What size propane holding tankk was installed into the 1988 30 foot honey motor home
The top thread shreds sewing in reverse.
(put my answer in wrong box on this site. Duh)
Get a good light on the foot so you can study the problem. You may need three hands or a helper. Thread the needle, and hold the end of the thread as you hand turn the hand wheel forward, press the reverse and as the needle goes through the foot see if isn't rubbing the foot. If its not rubbing the foot, take the feet pieces off and go through the same motions watching to see if the needle/thread isn't rubbing on the hole in the feed dog. You may need to go down a size in your needle or modify your machine parts with emery cord.
Good Luck.
Mar 14, 2016 | Juki DU-1181N Walking foot Industrial...
What size is the glass shelf in a consul 8 cu ft propane fridge
measure the space with a tape measure or order by model number :-)
Aug 18, 2014 | Refrigerators
What foods can be stored for an unlimited amount of time?
: Foods that can be stored for a life time include:
White rice
Dry pasta
Instant coffee
Instant tea
Instant cocoa
Wheat
Honey
Non-carbonated soft drinks
Sugar and salt
Baking soda
Corn
Salt
Soy beans
Powdered milk
Feb 04, 2013 | Home
Can i switch a model RN30 from natural gas to propane?
Only the portable heaters that are manufactured to be used on dual fuel (nat gas/propane) can switch from one to another. If they are made for 1 type of gas only, they are not field serviceable and cannot be converted. Douglas
Sep 30, 2010 | Reddy Heater-30-55,000 BTU Variable
Whats the medecine of pimples in the body
If you are suffering from pimple,you can simply use honey since it is loaded with antibiotic quality that can prevent bacterial infections and help you eliminate pimple. All you need to do is soaking a cotton swab honey and apply it to the affected skin areas. Leave it on for 30 minutes and rinse your skin off with warm water. Remember to Use a cotton towel to make your skin dry. How to Get Rid of Pimple Scars Top 10 Natural Home Remedies
Sep 05, 2010 | Health & Beauty
Repar water pump on 1996 35hp johnson
VERY EASY REPLACEMENT
REMOVE PHILIPS HEAD SCREWS THAT HOLDS THE PLASTIC WATER STRAINERS ON THE FOOTOF THE MOTOR,
NEXT LOOSEN THE HEX FITTINGS 7/16 OR 1/2 WRENCH SIZE THAT WERE COVERED BY THE STRAINERS
NEXT REMOVE THE 2 STAINLESS STEEL BOLTS THAT ATTACH THE FOOT TO THE LOWER UNIT.. BOLTS COME OUT FROM THE BOTTOM,, NEXT LOOSEN THE NUT ON THE FRONT OF THE FOOT FACING THE TRANSOM LEAVE A FEW THREADS TO HOLD THE FOOT SO IT DOSEN'T FALL. NEXT WIGGLE AND SHAKE THE FOOT
TO LOOSEN IT FROM THE LOWER UNIT . NEXT STEP REMOVE THE NUT WHILE HOLDING UP ON THE FOOT THEN SLOWLY REMOVE FOOT ASSEMBLY WITH DRIVE SHAFT.
NEXT REMOVE THE O RING FROM THE FITTING THEN REMOVE THE FITTING FROM THE SHIFT ROD THERE SHOULD BE A BIGGER O'RING ON THE SHIFT ROD NEXT TO THE WATER PUMP HOUSING . REMOVE BOLTS HOLDING WATER PUMP HOUSING ON THE FOOT ASSEMBLY LIFT OFF HOUSING LOOK FOR IMPELLER KEY TO FALL OUT . I RECOMMEND REPLACING IMPELLER AND HOUSING AS A KIT . INSTALL IN REVERSE ORDER .
IT'S A PIECE OF CAKE ...
Aug 06, 2010 | Boating
I was coming home w/ an half tankk of gas, when all of the sudden the fuel light chimed. I looked at the gauge and it read empty past the red line. I made it home thankfully, although when I cranked the...
You weren't low on gas - your fuel tank sending unit is failing and needs replacement. It's inside the tank and usually can be replaced without replacing the fuel pump as well - don't get suckered into that.
Nov 18, 2009 | 2000 Oldsmobile Silhouette
I have an older Genesis grill with a leaking regulator
You can get a replacement regulator at just about any home improvement store (Home Depot, Lowe's, etc.) There haven't been changes in the size of the ports or thread patterns on regulators or propane tanks in the last 15 years.
Oct 07, 2009 | Thermos Stainless Steel Gas Grill
Glo Warm Self Venting Heater Model FB3B Emits strong odor
The propane may have a higher sulfur content; however, the odor may go away soon. It is probably caused by the dust and oxidation (micro-rust) that attached itself to every part of the heater while in storage, even though it was "sealed".
Sep 29, 2009 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
