Question about Building Materials
The motor only clicks when I press either the remote or stationary switch. Was working well two days ago. Nothing blocking the track, door travels freely when disconnected.
  • 250 Answers
SOURCE: door opener will not engage as mechanism moves along the chain track
Make sure the rope hanging down has not been pulled. If it has the door has been disengaged from the opener. You can correct this by flipping the metal part up (that the rope is connectd to) toward the drive track. Then open or close the door using the remote. The track should grab the door again.
Posted on Jul 08, 2008
Tech Jenkins
  • 359 Answers
SOURCE: 2001 malibu rear driverside window off track
Just take a phillips screw driver, and a good sturdy putty knife, and your fingers, and just pry the plastic away from the metal of the door...
Open the door first, and where the inside door handle there should be 1 or 2 screws, and one near where the handle is to open the door from the inside. Take these out first before attempting to pry off the door panel. The panel is held onto the door by plastic snaps shaped like an enlongagted tooth.
Don't be surprised if you have to get a whole new window motor assembly, alot of times they come as one assembly and seperate parts do not exist. Good Luck!!
Posted on Aug 29, 2008
SOURCE: Liftmaster 1/3 HP - humming, but does not open.
It's the gear drive. There are kits online for about $40, if you're semi-handy you can replace it yourself. Search for liftmaster replacement parts.
Posted on Dec 16, 2008
  • 244 Answers
SOURCE: chamberlin whisper drive 3800
may be bad logic board. is trolley jammed?
Posted on Jan 17, 2009
Door Tech
  • 98 Answers
SOURCE: Garage door opened, won't close
If you can press and hold the wall button and the door will go down, you have a photo eye issue. Check the photo eyes at the bottom of the door.
I have got a Eazy Lift Mk 11 garage door unit. When i opened it this morning it went just half way and stucked.When i press the remote the motor is not working and the motor is now 4 years old. What c
2 steps for you... first put new batteries in the remote. next trip the door mechanism by pulling on the rope. that frees the door from the chain that operates it. then close and open the door manually to prove the track is ok. then close the door and reengage the tripped mechanism. now press the button on the remote to retry. BTW... most doors will reset the catch mechanism automatically. just press the button and let her go.
Dec 21, 2014 | Building Materials
My driver side power seat quit working in my 2004 eddie bauer explorer. I rplaced the entire seat (adjuster assembly, track and all) and still no workie. I hear clicking at the chip board when I move the...
Sounds like a short in the wiring. Start tracing the wire back. You will probably find it under the carpet on the Left side, near the door. Good luck.
Aug 16, 2013 | Ford Explorer Cars & Trucks
How do i reprogram the power sliding door on a 2005 buick terraza
From the owner's manual:
If your vehicle has
the dual power sliding doors, both doors will have
to be reset. To reset a door, do the following:
1. Check to be sure the power sliding door is
unlocked and securely closed.
2. Turn the ignition to LOCK.
3. If the power sliding door overhead console
switch is in the override (deactivation)
position, return to the activation position.
4. Open the sliding door using the remote
keyless entry transmitter, overhead console
switch, or passenger switch. Allow the door to
travel fully open.
If the door does not travel to the fully open
position, press the overhead console switch to the
override (deactivation) position and slide the
door fully open and closed. Check for foreign
objects in the tracks. Repeat the procedure starting
with Step 1. If the door resists travel to the fully
open position, see your retailer for service.
Dec 27, 2012 | 2006 Buick Terraza
Resetting motor of a dominator garage door
Doe the motor have a battery back-up, or mains only?
Step 1: Disconnect the linking arm from the motor traveller, and test (by pressing button on remote or wall console), that motor runs traveller to the fully open position, and stops where the "open" limit switch is. Then run motor (by pressing button on remote or wall console), to the fully closed position. If the motor fails to run through a full open/ full close cycle, the limit switches require checking.Assuming that the motor runs through the full open/full closed cycle, focus on the door. All motors have built in circuitry, preventing motors from crushing objects. A double garage door should be able to be lifted easily by one hand. The door should be able to be left at any height, and remain there, or creep ever so slowly downwards (travel time of approx 10mm per 5 seconds is ok). If your door is properly balanced, and the motor will still not lift it, the control card on the motor is damaged, and requires replacement.
Jul 02, 2017 | Home Security
Liftmaster Garage Door Won't Close
Sounds like maybe the door traveled too far and the trolley has jammed against the bolt just in front of the motor. If so, loosen the chain enough to take the tension off the chain and then run the opener until the door closes. While the door is closed locate the 'up limit' control on the side of the motor unit and turn it 2 full turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
May 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
Keyless entry only works drivers door, car relocks
The window track may have some grit (sand or dirt) in it causing the window to drop down when it reaches to top of it's travel. This is because the safety feature which keeps you from choking yourself in an electric window works on resistance. Keep the track clean - a shot of WD40 in the track will clean it out. That should fix the window.
The lock problem may be a battery issue in the remote. Otherwise it sounds like it is in the anti-theft unit. Check for a loose ground issue.
Nov 16, 2009 | 2001 Nissan Pathfinder
No reponse when using the remote, the wall control works fine.
The remotes use a receiver to actuate the door and the wall control does not. It sounds like your logic board is bad. Maybe a lightning storm recently? Try removing the board and look for burnt or missing traces on the printed circuit.
Sep 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Not working
Sep 07, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears craftsman 1/2 hp garage door troubleshooting
My garage door opener will start to close then stop and go back to the open position. If I put pressure on the door as it is closing sometimes it will close all the way and sometimes it will return to the open position. Can you help me. Thanks
Aug 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
32 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
