Question about LG Heating & Cooling
Aircon shutting on and off automatically.How can I reset to keep it running continiously
  • jamiel786 Jul 25, 2009
    Thanks for the prompt reply.The AC technition is here with me.The gas has been refilled.The thermostat is working fine.The temp sensor is ok.
  • 3,267 Answers
If the thermostat sensor is working then I would suggest keeping at 19 deg C. Hower its most likely that the themostat has malfunctioned and needs replacement. Another thing possible is that there has been leakage of the refrigerant gas which would also display the same symptoms.....................sodeep
Posted on Jul 25, 2009
I have aVW jetta 4, 2.0 highline, 2001 that stalls engine at low gears. The situation becomes worse when the aircon is on.
Engine stalling issue at low speeds
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve. Buy a can of throttle valve cleaner from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
Jun 08, 2012 | Cars & Trucks
A error code E154 appears, then I shut down the unit, and restart, no problem a few minutes, then the error code appears again. have you the solution?
Hello there, I guess your Running capacitor is leaking already, when you start your aircon it will run after a minute the aircon will stop with errors, because the fan is stop running due to busted capacitor. thanks
Apr 25, 2011 | Heating & Cooling
My frigidaire 70 pt dehu. has a continious drain hose but the bucket keeps filling up and shutting off. What can i do ? thanks for you help christian
make sure that the hose is not plugged and that it runs continuously flat or downhill... if it is trapped it will not drain...
heatman101
Apr 15, 2011 | Dehumidifiers
Aircon runs for a few minutes then shuts down and timer light flashes
when we start the AC indoor working and out door unit compressor working but fan motor not working and indoor timer light blinking
Dec 16, 2010 | Mitsubishi MSZ-A24NA Split System Air...
I have a GrandAire and the aircon works fine; when I turned the heat on, it seems to work fine (warms the house), but the fan in the outside unit is not spinning when the heat is on...is this a problem?...
I think your unit is working in good condition. If you keep in cool mode the out door fan runs to condensate the heat in condenser by taking fresh air from the ambient. And when you keep heat mode, definitely the ambient temp will be too less.I fit takes from their then compressor will get frozting and it couldn't work properly. Depending on pressure increase, the fan will automatically run and stop. Don't worry. Thanks.
Dec 16, 2010 | Heating & Cooling
Audi a3
Does it keep running till the batt is flat? It could be the aircon condenser fan running - on the left as you stand in front of the car. This is a common prob with A3s of this age.
I have a '05 3.2L Quattro V6 and suffered the same prob. The batt is in the boot of the V6 and is sealed like Fort Knox so impossible to disconnect. After about 3 days with this the fan running constantly and having to put a charger on it every night I let the batt run completely flat to try and reset the complete system - no DIS lights - no starter motor clicks - DEAD. Then I jump started it and the prob disappeared completely. Everything is working perfectly ncluding the aircon. That was 4 days ago and 'touch wood' I've had no probs since. I know this won't work for everyone but it's worth a try before forking out £300+ for a new condenser fan unit. Good luck!
Oct 19, 2009 | 2005 Audi A3
I have a Ford BA Falcon but the heater does not work can you help
You'll most likely find your Air mix shaft has snapped - very common in the BA's and Territorys. Part only costs roughly $40, however the whole dash needs to come out so you can insert the new shaft. Less commonly it could be the HIM box
Aug 03, 2008 | Heating & Cooling
Heating & Cooling Logo
126 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
