Seike tv no sound - Televison & Video
Rca remote model number CRCR351, R2O474, 2T39EW Need code hook remote to my seike tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
Dec 14, 2016 | RCA Televison & Video
What is code for Seiki TV?
that is because sony remote is not a universal and will only control the original sony which it was sold with
Feb 09, 2016 | Sony Televison & Video
There is no sound from the tv, how do I turn on sound?
About 243,000,000 results (0.42 seconds) Search Results
    10 Ways To Fix A TV That Has A Picture But No Sound ...
    removeandreplace.com/2013/11/14/10-ways-fix-tv-picture-sound/
    Nov 14, 2013 - If your TV has a picture but no sound coming out of the speakers, thereare a few things you can easily check. ... See below for the best solutions to fix a TVwith no sound. ... Television Has No Sound Answer 1: Make sure TV is not muted.
    There is no sound or low volume coming from the TV ...
    https://us.en.kb.sony.com/.../there-is-no-sound-or-low-volume-coming-f...
    Aug 15, 2015 - There is no sound or low volume coming from the TV speakers. Article ID: ... Make sure no headphones are connected to the TV. Verify that the ...
    Picture But No Sound TV - Bright House Networks Support
    support.brighthouse.com/.../Picture-But-No-Soun...
    Bright House NetworksIf you have picture but no sound. Press to ... Ensure that the audio and video cables are connected to the same inputs on the TV. For example, if ... My BHN App.
    No sound from my TV via HDMI when my cable box is ...
Jan 21, 2016 | Televison & Video
My Seike 32" flat screen t.v. volume automatically turns down on its own everytime I turn it up???? My t.v. only 6 months old!!!:( How can I fix it?
Main system control memory IC fault. If the set is under warranty; contact the authorized service center. The fault is at its main board; sometimes, that board might need replacement. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 07, 2015 | Televison & Video
What if the Seiki Tv do not have the white plug in? Please show details I do not know what a 1019 is u miss under stand the ? I ask how to hookup a DVD player to the Seike Tv that do not have a white...
You seem to think you are talking to someone you have spoken to before? This is not the case.
Do you not have an HDMI socket? The model number of the television is always useful in questions such as yours. I could find the instruction manual for it.
The connection is called Composite Video, using three plug, one is for the video signal and the other two are for left and right audio.
In home applications, the composite video signal is typically connected using an RCA connector (phono plug), normally yellow. It is often accompanied with red and white (or black) connectors for right and left audio channels respectively.
Look for any markings around your
red, yellow, red, like LEFT and RIGHT or L and R. That is the audio.
Oct 07, 2017 | Televison & Video
Seike tv model# le-24g90 remote code #
Call the manufactor or the company they'll have it.
Jan 03, 2013 | Televison & Video
I turned off my seike tv model number se321fb and now it wont turn back on? the surge protector has power how do i get it to come back on?
Even though the indicator light on your surge protector is on, the surge protector outlets may not be working. Test it by plugging in a different electronic to make sure it still works.
It could also be a problem with your remote, such as dead batteries or that the remote is no longer programmed with the correct codes.
Here are a couple of troubleshooting checklists that can help you identify the problem and what you can do to solve it:
Remote not working
No picture on TV
I hope this helps!
Aug 03, 2012 | RCA Televison & Video
No sound on TV
If the TV programs come's up with sound, then is possible that the TV set could be problem free. then cheek the system frequency if it need to be adjust from NTCS, PAL, AUTO MESECAM and so on. Cheek the DVD and VCR if they are in one of the following system settings and adjust the TV set to the settings at which the DVD or VCR is set to. Then you can also cheek if the cable is properly inserted, that is audio to audio and video to video. Nevertheless, if you have properlly connected your cables and set the system frequency to match with each other, and still no sound, then the TV could have sound problem.
Possible courses of sound failure in TV are as follows:-
1 RF stage
2 sound Ics or transistors
3 broken speakers
4 a break down resistor which supplie positive voltage to the sound curcult
Dec 09, 2008 | Televison & Video
Seiko vr5000
You may download a zipped copy of the manual here.
Aug 14, 2008 | Seiko VR5000 Dictionary
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
