the furnace and all over the burner, gas valve, and wiring.
First, check the drainline from the furnace. You have a 90% gas fired furnace. Where 80% furnace has 1 heat exchanger, yours has 2 heat exchangers. And the second heat exchanger will cool the exhaust enough, that it ends up below the dew point, and your furnace outlet/exhaust will condensate. This drain is probably stopped up. Now, I've installed and service many of these systems and I've only seen the piping at the roof you described once. And that was when the roofers replaced the roof, damaged the furnace flue pipe, and tried to repair it themselves. Normally, and this may not apply to yours, we tie in the exhaust/supply lines about 2-3 ft. above the furnace. Then 1 pipe goes through the roof. Thus 1 pipe is a kit that has an inner liner & outer pipe(2 pipes in 1). Now I'm not sure if this is a problem or normal for your system, but it may be worth looking into. You should be able to find it in the installation manual, or call a local parts house that sells your brand, or as your tech. And if it's just your drain, forget all about the piping I mentioned. Hope this helps!
Mar 08, 2017 | Goodman Heating & Cooling
Which side ofintake manifold does temperature gauge sending unit go on
Water Temperature Indicator Sender Unit
The water temperature indicator sender unit is installed on the engine into an engine coolant passage. The water temperature indicator sender unit reacts to the engine coolant temperature. Its resistance decreases as the engine coolant temperature increases.
Water Temperature Indicator Sender Unit Removal
swb~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not mix Standard (green) Coolant with Extended Life Coolant (orange). If mixing occurs, drain engine cooling system and refill with originally equipped coolant type. If this contamination occurs the service change interval on Extended Life Coolant will be reduced from 6 years/150,000 miles to 3 years/30,000 miles.
  1. Partially drain engine cooling system as described.
  1. Disconnect engine control sensor wiring (12A581) from water temperature indicator sender unit (10884) .
  1. Remove water temperature indicator sender unit.
Jul 30, 2010 | 1998 Ford Mustang
Oil trap for 2 ton split unit
Jun 14, 2008 | Heating & Cooling
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
